#351 |
Member#: 88130
HIIC
Vehicle:2011 Legacy GT Silver |
![]() Good to hear,..Will tackle this again as soon as Im off baby duty for our 2 twin girls,..
#352 |
Member#: 88130
HIIC
![]() So i finished up today and found the top copper washer all munched up. But apparently the washer i bought new from the dealer is larger in hole diameter than the old ones on the turbo. I used the old washers and no leaks.
I gotta pick up the new vacuum hose, t fitting, and pill from the dealership on Monday as the ne i got used was thrown in the box from the seller and i cant tell what size pill it is. ![]() Last edited by abakja1; 09-01-2013 at 11:42 PM. |
#353 |
Member#: 13641
TXIC
![]() subscribed for my install.....
#354 |
Member#: 321665
BAIC
Vehicle:2006 WRX VF39 Swap WRX Blue |
![]() Bump for doing this. How hard is open source tuning? And or how much more effective is dyno tuning?
#355 | |
Member#: 88130
HIIC
![]() Quote:
Dyno tuning is effective because its in a safe enviorment. Your not on the open road and you can do various runs consistently. |
#356 | |
Member#: 323379
Vehicle:1992 Trans Am |
![]() Quote:
I prefer street tuning to dyno tuning. Much more comprehensive. Dyno tuning is great if all you want is a specific power curve. |
#357 | |
Member#: 107618
Vehicle:06 GG WRX / 09 FXT @florencedestinedfxt |
![]() Quote:
Again, it's just much safer. |
#358 | |
Member#: 321665
BAIC
![]() Quote:
#359 |
Member#: 107618
![]() Very nice. Watch the torque, thats how the 5 speed can go.
#360 |
Member#: 321665
BAIC
![]() Edit.
#361 |
Member#: 53975
South East
Vehicle:2004 Forester XT Java Black Pearl |
![]() For anyone having trouble finding the old map notes, you can either use Cobb's new Confluence based docs (linked on their site) or can search google for "site:www.accessecu.com vf39" to find the older PDFs. The 2006 WRX VF39 map notes refers to the pill modification mentioned in this thread numerous times. The 02-03 notes don't mention the pill. The Q&A on Cobb's site states numerous times that the stock WRX pill should be used. From what I gather, it looks like you should just use the stock WRX pill unless your WRX's map notes state differently.
#362 |
Member#: 478590
Vehicle:2004 Forester XT Black |
![]() Bought a XT with a blown turbo, replaced the turbo and I was still bellowing thin smoke out of the exhaust. Jumped the the conclusion that the heads were blown. Swapped the head gaskets, valves, and valve seals. Now Im still blowing whitish thin smoke (Using 5w-30 Synthetic). Anyone have a clue why very little smoke is rising from the turbo area/uppipe and smoke bellowing out the exhaust at 1500+ rpm?
#363 |
Member#: 478590
![]() S.O.S
Shot in the dark, Had bought a Forester XT 04 121K miles with a blown turbo. Replace the turbo with a used turbo from a wrx 06 TDO4L turbo. Still puffing light white smoke, billows of greyish-white thin smoke(Synthetic 5w-30) So it could also be oil burning. However Oil burn and white synthetic smoke didn't occur to me. SO I presumed a head gasket blew and hit the ground runnning. Got new valves, lapped and reseated the valves, cleaned them all to bits, resurfaced the head, kissed the cams with 700 grit(minimal-light scoring), swapped the gaskets(None of the gaskets seemed to be quite blown but well on the way to failure). Piece it all back together, new cam seals, timing belt kit, water pump, fuel injector seals, all of it. I bought a stainless steel oil feed line to the turbo and cleaned all my oil filters in my banjo bolts. So then we go to start the car and it all seems good, then oil burn from the turbo after idling for 5 minutes and still greyish white smoke past 1500RPM. So then we check the turbo if it's still good, nanoscopic play on the shaft, basically none and no signs of damage. Howere there was coking on the intlet turbine, so we check the PCV valve and it's not rattling, clean it with brake cleaner and try again. FINALLY turbo oil smoke from the turbo area of the engine bay was gone... But now we were getting steam... ****, so then we notice the oil return hose wasn't properly clamped annnd leaking coolant????? For disclosure while checking the turbo I blew into the oil return line until air escaped and sprayed it with brake part cleaner, did I **** up and do I need to rebuild my turbo. I'm clueless about these things, and I've now watched a ton of videos, can't find this problem... probably because people aren't as dumb as I am xD. Thanks for your time, opinions are wholesomely welcome! |
#364 |
Member#: 483159
![]() Hi, I'm thinking about doing a VF39 swap on my 2007 wrx and was wondering what all has to be replaced to make sure nothing bad happens. I've seen some people say you need to get it pro-tuned and that an access-port isn't good enough. I've also read that you have to upgrade the intercooler to an STI one and upgrade the injectors. I was curious what all you had to do to yours before it was VF39 ready.
Thanks |
#365 |
Member#: 247823
BAIC
Vehicle:2007 STi limited SWP |
![]() https://www.cobbtuning.com/maps/2007...e-3-vf39-turbo
The mods you need are pretty clearly listed. If you use the Cobb map, make sure you have all of those mods pretty specifically. Custom tune maps are made for the parts you have on your car, the Cobb map would be thrown off and would be a bad idea to use if you deviated and had, say, a 2008-14 STi tmic instead of the 04-07. edit: A custom tune is obviously more ideal. But if you have an Access Port, this map can get you along for the time being, until you get a few more mods and make paying for a custom tune ($500+) worth the money. As long as you own an AP, the map is free to download. Last edited by pigboat_2; 03-09-2018 at 09:58 PM. |
#366 |
Member#: 483159
![]() the only thing different that I see is that it calls for the stock intake or the cobb intake, but I have an injen intake and the rest of the motor is basically stock with an aftermarket exhaust. That shouldn't make a huge difference should it? Sorry I'm just getting into imports and dont want to ruin the engine
#367 | |
Member#: 247823
BAIC
![]() Quote:
#368 |
Member#: 483159
![]() It has an Invidia downpipe and a catless 3" straight pipe. Can you get a custom tune from Cobb that would be suited better for my setup? I've never used an accessport so I dont know what all can be done with it
#369 | |
Member#: 247823
BAIC
![]() Quote:
Accessport allows you to reflash the ECU with another map, and allows you to monitor whatever parameters you want in live data. As well as log data. Super useful. You’ll want a V3 sub002. |
#370 | |
Member#: 50064
Vehicle:'12 WRX (WRX#8, Subi#12) |
![]() Quote:
exhaust IC fuel pump injectors (highly recommended. You will be restricted by fuel for sure if you don't) Piece of advice: Seriously don't waste your time with an Accessport. Been there done that. Twice. The vf39 map is barely better than your normal stage 2. The only way to feel the bump from the bigger turbo is through a protune. |
#371 |
Member#: 480875
Vehicle:06 wrx wagon aspen white |
![]() did anyone with an 06WRX have interference on the engine casing with the return coolant line hard hose?
i had to carefully bend the hose slightly, and even grind away some of the engine casing to allow the VF39 to fit. |
#372 |
Member#: 526000
Vehicle:2006 WRX STI WRB |
![]() It would be nice if these pictures were still available
![]() ![]() Removing the vf39 from my 06 sti for the first time (I think the seals are bad, but well find out) and was looking for a good writeup with pictures. |
Trunk Swap Instructions | Sti-lysh | Interior & Exterior Modification | 15 | 01-11-2006 08:41 AM |
N00b JDM STi swap instructions? | perret318 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 03-31-2005 07:26 PM |
clutch swap instructions? | sailil | Mid Atlantic Impreza Club -- MAIC | 5 | 08-03-2004 09:03 AM |
Trunk and lock swap instructions? | Fair Oaks STI | Interior & Exterior Modification | 2 | 08-16-2003 02:59 PM |
Bring back the bumper swap instructions! | AccidenT | General Forum Archive | 1 | 03-17-2001 12:33 AM |
