#126 |
Member#: 67807
![]() Meh, QA and QC is interchangeable when discussing the quality of a car that leaves the assembly plant. Doesn't matter the before or after, someone got a **** product and it will impact their experience with the brand.
#127 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
![]() Smokingtire talked a lot about the warranty denial story, along with the GR86 cup car (which has an upgraded oil pan and baffle, would be interesting if it were sold separately) |
#128 |
Member#: 50586
BAIC
Vehicle:64 Impala |
![]() at least the wheels didn't fall off lol
#129 |
Member#: 141952
Vehicle:2023 M340i |
![]() does subaru have people applying sealer by hand at the factory instead of robots like everyone else?
example at the beginning of the vid. |
#130 |
Member#: 21356
NESIC
Vehicle:2017 Subaru Corolla STI Limited SE-R Type (R) |
![]() This whole thing makes me worry about my Kia, which had part of the engine re-sealed.
There are gobs of sealant around the oil pan ![]() |
#131 |
Member#: 873
TXIC
Vehicle:2020 JEEP / RAM Datsun 71 240Z & 68 2000 |
![]() I generally detest RTV when I build an engine. When I was heavy into old Detroit V8's, I barely used a drop, while my fellow less mechanically inclined friends used it like ketchup on fries. Guess which leaked after 1 month. Know your application and know its environment. Appling a gasket is much like painting a car. It is about prep. It is about surface condition and cleanliness.
Most gaskets on old school V8's were installed dry. When I see gobs of RTV sticking out of an oil pan it tells me a job was rushed and they are hoping the viscosity of the RTV will make up for ****ty workmanship and technical skill in surface prep. Oil pan gaskets do not need a drop of RTV. At most a very thin film of it can be used to 'glue' the gasket onto the pan for ease of installation. VaporeOn, I wish you luck on your engine. |
#132 |
Member#: 317270
Vehicle:15 WRX, Sienna, GR86 |
#133 |
Member#: 528403
NWIC
Vehicle:22' WR-HikingShoe 17' F250, 18' Q5, 18' CRV |
![]() *Applies it fine the previous Gen, ****'s it up on the current Gen* lmao
#134 |
Member#: 2272
BAIC
![]() Subarus haven't used physical gaskets since the EA engines in the 80s. Every one has been RTV on the EJ and the FA/FB motors.
#135 |
Member#: 873
TXIC
#136 |
Member#: 141952
#137 |
Member#: 2272
BAIC
#138 | |
Member#: 153088
Vehicle:2005 Baja Turbo 95 Sambar 06 Forester |
![]() Quote:
Oh man. And it sucks. I've watched out techs cleaning that stuff off. Glad that's not my job. |
#139 | |
Member#: 183032
NESIC
Vehicle:RWD Camry Pull me over red |
![]() Title says it all really: Toyota stuffed the 1.6T from the GRYaris/GRCorolla into some GR86 models as a test bed for race cars.
#140 | |
Member#: 161333
NWIC
Vehicle:20 Yami XSR fast leaf |
![]() but also:
#141 |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
![]() Base model, steel-wheel'd, 3cyl-turbo, 4:44:1 final GR86 plz.
#142 | |
Member#: 139693
Vehicle:Dura ngo 95 horrorshow |
![]() Quote:
but if you think about it, the 4 banger Supra don’t sell well. Wouldn’t it be better to put the G16 in the Twins and rock and roll? The inline 3 turbo is compact and not bulky like the 2 headed boxer motor. I mean the damn thing couldn’t weigh that much more in G16 trim. 100 lbs, at worst? Still would be 3k or under and that’d be a big F U to the Cayman and Porsche for half. Say it’s 40k, good look getting something else on the market like this for that kind of money. 300 HP, turbo, 3k lbs, rear diff, 6MT. ****. |
#143 |
Member#: 317270
![]() I figured the 2.4 would have put the crying about turbo mostly to bed but the G16.. I mean that just makes sense.
Info I found has the complete G16 engine weight with turbo at 240lb. FA20 from first gen I think was like 140lb heavier than that, FA24 would be about the same. Hey they listened to us before, ha |
#144 |
Member#: 317270
![]() Shdhabebdj
#145 |
Member#: 163775
Vehicle:2023 BRZ CWP |
![]() So, crate motor kit please? The 2.4 feels great in this car, not knocking it at all, but a G16 swap in a few years would be great.
#146 | |
Member#: 73805
![]() Toyota Finally Turbocharges the GR86 Sports Car, But There's a Big Catch
Toyota built a few 86s with GR Corolla-derived turbo three-cylinder engines. Quote:
#147 |
Member#: 450808
SCIC
Vehicle:2017 WRX Premium WR Blue Pearl |
![]() I posted this R&T article in the BRZ thread but didn't realize the issue was already being discussed here. Anyway, here we go.
https://www.roadandtrack.com/news/a4...pickup-update/ |
#148 |
Member#: 450808
SCIC
#149 |
Member#: 139693
![]() Oh how this reminds me of my Ford product. They had not designed the head properly (and honestly the choices they made with the engine block are perma-bad) and rushed the RS out the door. When enough of them had coolant escaping and f’ing the motors up they caved, spent money to design the HG properly, then passed it off as a kind of TSB instead of a full on recall
![]() The same will happen here. The more this goes on the more both companies will be forced to deal with it and issue a TSB, recall, whatever they want to call it. And at the same time fix all future production. It’s a bad miss that many are carsplaining away and it’s bs. |
