#51 | |||
Member#: 508105
NWIC
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
![]() I don't consider that figure estimate to be "made up" when it was provided by one of the top engineering groups in the industry regarding their experience.
He even admitted himself he's never even seen let alone used a KB product and hes raving about how reliable the OEM pickup is. ![]() ![]() ![]() Given how how much berating of others he does on this forum you'd think he'd know what a wrist pin access port is. Gotta love diehard OEM fanboys
#52 | |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
![]() Quote:
If the OP wants more info, let me know. |
#53 | |
👏 Big Ron 👏
Moderator Member#: 18062
![]() Quote:
1. An owner losing an oil pickup is a very rare thing. Some would say replacing it is wise, but using a risk assessment analysis where the likelihood is low and the severity is high, this is a topic where there is no right answer. I lean towards no. My opinion means zero. 2. Radiators fail, mine has twice. Both times were drama free and I nursed them along with a Pepsi bottle of water for a few months until I could swap it out. Explosive failure is probably more rare than oil pickup issues as I've actually heard of oil pickup issues. I lean towards no. My opinion means zero. 3. Re-gap pistons. Now someone posted an easier way to do this, which is a great knowledge share! But...seriously...pull the whole motor? The cost/benefit of this is incredibly low and what if the motor has terrific ring gaps once checked? I lean towards no. My opinion means zero. 4. AOS. I've gotten in trouble about this topic before. I was there with Elrond 3000 years ago when no one was running one and motors were failing at the same rate then as now. And there's no good way to test the claims that I'm aware of. They aren't hard to hook up(ish) and aren't expensive(ish), but I doubt the practical benefit and doubt their ability to "save" a motor as death-knell knock is more caused by the right foot than 92 vs 93 octane. I lean towards no. My opinion means zero. 5. Tuning of any flavor. I don't view this so much as a motor saver as a driveability mod and I'm a huge fan of it vice it being critical to motor longevity as there are some high mile OTS cars out there. I lean towards no for reliability but yes for driveability. My opinion means zero. And to all, please quell the need for rhetoric in posts. I just dropped $1400ish on a new stereo setup in my 04 ****box. Dumb as hell it is. Worse I dropped 6 large on a paint job last year, again dumb. We all do dumb stuff. But do dumb stuff based on your financial and personal wants with eyes wide open....listen to opinions and make an informed choice with eyes wide open even if its "dumb". And again, my recommendation for all motors is https://shop.getadomtune.com/gdt-cyl...ooling-system/ which is cheap and easy and has documented cooling equalization benefits which may be the very reason people pop motors. And if dumb, its 1 hour and $100 of dumb which is a really low cost of entry to reliability. |
#54 | |
Member#: 512891
Vehicle:2010 STi/21 Passport RIP 19 WRX & 16 FXT |
![]() Quote:
![]() As far as reliability mods, I picked up my 61k bone stock 2010 STi and have bought a bunch of the mentioned mods but haven't gotten around to installing them yet. Up to 67.5k now. Unfortunately I have bought so many things that can be installed together that I haven't had time to do it. Example: AOS, cyl4mod, KoyoRad, oil cooler. While I'm doing the cooler I should do the KB pickup/baffle/pan...etc, etc. My car is not a fancy 19+ though. |
#55 |
Member#: 50072
South East
Vehicle:2017 STI Blue |
![]() Looks like that 2019 TMIC part number is used for 2017-2020 STI models.
#56 |
Member#: 508105
NWIC
#57 | ||||||
Member#: 428511
Vehicle:2016 STI |
![]() Quote:
#58 | |
Member#: 508105
NWIC
![]() It actually does.
![]() ![]() ![]() ![]() ![]() Stay mad and stay stock my friend. Last edited by K3rm1tth3fr0g; 10-05-2022 at 09:25 AM. |
#59 |
Member#: 292708
Vehicle:2006 WRX white |
![]() My daily driver is an '06 WRX with 283,000 on the clock. The engine has never been out or apart. Figured I'd share my .02 about what I have done, and what has failed along the way. All maintenance and repairs have been done by me.
- Replaced failed secondary air injection valves at 90K - The upper tank of the factory radiator split open the day after returning from a cross country road trip at 120K. I replaced it with an aluminum Fluidyne. At that time I also did the timing belt and water pump for the first time ( I know I was late ). While doing the timing belt I replaced the oil pump with a Cosworth blueprinted high flow oil pump. Figured that would be a little extra insurance. The car also got it's first mods at this time - Cobb SF intake, Access Port w/ stage 1 OTS map - At 140K I installed a Grimmspeed TMIC, and a Perrin AOS solely to keep any oil residue out of the new intercooler. - 150K the release bearing completely failed leading to the first clutch and a transmission case repair. - Replaced both noisy front wheel bearings at 160K - Replaced leaking valve cover gaskets and leaking oil cooler seals at around 200K. -Replaced a failed ignition coil around 210K - Timing belt and water pump for the second time at 220K ( Gates water pump from the first time had started leaking ) - Fluidyne radiator failed at about 250K. The larger tank of the aluminum radiator rest against the core support and eventually rubbed through and started leaking. Probably could've been prevented with a more careful install. - and now at 280K I can hear the release bearing starting to fail again so it's time for clutch number 2. Will also address some oil leaks - rear main seal and petrified crank case vent hoses. Also check engine light is on again, and I have verified that the secondary air valves have failed again. It's not causing any driveability issues so I will probably install a used set I have laying around. I will also pull the intake manifold to replace the rubber fuel lines that leak and cause a bad fuel smell when it's below freezing out side My best advice for reliability is regular oil changes with quality oil. Most of mine I have used Amsoil 5W30. Not sure if the Cosworth oil pump had anything to do with the engine longevity, but I think it was worth it for me. I drive back roads on my work commute, so the car gets driven aggressively on a regular basis, definitely not babied. The mild performance mods made the car fun enough for my daily. I always think about doing more, but the reliability would suffer. Hope this helps the OP with your modification decisions! |
#60 |
Member#: 511379
Vehicle:2019 WRX Dark Grey Metallic |
![]() So--in short, here's what's been done, based on this thread and advice from others that I've met:
IAG AOS Street Version Getadomtune Cylinder 4 Cooling Mod I will say that the AOS has been really helpful. Doing a drive from NJ to Indiana, I still regularly checked my oil at each fill up. Before, I noticed that there was some oil being burnt, and normally after a back and forth trip I had to top off oil. Now, this may be placebo or not, but doing the same checks I noticed my oil levels are consistent and don't need topped off. Next mods I plan on doing is getting a Cobb downpipe and EBCS to then get tuned. I'm happy with the stock airbox and a GS Drop In Filter, but I may upgrade the turbo inlet like I did on my 19 WRX. |
#61 |
Member#: 511379
#62 |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
![]() I still say go with the killer bee oil pickup over the AOS. If not, atleast change the oem with another oem, but if you are willing to do all that, you might alwell just upgrade.
#63 |
Member#: 508105
NWIC
![]() Agreed - modding other parts of the engine for more power on a stock pickup is not smart
#64 |
Member#: 511379
![]() I think then on that token, the Killer B oil pickup and the oil pan would be next before more power.
Agreed? |
#65 |
Member#: 511379
Agreed? |
#66 | |
Member#: 428511
Vehicle:2016 STI |
![]() Quote:
You keep forgetting to mention that. |
#67 |
Member#: 193940
![]() Don't see the point of a larger oil pan from killer bee. At your stock power level its a want and not a need. The other two I would say they are a need to be on the safe side. If you really want the oil pan too but short on cash, get one of their Blemished High Performance Oil Pan, EJ Series in their "garage sale" section, 30% off. Same thing but at $300. Only different is that its blemished, but who cares if its under your car. With the extra cash left over get the cooling mod
#68 |
Member#: 511379
![]() @BlackFighter - the cooling mod and AOS are installed, might have missed it, not sure why I'm getting these damn double posts.
Fair point on the oil pan, but the pickup sounds more necessary. |
#69 |
Member#: 508105
NWIC
#70 |
Member#: 508105
NWIC
![]() It's because this website is 20 years old and barely functions on good days
#71 |
Member#: 428511
Vehicle:2016 STI |
#72 |
Member#: 428511
Vehicle:2016 STI |
#73 |
Member#: 511379
![]() Fair on the website comments, lol.
All in all, I'm happy with the mods done so far, I had gotten the AOS oil return line to the PCV insulated as well, as a precautionary measure. So we'll see how that works out. Thankfully, the dealership I got it from (not Subaru) is good with the modifications, and they have a lifetime engine warranty that even covers modifications (which it states in the warranty.) Only thing I have to do is take it in every 6 months and get a checkup on the engine and make sure I change my oil every 3 months or 4000 miles. |
#74 |
Member#: 511379
#75 | |
Member#: 428511
Vehicle:2016 STI |
![]() Quote:
dude, they are not warrantying your engine for lifetime, period. that's not a thing There's fine print in there that will mean they are literally not going to cover a single issue you have, and it will be BECAUSE of your mods, not in spite of them. Just like the advice you've been getting in this whole thread, think about that one for just a few minutes. A non subaru dealer sold you a car and gave you a lifetime warranty on the motor even if you mod it? Not one dealer on the planet provides a legitimate warranty like that, (because they don't have to) but this particular dealer is giving out that level of coverage to compete with zero other dealers that give that level of legitimate coverage and it means they will be on the hook for your engine for a decade plus potentially? sheesh, even Kermit can't possibly go along with that one, and that's saying something |
