#1 |
Member#: 475898
Vehicle:2005 Legacy GT |
![]() https://youtube.com/shorts/Vr9AzztZ7bQ?feature=share
This a 2005 Legacy GT. I just removed and reinstalled the turbo, and as usual, the cooling system needed to be burped. This time around however, I am experiencing what you can see in the video. It only happens when the car is warmed up, and I'm thinking it's the thermostat trying to open but failing due to a bubble. Any ideas on fixing this? I'm going to try again now that the car has fully cooled down, but I'd love some insight.
#2 |
Member#: 475898
![]() Tried again, no good, both large radiator hoses give a large jolt when the car is warmed up, but I don't feel the lower hose get warm enough.
Car doesn't overheat while idling but fans also don't turn off. |
#3 |
Member#: 475898
![]() Put in a new thermostat, the issue remains. I'm concerned mostly by the loud tick/jolt the hoses give. Water pump is less than a year old, could it be an issue?
#4 |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
![]() Are the coolant caps in the right place? Radiator and expansion tank caps are different PSI. Do not mix them up.
#5 |
Member#: 149347
NESIC
Vehicle:05 LGT ,09 SpecB Black/silver |
![]() The 108kPa cap is the cap for the turbo tank.
The 137kPa cap is the radiator cap. I like to have newer caps. In Aug this year, I had to burp the system in 2005 GT wagon. As I have always done, put heater on full hot, I jack up the right front corner of car as high as I can get it. With both caps removed, I fill the radiator, until it's almost full, then put its cap on. Continue to fill the turbo tank until it's about half full. While you're doing this you can hear bubbles moving through the system and out the open cap. With turbo cap open, start engine, while car is still jacked up, let the engine heat up and fans cycle. You may notice bubbles coming out in the turbo tank. When you think all air is out, shut off engine, put tank cap on. After the engine cools fully, verify coolant level is at the Cold full line on overflow tank. I carry coolant in the car for a couple of day's checking and topping off overflow bottle as needed. I've done that same process a few times over the 18 years I owned the car. |
#6 |
Member#: 149347
NESIC
![]() I also don't use one of those special burping funnels.
#7 |
Member#: 475898
![]() Yeah it's pretty much the same process I do, from what I can see, no bubbles appear in the overflow tank and it's only when the car starts to overheat, that I see the violent throbbing of the coolant hoses, and how the water level "jolts" as in the video.
I've removed the intercooler again to see if I maybe mixed up any PCV tubing, though not sure if that could be related ![]() |
#8 |
Member#: 475898
#9 |
Member#: 475898
![]() Thanks for the info on the caps! The 137 kpa was on the turbo tank, and the radiator had a 80kpa one.
Got it replaced, followed your instructions exactly and my car is now properly running. Thank you! |
#10 |
Member#: 193940
![]() Your welcome, very common mistake.
#11 |
Member#: 149347
NESIC
![]() Yes, glad you got it figured out.
For some reason, I thought, the caps had some kind of different tabs, so you couldn't put them on wrong... ? |
#12 |
Member#: 149347
NESIC
#13 |
Member#: 475898
![]() Apparently they're the same. I bought the car used so I'm not surprised they were incorrectly placed.
Bad news is the car started to do it again. Overheating, the two main hoses on the radiator and the larger of the two hoses that go from the turbo reservoir to the radiator, are doing the violent jolt. Thermostat hose remains cold :/ |
#14 |
Member#: 475898
#15 |
Member#: 519868
Vehicle:2010 Impreza WRX Satin White Pearl |
![]() I'm going to throw this out there since I goofily made this noob mistake, but any chance the thermostat is in backwards? The spring needs to go inside with the jiggle pin at 12 o'clock.
#16 |
Member#: 149347
NESIC
![]() The spring side goes towards the inside of the block. Pin at 12 o'clock. I'm sure if you ask google, you'll get a video on how to install...
You can search for the service manual too. |
#17 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
![]() im surprised this hasnt caught on with sharing...i found that removing one of the heater lines while engine is running until some coolant starts flowing out of it will resolve the air bubble...a prior customer shared this with me and have not had issues bleeding the system since...i did not have to do it when i added my cylinder 4 cooling mod, but also have only had the system open once to add it so far
#18 |
Member#: 475898
![]() Finally fixed!
The coolant hose from the turbo reservoir to the turbo wasn't placed in correctly, so it was sucking in air apparently. I put it in all the way, tightened it and started the car again, and IMMEDIATELY I could see the small water spout inside the turbo reservoir flowing (car was already a little warm). What a ride, but I did drive for a good while and even did a slight pull and the needle stayed put in the middle. Thank you, everyone! Jedi03, that looks like a promising solution, I will keep it in mind if I ever need to burp the system again. |
