Welcome to the North American Subaru Impreza Owners Club Friday January 27, 2023
Old 11-06-2022, 09:04 PM   #1
Glutton
Member#: 529499
Default Checking valve lash in vehicle?
I think the previous builder may have dumped the buckets from his new heads. I just can't think of what multiple ticks of varying intensity coming from one side would be other than valve clearance problems. The heads had 100 miles on them, so like an idiot I didn't verify.
I was just planning to pull the engine, but maybe it wouldn't be as bad as it seems in frame? Would you pull it or mess with it in the car?
Glutton is offline   Reply With Quote
Old 11-06-2022, 11:05 PM   #2
benflynn
Member#: 515308
Unhook the motor mounts and jack it up some. I’m sure you could check some, changing anything might be one hell of a chore.it’s prob easier to pull it.
benflynn is offline   Reply With Quote
Old 11-07-2022, 01:51 AM   #3
WheelsCSM
Member#: 20765
2008 Forester XT
6mt/18g-xt
You can check them in the car - it's not too bad. I did the passenger side on my Forester. Adjusting them in the car would be practically impossible. If you just want to check I wouldn't pull engine, but if you expect to have to adjust I would.
Mine were within spec 80,000 mi after my rebuild.
WheelsCSM is offline   Reply With Quote
Old 11-07-2022, 03:41 AM   #4
Subie_
Member#: 419354
2007 STI
Crystal gray metallic
Agree w/ others. I've done it and it's not too bad. Just be careful putting the cover back on, the gasket likes to move around. A few dots of RTV will hold it in place. I pinched it once and almost ran my engine dry from oil leaking out.
Changing buckets with it in is doable, I've done that as well. It's not fun. Your back is going to hurt like he'll from bending over for so long. Cleaning/ prepping to RTV the cam cover is super annoying bc of oil drips & lack of space.
If you jack the engine, unbolt the pitch stop under the intercooler first.
Might as well do plugs while you're in there too.
Subie_ is offline   Reply With Quote
