06-26-2002, 02:24 PM | #1 |
Member#: 19816
Differences in Factory STS and Normal Shifter
I'm going to be getting a WRX shortly and i had a question about the shifter options. Is the only difference for the short shifter the actual shifter and/or bushings? is the linkage different at all? i ask this because i plan to get a kartboy shifter and bushings, and i was wondering if i should just get the regular shifter from the factory, or do i need to get the short shifter? thanks for the help in advance.
06-26-2002, 04:04 PM | #2 |
Member#: 12619
Tri-State
Vehicle:02 WRX Wagon #47 SM w/RA gears |
The dealer's STS is a POS and way over priced. It's like a 2% shorter throw! The dealer had two cars one with the STS and I could barely tell the difference. I would just get the normal shifter and get the kartboy. It's probably half the price and sooo much better.
06-26-2002, 04:09 PM | #3 |
Member#: 9548
RMIC
Vehicle:2004 WRX STi 10.154 @139 @ 7,000'DA |
POS?
the sti ss is not a pos in my opinion, and i think many others will agree with me. the throw is just as short as the kartboy, trust me i have had both which is something that most others can't say. the kartboy, at least mine, was very knotchy feeling. the sti is very smooth. i can shift faster with the sti than the kartboy. actually i could shift faster with the stock long throw that the kartboy due to the knotchy binding up shifter.
just my opinion. others?? cnstman |
06-26-2002, 04:25 PM | #4 |
Member#: 12619
Tri-State
The short throw shifter my dealer had was not the STi. It was just a normal STS and was twice the price of a kartboy. I'll assume the STi is even more than that.
06-26-2002, 04:30 PM | #5 |
Techno Sapien
Moderator Member#: 449
MWSOC
Vehicle:2019 Impreza Sport Lithium Red |
The reason the STi is not as notchy or positive shifting feeling is the bushing is much softer than the KB shifters. Mostly you are just paying for the shift lever. The linkage and bushing is the same as OEM. I've felt and had both out. In fact I put KB bushings in an STi shifter this weekend. The throw for the KB and the STS are mostly the same. The only real diff is the STi is stock height and the KB is shorter. You can get the Cobb SS and adjust it the way you like.
Look here for a comparison: http://www.scoobymods.com/forums/sho...?s=&threadid=6 Cobb info here: http://www.scoobymods.com/forums/sho...=&threadid=402 |
06-26-2002, 06:39 PM | #6 |
Member#: 9548
RMIC
i see
well i have the kartboy bushings installed, and that is not the cause of the notchy feeling. according to my mechanic, who has been working on subaru's for 10 years or more, is that the angle that the new shifter, whatever brand it is, buts the linkage in is too steep thus causing the universal joint where the shifter connects to the transmission to bind up. that to me does not sound good. that is why i took out my kartboy and bought the full linkage.
if you look at the attached pictures, look at the gold shaft on the sti vs the stock. you will see a greater bend in it than in the stock black shaft. this allows the pivot point to safely be raised to allow a shorter throw. this is done to correct the angle that i am talking about and allow the u-joint to not bind up. i think the boys at sti do things for a reason. this increased angle will also cause a seal to go out over time, 30-50k miles and will cause an oil leak. to fix the oil leak i guess you have to take the tranny out and replace the housing where that seal is. i am not going to get into an agruement about this statement, just take it for what it is worth. (to some like myself it is worth alot, to others not much) for me it was worth the extra $60 that i spent to get the sti (130 for kartboy, 190 for the sti from group buy on i-club a few months back) cnstman |
06-26-2002, 07:31 PM | #7 |
Member#: 5596
TXIC
Vehicle:2010 Honda Fit Sport Black |
Just want to state it again... The SPT/STi bushing is not the same as the stock ones. It looks the same, but is a tiny bit firmer. Doesn't really affect the argument, though.
-Ray |
06-26-2002, 07:41 PM | #8 |
Techno Sapien
MWSOC
I'm not sure about that myself. The angle of the shifter above the pivot point on the shaft has no bearing on the angle to the u-joint. The distance from the ball to the pivot point does and the distance is basically the same on the KB to the STi, center to center. I've had my KB shifter in for 50K with no problems myself.
The angle in question of binding is at number 35035F point in the pic below. Look at the section. It would have to be lifted up pretty high to begin to bind. Like 4 - 5 inches in fact I think the shaft would contact the car before anything got bound in the joint. Here is a shot of the actual location. Look just above the bushing. The U-joint is there. I can't see how it would be able to bind. This pic is w/ a KB shifter already installed. It's the harder bushing that contributes to the notchy precise shifting feel IMHO. Peaty www.Scoobymods.com Last edited by Peaty; 06-26-2002 at 07:51 PM. |
06-26-2002, 07:43 PM | #9 | |
Techno Sapien
MWSOC
06-26-2002, 07:43 PM | #10 | |
Member#: 67
SCIC
Vehicle:1999 Outlasting the competition. |
Re: i see
[email protected] |
06-26-2002, 10:57 PM | #11 |
Member#: 9548
RMIC
kartboy
i
06-26-2002, 10:58 PM | #12 |
Member#: 9548
RMIC
kartboy
i loved your shifter, until i found out it was POSSIBLY damaging my tranny. if you search under my profile you will see that i gave it good reviews. like i said i am not going to get into an conflict about this. my mechanic who i have the highest respect for told me the above so i switched. no offense to anyone on here, but i take his word over all of yours.
tom tell me then where the notchy feeling comes from, just wondering. i was impressed with the physical qualty of your shifter, however given the information i have, i elected not to use it anymore. cnstman. |
06-26-2002, 11:35 PM | #13 |
Member#: 67
SCIC
i have no grudges against you, i just want to state my side
there are two reasons why/how my shift kit is "notchier" one is the bushings. they are quite a bit harder than the OE ones 75A VS.95A Second if the center piviot is tightened too much and was not greased before instalation it will be very stiff to shift. With the OE setup this is allready done for the end user. it is just a PNP setup. also if the tang on the shifter bushings is installed backwards it will bind and make it REALLY stiff to shift. hope that helps. [email protected] Our shifter dosent kill trannys... 400HP will TRUST ME |
06-27-2002, 08:05 AM | #14 |
Member#: 19816
so you guys are saying that if i plan to get the kartboy shifter and bushings, that i should get a WRX with just the regular shifter because there would be no advantage to getting the factory STS and then putting in a kartboy, correct?
06-27-2002, 09:23 AM | #15 |
Techno Sapien
MWSOC
GT2Sean
Yes, that's what I would do if it were me. Peaty PS: Good luck w/ the new WRX , What colour are you getting Silver I hope |
06-27-2002, 10:22 AM | #16 | |
Member#: 12619
Tri-State
I kept the stock bushings in the car and it's pretty good. I also lubed the ball joint pretty good. There was a ton of grease around the socket already actually. It's not Honda broom-handle-in-bucket-of-grease smooth but who the heck really wants that? |
06-27-2002, 12:39 PM | #17 |
Member#: 19816
silver, black, or blue. i just can't decide.
06-28-2002, 10:29 AM | #18 |
Member#: 12329
TXIC
Vehicle:2o15 WRX Ice Silver |
Meh. I paid the extra money because I wanted something STi.... actually, the car came with it, and I didn't argue. It feels much nicer than stock, that's all I can say, because I haven't played with a Kartboy yet, and probably won't, because I'm not gonna throw out the SS I have just to put in another one especially if the bushings are the only thing that changes the feeling. As for bushings..... I may try the KB ones.
06-29-2002, 01:44 PM | #19 | |
Member#: 13668
07-05-2002, 02:13 AM | #20 |
Member#: 12677
Vehicle:2002 Subaru WRX WR Blue |
My 2c
Kart boy is excellent...notchy but very nice feel....
Personally...I like..... The STI SS + Kartboy bushings + Group N Tranny Mount + Prodrive gear knob + Redline 75w90ns.... |
07-05-2002, 10:45 AM | #21 | |
Member#: 5596
TXIC
Re: My 2c
The STI SS + Kartboy bushings + Group N Tranny Mount + Momo gear knob + Red Line 75w90ns.... And I agree it is just about the best one can get without tearing down the tranny or replacing the clutch. -Ray |
10-13-2002, 08:55 PM | #22 |
Member#: 17712
Vehicle:2002 wrx white |
my take...
oops..posted in wrong thread...moved it to parts review forum..sorry
Similar Threads | ||||
Is there a difference between stock RS and WRX shifter linkage? | jonnysubby | Normally Aspirated Powertrain | 2 | 03-25-2005 01:31 PM |
Difference in STI windshield and WRX? | bikerboy | Interior & Exterior Modification | 1 | 10-08-2004 10:53 AM |
difference in spec c and R/a Spec c? | dlowman | STi Forum Archive | 3 | 04-02-2003 06:46 PM |
Difference in Joe P and Hallman ES | joe_white | Newbies & FAQs | 6 | 10-09-2002 12:08 PM |
differences in engines: manual and automatic | 2.5GT | Normally Aspirated Powertrain | 5 | 11-16-2001 12:04 PM |
