Welcome to the North American Subaru Impreza Owners Club Saturday October 20, 2018
Old 12-28-2007, 04:17 PM   #1
Brock31
Member#: 128115
2008 STi Hatch OBP
enginuity is cool
Default Inspections and "Not Ready" codes
Went to get my car inspected and when the OBDII computer was plugged in, the tech got a bunch of sensor not ready codes. I'm not exactly sure why. It has been a while since I last reflashed and and reset the ECU (disconnected neg. battery cable). I did change the oil last week, but the car has been driven several hundred miles since. Just before x-mas, I pulled a couple of logs and read the current map using Ecuflash. The car was parked for 4 or 5 days and then driven to get inspected today.
Would reading the map with Ecuflash cause the ECU to be put into a "not ready" state?
--Brock
Brock31 is offline   Reply With Quote
Old 12-28-2007, 04:28 PM   #2
Zumble
Member#: 34860
2005 Forester CGM
Are you running anything like a electronic CEL defeat?
Zumble is offline   Reply With Quote
Old 12-28-2007, 06:43 PM   #3
Tea cups
Member#: 103136
With the latest Enginuity/Ecuflash defs you can force all readiness monitors to be immediately ready ("Force Pass Readiness Monitors") for the 16-bit ECU. That is, once enabled and flashed, it will show ready for all tests after turning the ignition on (no drive cycle crap). Of course, this is for testing only and i don't condone using this to pass any emissions tests.
Tea cups is offline   Reply With Quote
Old 12-28-2007, 10:47 PM   #4
Brock31
Member#: 128115
2008 STi Hatch OBP
enginuity is cool
The only "CEL defeats" I'm using are the DTC's through enginuity. I just can't figure out why the codes are reading not ready when I haven't recently reset the ECU.
Tea Cups--when were the latest enginuity defs. released? I'm not sure if I have the newest ones. And if I need to get them, where can I download the defs. since the enginuity site is down?
Old 12-28-2007, 10:49 PM   #5
Brock31
Member#: 128115
2008 STi Hatch OBP
enginuity is cool
Old 12-29-2007, 12:02 AM   #6
WeldingHank
Member#: 98645
2002 WRX Wagon
taking a rom dump (reading the map) resets all the learned values and DTCs/readiness tests. if you don't have the new defs you can get them from a mirror you can find in this sub-forum.
WeldingHank is offline   Reply With Quote
Old 12-29-2007, 03:15 AM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Is the forced-readiness planned for th 32bit ECUs as well?
Old 12-29-2007, 08:46 AM   #8
Tea cups
Member#: 103136
I have idea how to do it for the 32-bit ECU but I haven't messed with it much.
Old 12-29-2007, 03:16 PM   #9
drkramm
Member#: 159156
2007 wrx
wrb
well mess with it damnit ! lol
drkramm is offline   Reply With Quote
Old 12-29-2007, 07:57 PM   #10
Brock31
Member#: 128115
2008 STi Hatch OBP
enginuity is cool
Well, after taking the car on a trip today, I took it back to be inspected and all went fine. I guess the ROM dump did reset the ECU.
I learn something new everyday!
300 miles driven and ECU still "NOT READY" rage557 General Community 6 09-23-2008 11:59 AM
Failed Inspection for monitors "Not Ready" TheMainFrame Service & Maintenance 20 10-26-2007 11:15 PM
o2 Sensor always shows "NOT READY" v8what Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-06-2007 07:25 PM
Blinking CEL and OBD-II "NOT READY" rjp Engine Management & Tuning 4 03-09-2005 12:00 PM
I/M Monitor O2 "Not Ready" for how long? z&cobb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-28-2002 10:32 AM
