Welcome to the North American Subaru Impreza Owners Club Friday November 16, 2018
Old 12-23-2007, 03:25 AM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Can a Single Ping Set off an Avalanche of Knock?
In a WOT pull tonight, I ended up with a scary amount of knock. This is in an area where the timing is stock. Is each knock even real and distinct (meaning the stock map has WAAAY too much timing in this region), or can one knock event set off a whole chain of other knocking if the tune is kind of on the ragged edge? Log below snipped to show relevant time span, don't worry about AFR, I only have the stock AFR sensor so it would have been jumping up and down going "Look at me! Look at me! I'm pegged rich!" for the entire pull.
Code:
Time	RPM	g/rev	Thrt%	FBKC	FLKC	IAT	RelPres
143171	4405	1.16	100	0	0	72	-1.06
143421	4472	1.16	100	0	0	72	-1.05
143671	4536	1.16	100	0	-1.05	72	-1.06
143921	4589	1.17	100	0	-1.05	72	-1.07
144171	4652	1.16	100	0	-1.05	70	-1.07
144421	4692	1.16	100	0	-1.05	70	-1.1
144687	4748	1.16	100	0	-0.7	70	-1.07
144906	4822	1.16	100	-1.05	-0.35	70	-1.08
145156	4885	1.15	100	-1.05	-0.35	70	-1.09
145390	4918	1.15	100	-1.05	-0.35	70	-1.11
145625	4992	1.16	100	-1.05	-0.35	70	-1.11
145859	5049	1.15	100	-1.05	-0.35	70	-1.13
146093	5104	1.16	100	-0.7	-0.35	70	-1.16
146343	5149	1.16	100	-0.7	-0.35	70	-1.14
146578	5192	1.15	100	-0.7	-0.35	70	-1.18
146843	5239	1.16	100	-0.7	-0.35	68	-1.17
147078	5288	1.16	100	-0.35	-0.35	68	-1.17
147312	5353	1.16	100	-0.35	-0.35	68	-1.19
147578	5388	1.16	100	-1.4	-0.35	68	-1.2
147812	5434	1.16	100	-1.4	-0.35	68	-1.21
148062	5503	1.17	100	-1.4	-0.35	68	-1.23
148312	5529	1.16	100	-2.45	-0.35	68	-1.23
148546	5567	1.16	100	-2.45	-0.35	68	-1.27
148781	5612	1.16	100	-2.45	-0.35	68	-1.27
149015	5653	1.16	100	-2.45	-0.35	68	-1.28
149281	5695	1.16	100	-2.45	-0.35	68	-1.29
149531	5752	1.15	100	-2.1	-0.35	68	-1.28
149765	5772	1.16	100	-2.1	-0.35	68	-1.33
150015	5821	1.15	100	-2.1	-0.35	68	-1.31
150265	5875	1.15	100	-2.1	-0.35	68	-1.36
150515	5922	1.14	100	-3.15	-0.35	68	-1.36
150765	5946	1.15	100	-3.15	-0.35	68	-1.32
151000	6000	1.12	100	-3.15	-0.35	68	-1.35
151218	6037	1.13	100	-3.15	-0.35	68	-1.39
151484	6059	1.12	100	-2.8	-0.35	66	-1.39
151734	6092	1.11	100	-2.8	-0.35	66	-1.4
151968	6138	1.09	100	-3.85	-0.35	66	-1.37
152218	6174	1.09	100	-3.85	-0.35	66	-1.41
152468	5978	1.05	100	-3.85	-0.35	66	-1.17
152703	6204	1.02	100	0	-0.35	66	-1.2
152937	6066	0.37	16.86	0	0	66	-8.51
Old 12-23-2007, 04:13 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
No. From what I see.
It knocked once at 4800 rpm, it pulled 1 degree and started to add it back.
Another knock at 5388, 1 more degree of timing pulled on feedback.
Another knock at 5529, 1 more degree on feedback. starts adding it back
Another knock at 5900, 1 more degree pulled on feedback. Again starts adding it
And then one more knock at 6138.
You need to fix your timing at each one of those knock events.
Master2192 is offline   Reply With Quote
Old 12-23-2007, 04:16 AM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
That's how I read it too, but I wanted to confirm. Like I said, this is on the stock timing on 94oct on an RS. It's amazing to me that the factory tune is knocking this badly.
Old 12-23-2007, 04:32 AM   #4
dynamix
Member#: 122603
factory tunes have knock retard all over the place - mine had a lot more than 3.8 degrees.
I would reduce timing through that whole range (assuming fuel is on target) to keep an overall smooth 3d shape. Knocking timing out in whole degrees at individual steps may make it feel jerky when travelling through the range on a WOT run. I would probably start with 0.7 degrees unless it is doing this on every run through.
dynamix is offline   Reply With Quote
Old 12-24-2007, 04:48 PM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
to answer your question (even if it didn't necessarily happen in THIS particular case), yes.
knock tends to have a "hysteresis." in other words, there is a dependency on past events. once knock starts it tends to keep going.
as an example, say you can run 15* of advance with no knock whatsoever. in the quest for "mo powa" you try to dial in another degree. the car knocks and the EMS by some mechanism pulls one degree, which nets 15. the car still knocks. the EMS must dial it back to 14 degrees to STOP the knock. once things are stable the EMS may or may not dial back in some advance. 15 will likely work just fine again (it did before), but if it goes to 16 then it'll be necessary to drop to 14 once again to quell it.
of course if the EMS is operating properly this all happens in the fraction of a second. nevertheless the fact remains that an operating condition that runs without knock may NOT be stable IF knock just occurred.
fwiw
ken
Old 12-24-2007, 05:43 PM   #6
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
OK, that's what I was wondering.
What's the physical process that produces this "hysteresis of knock"?
Old 12-25-2007, 09:24 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
hard to say.
i think it boils down to the instability of the conditions in the chamber after the knock event. a lot of times knock will result in an incompletely burned charge which may leave behind much more reactive compounds than a "clean burn" would have. on the next cycle they blow up, and the process runs away.
Old 12-25-2007, 11:25 AM   #8
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Yeah, the knock control system by default pulls 1 degree but that doesn't mean you weren't less than 1 degree off target. Start from the top and work your way down.
Old 12-26-2007, 03:59 PM   #9
bboy
Member#: 56468
04 Improved STI
Dirty White
Not in this case (log), but knock does cause more knock because of extreme heat during the initial knock event.
bboy is offline   Reply With Quote
Old 12-28-2007, 04:40 PM   #10
benw
Member#: 103320
1998 swapped
Forester L
not to mention that the sharp increase in heat is more likely to create "short term hot spots" on the piston.
An ADI system that constantly re-mapped itself based off the FLKC table would be sweet.
benw is offline   Reply With Quote
Old 12-28-2007, 05:38 PM   #11
Freon
Member#: 88322
2009 BMW 135i
I have seen behavior where fixing a knock even at lower RPM will fix behavior where I see multiple knocks during a pull through a wider RPM range. Say, pulling 2 degrees in the 4400-5000rpm 2.6-3.0 load region where I saw a knock event will avoid the problem where the engine will see a few knock events throughout a pull from 4000-6500rpm even if timing is not touched from 5000-6500rpm.
This would lead one to believe the extra following knock events were caused by the first one, and not by the timing or fueling during the later knock events. I think this is a reasonable conclusion.
:evileyes:
Freon is offline   Reply With Quote
Old 12-28-2007, 05:41 PM   #12
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
/me dons his noob hat
What's ADI?
Old 12-28-2007, 06:16 PM   #13
Freon
Member#: 88322
2009 BMW 135i
Anti-Detonant Injection (secondary water/meth system).
Old 12-29-2007, 12:52 AM   #14
benw
Member#: 103320
1998 swapped
Forester L
What's ADI?
it's a term that Ken (Ride5000) had to beat into people's skulls for a solid 2 months.
An Avalanche of Coincidence SonicWRX Off-Topic 33 11-06-2009 05:52 PM
Picked up an ebay Injen knock-off BrysImpreza Normally Aspirated Powertrain 24 02-25-2005 10:28 AM
dug my friend out of an avalanch/life changing experiances scaryfastskier Off-Topic 34 01-05-2004 12:58 PM
What car can handle 5x100 lug pattern and an offset of +30? SinhCredible Off-Topic 4 10-30-2003 02:59 PM
Is there an STi Injector knock-off redrex3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-06-2002 06:15 PM
