06-02-2017, 08:44 AM | #26 |
Member#: 432497
Vehicle:18 Sti ISM |
pioneer 4200 yes, but if you really want to know, most good aftermarket radios use the same colors.......
06-02-2017, 12:49 PM | #27 |
Member#: 446882
Vehicle:2016 WRX Ice Silver |
08-06-2017, 08:25 PM | #28 |
Member#: 466470
Vehicle:2018 WRX WRB |
how long does it take to boot up when you start the car?
08-06-2017, 08:27 PM | #29 |
Member#: 457782
Vehicle:2016 WRX Limited Ice Silver Metallic |
08-22-2017, 03:44 PM | #30 |
Member#: 416576
can you elaborate on what you mean by the maestro interferes with the cobb access port? Does the AP not work anymore? Can you not plug it in? Sorry new to this.
08-22-2017, 05:18 PM | #31 | |
Member#: 457782
The AP doesn't view gauges anymore. It freaks out and toggles between "trying to connect to car" and "not connected". Once I disable the headunit from trying to read the Maestro the AP works. Or ally again. |
08-22-2017, 05:33 PM | #32 | |
Member#: 463264
E. Canada
Vehicle:2018 WRX sport, 6MT crystal BLACK silica |
I'm glad I followed your advice to go with the half price less expensive SW since I already have an AP always connected |
08-22-2017, 05:39 PM | #33 | |
Member#: 457782
Yeah no problem! SW is the way to go. I played around with the gauges a few days after the initial installation and haven't used it since. |
10-08-2017, 04:31 PM | #34 |
Member#: 468390
South East
Vehicle:1998 Legacy GT Silver |
Cobb Access port
When you say it interferes with it, can you be more specific? I am planning on upgrading my head unit, and running the car. Thanks!
10-09-2017, 11:37 AM | #35 |
Member#: 432497
10-24-2017, 04:09 PM | #36 |
Member#: 412206
Vehicle:2017 WRX Lapis Blue Pearl |
Commenting to bookmark. Lots of good info.
11-24-2017, 12:04 PM | #37 |
Member#: 451646
Vehicle:2017 WRX WRB |
Hey jonizzle, awesome setup you got going on! If I just use my AP to flash tunes and don't use it to monitor gauges or anything it should be fine right? And when you refer to disabling the headunit from trying to read the Maestro is that something easily done through the software? or are you physically unplugging? If the radio was off would the AP work? Thanks!!
11-28-2017, 04:35 PM | #38 |
Member#: 425400
Hey guys, couple of questions (awesome thread BTW): 1. you mention no nav in the unit... but you can still get nav through carplay/android auto correct? 2. If I am not tuning the car, so I need the iDatalink Maestro RR? Seem expensive, but I believe I saw mention of a cheaper alternative? I would (obviously) like to retain the steering wheel controls.
Thanks again-- looking forward to giving my car a deserved audio upgrade. |
11-28-2017, 04:54 PM | #39 |
Member#: 432497
Maestro SW= no data between radio and vehicle, strictly for steering wheel control only
Maestro RR= Full data to radio with compatible radio. Includes gauges on screen, steering wheel control, back up camera wiring, and soon to follow with vehicle info and tpms (will need to get a upcoming t harness to get tpms or vehicle info) Maestro SW is about half the cost of the RR |
11-28-2017, 07:08 PM | #40 |
Member#: 477587
So there is no way to retain a USB in the console?
11-29-2017, 08:51 AM | #41 | |
Member#: 425400
11-29-2017, 09:41 AM | #42 | |
Member#: 432497
The RR is internal, and one wire coming out of it is 6 volt with ACC on, due to some newer radios allowing you to turn the camera on while driving |
12-01-2017, 07:06 AM | #43 | |
Member#: 453411
NESIC
Vehicle:2017 WRX CWP |
I have a 4200NEX incoming and want to know if its worth the wait, or if I should just get the SW (the TPMS feature may push me to the RR). |
12-01-2017, 10:50 AM | #44 | |
Member#: 432497
it will be out really soon, i head to my office in about 9 days and i will have a better idea once im there, i know we released the older subaru version already which is labeled SU1 with the RR but that covers previous generations right now. Ours will be SU2 |
12-12-2017, 12:29 AM | #45 |
Member#: 479085
Vehicle:2015 Forester XT |
That's great news! I have an Alpine HU installed and an RR waiting to go in. If this is the case I'll just hold off for that harness and live without my steering wheel controls for a bit longer.
12-12-2017, 12:07 PM | #46 |
Member#: 478930
Vehicle:2017 WRX |
Thanks! definitely doing this sometime this week.
12-14-2017, 06:23 PM | #47 |
Member#: 418049
So do I have everything here? I also have the micro bypass which is isn't pictured. But I'm confused about a 32 pin connector that I don't think I have.
12-14-2017, 08:15 PM | #48 | |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
If you have one of the 7" OEM HUs, you'll need a separate 5-pin harness to retain your OEM rear camera. I don't know where you heard anything about a 32-pin connector, but none of the recent Subaru models have anything for the HU with that many pins. In any case, you can remove the blue wire from that Metra antenna adapter (your car does not use that pin). You can also remove the short blue loop wire on the 70-1761 (be careful to not damage the longer blue wire that it's crimped onto). |
12-14-2017, 10:54 PM | #49 | |
Member#: 418049
Talking about this harness |
12-15-2017, 08:10 AM | #50 |
Member#: 432497
just an update: i finally got to see our RR harness for the new platform. It needed one little revision and we are looking at possibly early february for availability.
