Welcome to the North American Subaru Impreza Owners Club Tuesday January 16, 2018
Old 08-28-2009, 10:07 AM   #351
KW900
Member#: 220013
2003 WRX
I had ordered a set of 225/40/18s to replace my tires but thanks to you all I just changed the order to 245/40/18s. I hope they fit. Got a set of 225/45/17 Blizzaks too. (winter tires)
KW900 is offline   Reply With Quote
Old 08-28-2009, 03:03 PM   #352
railingsti
Member#: 195656
Originally Posted by crpwrx View Post
Too bad the new bodywork does not match the paint.
??? what are you talking about, the entire car was repainted
railingsti is offline   Reply With Quote
Old 08-28-2009, 03:50 PM   #353
kcook
Member#: 78074
2005 STi
17x9 +42 Rota DPT / 255/40 RE-01R
In action
kcook is offline   Reply With Quote
Old 08-28-2009, 03:51 PM   #354
kaotekxe
Member#: 221884
1992 nissan
talk about meaty
kaotekxe is offline   Reply With Quote
Old 08-28-2009, 03:56 PM   #355
BOOSTi
Member#: 61657
1990 Nismo GTR #103
Championship White
BOOSTi is offline   Reply With Quote
Old 08-28-2009, 06:20 PM   #356
STI_SLC
Member#: 111450
06 WRB_STi
too bad that kit, minus the fenders is just straight horrid.
STI_SLC is offline   Reply With Quote
Old 08-29-2009, 12:02 AM   #357
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Oh it must be the light then, cuz the paint looks diff. colors on the doors.
crpwrx is offline   Reply With Quote
Old 08-29-2009, 01:06 AM   #358
rexxx
Member#: 136172
2008 wrx
egg
hey guys, has anyone throw anything bigger then like a 235 on the 08+ wrx's. im just trying to find some people who have did some wider wheels so i can finalize some wheel choices. im wanting to run 265-35 18s. seems pretty realistic given some what appear to be dullies from the rear theres so much rubber. but would 265s bulge pretty bad on a 8.5? the wheels im planning on are 18x8.5 svns based on design, color and size. i believe there a +48. i dont want to get anything much lower offset and i just dont like the dpts much on the newer body style. im pretty dead set on rotas becasue ive never had any problems from having them as opposed to my ssrs i just sold which loved to bend..anyways im running bc racing coilovers so i have some more inner clearance so i dont wanna go to low on the offset, its easier to add a 3mm spacer to clear inner then pull more on the fender for me, plus i ride pretty low so itll be easier with a higher offset. thanks for any help!
rexxx is offline   Reply With Quote
Old 08-29-2009, 02:10 AM   #359
davidsti1
Member#: 210923
2002 Bug-Attack
15 slow STI
265/35/18 on 18x9.5
davidsti1 is offline   Reply With Quote
Old 08-29-2009, 02:45 AM   #360
railingsti
Member#: 195656
I agree, that's why its in the shop right now getting reworked, it was painted before i got to see it and give my final direcion. It makes my 275 look small, it is the anti agressive. Im curious what everyone will think when it is finished, definaitley more agressive and clean at the same time. A lot of shaving.
Old 09-01-2009, 04:04 PM   #361
Mr_Hox
Member#: 118789
I just went from
six to midnight...
Mr_Hox is offline   Reply With Quote
Old 09-01-2009, 04:48 PM   #362
xfactor78
Member#: 189619
2006 Evo IX MR
Originally Posted by davidsti1 View Post
265/35/18 on 18x9.5
MOAR PICS
xfactor78 is offline   Reply With Quote
Old 09-02-2009, 11:20 PM   #363
davidsti1
Member#: 210923
2002 Bug-Attack
15 slow STI
265/35/18 18x9.5
Old 09-02-2009, 11:46 PM   #364
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
^needs more low and less mexi flush
domestic_abuser is offline   Reply With Quote
Old 09-03-2009, 12:28 AM   #365
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
18x10 et35 305/30/18 Kumho v710
pignoseSTI is offline   Reply With Quote
Old 09-03-2009, 12:30 AM   #366
mAdatee
Member#: 87922
2002 Impreza WRX
Jasper Greeeeeeen
I have 245/40, not posting pics bc I don't quite qualify
mAdatee is offline   Reply With Quote
Old 09-03-2009, 12:51 AM   #367
jt0thevizzle
Member#: 174979
Wowww meeatttty!!!
Sorry to thread jack but just a quick question. Is there a big difference in 235/45/17 and a 245/45/17 on a 17x9 DPT? I saw some pictures of 17x9 on 245 and they don't look meaty at allll.
jt0thevizzle is offline   Reply With Quote
Old 09-03-2009, 01:47 AM   #368
Horse
Member#: 183912
??? What widebody?
Originally Posted by jt0thevizzle View Post
Wowww meeatttty!!!
the sidewall on the 245s will be a bit taller so will its radius, diameter and circumference. but its revs/mile will be less. the 245s will be wider. all this assuming you are comparing the same brand and model of tire. each and every tire is different. some brands make their 235 wider and/or taller than another brand's 245. and using either 235 or 245 wont get you that meaty look, you're asking for a stretched appearance. 255+ on those 9" wide wheels is the way to go.
google the tire calculator and look up the "specs" on those tires sizes on tirerack.
Horse is offline   Reply With Quote
Old 09-03-2009, 01:51 AM   #369
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
What is the widest tire that is safe to put on an 8 in wide rim?
Old 09-03-2009, 01:54 AM   #370
Horse
Member#: 183912
??? What widebody?
depends on the specs of the tire. look up the tirerack specs on the type of tire you plan on getting. the spec sheet will tell you what's the recommended wheel width (labeled rim width range). they're all different so i can't give you a concrete answer
Old 09-03-2009, 01:57 AM   #371
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Thank you.
Old 09-03-2009, 02:03 AM   #372
Horse
Member#: 183912
??? What widebody?
no prob
295/30/18, 18x10
Old 09-03-2009, 02:06 AM   #373
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
More pics please^^
Old 09-03-2009, 02:25 AM   #374
GDB FAN
Member#: 105814
Good god!?!?
+1 for m0aR pics
GDB FAN is offline   Reply With Quote
Old 09-03-2009, 02:45 AM   #375
jt0thevizzle
Member#: 174979
Cool thanks man. I drive an RS so I don't want to go too wide knowing it will be heavier. So should I not go 17x9? I'm only going 17x9 because I want the white DPT and too lazy to paint 17x8s. Suggestions comments welcomed.
Does Anyone Else Have A (small) Problem With the Winter Tire Thread? REX8 Tire & Wheel 8 11-08-2009 12:53 PM
Post you stock height/meaty tire pictures patricksmith04 Member's Car Gallery 18 01-21-2008 02:42 AM
The Rally Tire Thread Rallycarperson Motorsports 45 04-11-2005 08:52 PM
