Welcome to the North American Subaru Impreza Owners Club Tuesday September 25, 2018
Old 02-07-2010, 10:57 AM   #501
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
^^^GC looks good Lowride!
soo many nasty setups in this thread. Ill bump this thread up with a question...
Looking to do some 255 40 17 Star Specs on a 17x8 +48 on a 07 STI. I do like the Meaty tire look with a bit of a buldge. RCE Taramac zero's and camber plates up front, bolts in the rear. Anyone see any issues with this? Im not sure if ill need to pull, maybe a slight roll but the camber should make up for this....yes?
The star specs run at 10.4" at 255-40-17 vs the OEM RE070's at 8.9" at 225-45-17.
anyone have any pics of a 255 on a 17x8? There was a few in here already
Boxer4u is offline   Reply With Quote
Old 02-07-2010, 11:21 AM   #502
wantsti
Member#: 134764
04 sti
java black pearl
Why that big on a 8" rim? It wont handle as good as a smaller tire would. You'll have lots of tire roll.
wantsti is offline   Reply With Quote
Old 02-07-2010, 11:33 AM   #503
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
[/IMG]
This was my old setup. 17x8 +48 with 255/40/17 Nexen N3000 and a 10mm spacer all around. I now have 245/40 on the same wheel as spares which i think fit the wheel much better.
My new setup 17x9 +42 dpt with 5mm spacer in rear. 255/40/17
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
crpwrx is offline   Reply With Quote
Old 02-07-2010, 11:56 AM   #504
grippy monkey
Member#: 131067
your "stance"
sucks
^ meatyflush.. looks good
grippy monkey is offline   Reply With Quote
Old 02-07-2010, 12:08 PM   #505
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Thanks grippy!
Old 02-07-2010, 12:49 PM   #506
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
well i guess ive seen some people do a 255 40 on a 17x8, and while it might buldge a little depending on the tire, i just think it looks sick! I don't think a 245 will be wide enough for me, but at the same time i dont wanna put up the cash for wider rims. Tough spot im in i guess...
a guy on here posted with a 05 STI and some 255 40 azenis on his stock bbs, and it didn't look bad at all
Thanks for the pics CRPWRX
Old 02-07-2010, 01:18 PM   #507
wantsti
Member#: 134764
04 sti
java black pearl
Ya I have 245's on my 7.5 rims and they blow (got them cause they were super cheap). So much float in them. I would stick with the 245's on the 8" they will be big and they will handle alot better then the 255's. Just my opinion. 255/40/17 rim range is 8.5"- 10" Just something to think about.
Old 02-07-2010, 01:30 PM   #508
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Yeah with the 255 on the 8 that i was running it felt soo mushy. The 245 performs so much better and still looks meaty on the 8.
Old 02-07-2010, 02:21 PM   #509
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
alright alright, you guys have persuaded me. Really wanted to try a 255 but I guess ill try the 245's and go up from there with a wider rim. it just doesn't seem that aggressive. Anyway thanks for your input guys
ill post up some pics when its all complete
Old 02-07-2010, 04:47 PM   #510
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
^I was the same way when i got the 255's mounted. 245 is a good choice.
Old 02-10-2010, 02:40 PM   #511
joltdudeuc
Member#: 6119
1999 GM6
RBP
18x9.5 +30
255/35/18
and after I added a 25mm spacer on the front
so the fronts are +5, and still have room to spare...
Eventually I'll have 285/30/18 V710s or Hoosiers. And I'll use like a 5mm or 10mm spacer to push it out.
joltdudeuc is offline   Reply With Quote
Old 02-10-2010, 03:03 PM   #512
boricuajr
Member#: 62842
05 STI\98LGT\97OBS
AW White Grids - RED - WH
i see x
but maybe its because im at work and not at home
boricuajr is offline   Reply With Quote
Old 02-10-2010, 08:47 PM   #513
aesthetect
Member#: 89051
2001 GC6
Originally Posted by boricuajr View Post
i see SEX
fixed
aesthetect is offline   Reply With Quote
Old 02-10-2010, 09:15 PM   #514
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
Do these count?
225/60/16 ContiExtremes on an 04 FXT.
kharris4 is offline   Reply With Quote
Old 02-11-2010, 05:36 PM   #515
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
Originally Posted by cpunlamd View Post
255/40 on the stock BBS 17s have been many times already. There are no issues with it rubbing the strut. Its the rear fenders that will need a slight pull.
even with coilovers and slight camber up to -1.5" ? You mean the fenders need to be rolled or pulled?
Old 02-12-2010, 01:41 AM   #516
joltdudeuc
Member#: 6119
1999 GM6
RBP
Default Re: The Official Meaty Tire Thread
i see x
I can see them. Do you see them now?
Old 02-12-2010, 07:47 PM   #517
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
New wheels 18x10.5 SSRs 295/30/18 tires
pignoseSTI is offline   Reply With Quote
Old 02-12-2010, 07:55 PM   #518
P-iff
Member#: 201568
'05 rotated STi
wrb
no fender mods needed. not even a roll. granted im not slammed i dont see any issues.
as for the people saying 255/40/17 (not 45) are sloppy on 17x8 wheel, i ran these rt615s on tons of autocross days and the sidewalls are still mint. i push the car hard into turns and my suspension isn't the best so it does roll a bit. if the tires were the weak point i think there would be physical evidence.
the one and only pic i have of my car lol
P-iff is offline   Reply With Quote
Old 02-15-2010, 01:21 AM   #519
joltdudeuc
Member#: 6119
1999 GM6
RBP
Can't wait to see them in person!
Old 02-15-2010, 02:59 AM   #520
oly kenji
Member#: 211299
2005 STi
going into 2001 gc
p-iffs..any close up pics? hella tire bubble, or???
and widebody coming for the 295s???
oly kenji is offline   Reply With Quote
Old 02-15-2010, 03:10 AM   #521
aesthetect
Member#: 89051
2001 GC6
Originally Posted by joltdudeuc View Post
18x9.5 +30
255/35/18
dude, please post more pics of this bad boy
Old 02-15-2010, 03:13 AM   #522
adizon
Member#: 55718
02 WRX sedan
Pignose, your meaty tires/wheels would look sweet with some LICmotorsport flares when they come out!
adizon is offline   Reply With Quote
Old 02-17-2010, 01:32 PM   #523
joltdudeuc
Member#: 6119
1999 GM6
RBP
Sure thing. I'll try to find and keep more of the autox photos I find, and post them. Otherwise, I don't have too many other photos in it's recent state.
Old 02-17-2010, 02:14 PM   #524
P-iff
Member#: 201568
'05 rotated STi
wrb
no buldge ill look for pics when i get home, honestly done have many of my own.
what i should do is take pics of the tires now off the car and show of there is no sidewall wear aka signs of massive tire roll
Old 02-17-2010, 02:40 PM   #525
joltdudeuc
Member#: 6119
1999 GM6
RBP
245 RS-2s on 16x8 +48 (Circa 2006)
235/40/17 RA-1s on 17x8 +48 (Circa 2007)
245/40/17 RE-01Rs on 17x8 +48 (Circa 2007)
255/40/17 RT-615s on 17x9 +25 (Circa 2008 and 2009)
255/40/18 RE-11s on 18x9.5 +30
Does Anyone Else Have A (small) Problem With the Winter Tire Thread? REX8 Tire & Wheel 8 11-08-2009 11:53 AM
Post you stock height/meaty tire pictures patricksmith04 Member's Car Gallery 18 01-21-2008 01:42 AM
The Rally Tire Thread Rallycarperson Motorsports 45 04-11-2005 07:52 PM
