05-24-2016, 03:05 AM | #1 |
Member#: 447534
1998 Outback Swap Engine Swap Request
Hey guys, so I have a 1998 Outback with an EJ25. It has really bad rod knock and can't run without being fixed or a swap. I need to know what swaps will be completely plug and play. Doesn't matter if it's an EJ20, EJ22, or EJ25. But regardless, what would just drop in? Thanks for the help guys!
05-26-2016, 11:29 AM | #2 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
'97-99 Legacy 2.5GT, '97-99 Legacy Outback, '98 Impreza 2.5RS and '98 Forester are all the EJ25D. '96 2.5GT was also an EJ25D, but with different heads; it'll still drop into your car just fine.
You might search and/or post in the Normally Aspirated Powertrain forum, as I'm fairly certain I've seen discussions there of this sort of thing. |
06-08-2018, 05:38 PM | #4 |
Member#: 452713
Vehicle:02 Impreza WRX Grey |
would a 00 legacy outback ej25 swap into my 00 impresa obs with a bad ej22? is it just plug and play or what do I need to chnge or swap I got a fuul donor legacy wuth the ej25 also do I need to swap trannys with the motor or will the 25 match with the 22 trans?
06-08-2018, 06:25 PM | #5 |
Member#: 59182
Vehicle:2002 WRX GG>> 2016 Focus RS |
OO,
Plz don't hi-jack an old thread that doesn't apply to your year...and search more as this is covered 'ad infinitum' too. You'll need a dual-port exhaust manifold / header, swap the flexplate if AT...i'd probalby move over the Intake Manifold. too. And if the HG aren't done on the 2.5, you'll be doing them. All EJ-series engines and trans will bolt together....but Phase 1 vs. Phase 2 get in the way of the electronics. |
