Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2019
Old 03-13-2019, 10:04 AM   #126
avidworks
Member#: 144415
That manifold looks sick. Reminds me of a mini version of the one in Riley Stair's Trans Am.
avidworks is offline   Reply With Quote
Old 03-16-2019, 05:30 PM   #127
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Default 2JZ No *****!
Finally have some time to update this.
Well I FINALLY finished welding the manifold. Turned out wild but holy moly was it a lot of work. Now I just need to wait for my second wastegate to arrive then Iíll build the dump tubes. Those will be a neat design too!
Got my intercooler core mounted, and trimmed bumper to fit the new thicker core. Hood is also back on and clears everything nicely.
Head is going to the machine shop Tuesday to get resurfaced, then I will rebuild it with the new springs and cams.
Rear subframe also arrived and I coated my diff at the shop. Iíll be rebuilding it tomorrow and doing a rear end test fit to measure my driveshaft and get that ordered.
Things are finally falling in place but I still have lots to do.
I--RIDE--BIKES is offline   Reply With Quote
Old 03-16-2019, 11:47 PM   #128
TDagen
Member#: 163648
V9 6mt R180 Brembos
Looks mean with the bumper on...
The manifold turned out wild!
The IC core is THICK!
The subframe turned out mint, coating that the same color?
Rear diff looks legit, will look good mounted up.
Head will be ready to rock I see. Man what an update, keep up the good work this is moving along quickly!
Old 03-17-2019, 12:04 AM   #129
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Thank you x6! Haha. Yes the subframe will be going the same dark metallic grey as the diff housing, then lateral links will be the yellow/green.
I have to move quick since my tune and the first show Iím going to is May 3rd!!!! Yikes. Hopefully everything falls into place.
Old 03-17-2019, 11:57 AM   #130
TDagen
Member#: 163648
V9 6mt R180 Brembos
Originally Posted by I--RIDE--BIKES View Post
I have to move quick since my tune and the first show I’m going to is May 3rd!!!! Yikes. Hopefully everything falls into place.
You don’t play games! ****s inspirational man.
Old 04-06-2019, 03:11 PM   #131
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Update time.
Iíve been pretty much working on this thing daily to try to get it running. Got my dual pass rad setup mounted up, which was a big thing on my to-do list. I recessed it in and under my removable chromoly rad support to give as much fan clearance as I can. Still will be snug.
Also got the differential rebuilt finally. That sucked.
I got all my rear end components powder coated now and itís ready for final assembly! Exciting. My Precisin Shaft Tech 3Ē chromo driveshaft with 1350 u-joints will be here Monday as well.
Because Iím not running the u shaped subframe I decided to make a front end brace using 4130 chromo. Turned out super mint.
I also got the head torn apart and resurfaced. Also had to replace one cracked valve guide. I cleaned and lapped all valves/seats and have reinstalled them with GSC stem seals, and Manley spring with Ti retainers. Should pair nicely with my cams.
Now the engine is coming back out to put the head on, final assemble the clutch and do some final tweaks.
I can kind of see the light at the end of the tunnel. Itís faint but itís there. Lol
Now some pics.
Old 04-07-2019, 11:02 AM   #132
TDagen
Member#: 163648
V9 6mt R180 Brembos
Powder coated stuff looks good, really makes that big rear diff look legit.
Old 04-08-2019, 05:17 PM   #133
dev6565
Member#: 424131
2006 WRX Limited
This is an incredible project, keep updating! We're all beyond excited to see the final product.
dev6565 is offline   Reply With Quote
Old 04-11-2019, 05:04 PM   #134
c4lvinnn
Member#: 479833
Looks great Leland!
c4lvinnn is offline   Reply With Quote
Old 05-18-2019, 01:29 PM   #135
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Itís been a while so I figured itís time for an update!
This project is definitely taking a lot of work to do correctly but thatís ok with me. I just need it done before mid July. Hoping to maybe have it fired up in a month or so.
After the last update I got my rear end assembled and installed. It was an absolute battle and not a bolt-in affair. Regardless itís in for good and looks badass! My new Precision Shaft Tech 3Ē chromo 1350 jointed driveshaft fits like a glove too. Really nice piece.
I was sick of having my fuse box hiding behind my bumper so I made a recessed box for it to sit in on the side of the bay. Will be 100% accessible and hidden from site. Turned out great.
After that I repainted my bay once I was finished filling a few more unused openings. Just black.
Then I powder coated a million other things including engine mounts, subframe, sway bars, knuckles etc. Then made custom front stub shafts to finish the RWD conversion.
Installed the front subframe and front suspension. Looks sooooo good! Nice to see it start coming together.
I then did a complete overhaul on my Brembo calipers and shaved the rears to fit a 15Ē wheel when the time comes.
Then I installed my head for good with the arp 625+ head studs and APEXi head gasket, set all the valve lash for the new Kelford T202-d Camís and buttoned up the top end.
I started installing the new triple disk OS Giken clutch then realized I need to align the QuickTime bellhousing so I had to order the indexing plate which will arrive this coming week. Really nice clutch though. Never seen anything like it up close. Curious to see what it feels like.
And that pretty much sums up the last month.
Next on the hit list is:
-final clutch install and then motor/trans go in for good.
-fab wastegate dump tubes
-fab IC pipes and IC endtanks
-fab exhaust (hoping to fit 4Ē)
-install new Tilton clutch master to power the Tilton hydraulic release bearing
-Then wiring!
Better get busy hahah.
Old 05-18-2019, 01:31 PM   #136
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Old 05-18-2019, 01:54 PM   #137
TDagen
Member#: 163648
V9 6mt R180 Brembos
Heck of an update. Keep up the great work!
Now that you have the rear end sorted I would say it’s all downhill from here. Your to do list should fly, and you have some fun fabrication left. The wiring is prob hardest thing left? Then a little motor/clutch install and your near the finish line. Your tearing it up!
Old 05-18-2019, 02:55 PM   #138
willowlee
Member#: 358533
2013 sti sedan
wrb
Wait.... Is that a SUBRA? lol.... Nice build btw. That thing is gonna fly....
willowlee is offline   Reply With Quote
Old 05-18-2019, 10:30 PM   #139
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Now that you have the rear end sorted I would say itís all downhill from here. Your to do list should fly, and you have some fun fabrication left. The wiring is prob hardest thing left? Then a little motor/clutch install and your near the finish line. Your tearing it up!
Thx and I agree that Iím on the downhill now! Yes the wiring will be a beast but hopefully isnít too bad!
Old 05-19-2019, 12:29 AM   #140
WRX_mattb
Member#: 349275
2012 STi
This build is just incredible! Keep up the great work
WRX_mattb is offline   Reply With Quote
Old 05-19-2019, 09:32 PM   #141
elserg93
Member#: 484981
wow! beautiful work. looking forward to final product.
elserg93 is offline   Reply With Quote
Old 06-02-2019, 10:20 AM   #142
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Since the last update Iíve been busy!
Aligned bellhousing to within .00075 parallel, and .0025 concentric, which is WELL within spec. Setup the hydraulic release bearing/clutch then mated it all together for good.
Motor/trans went in beatifully and is now in its final resting place. I spent the last week fabricating the IC endtanks and IC pipes. Tight fit but it all fits very well. First time ever welding endtanks, but Iím pretty pleased with them.
Now to start on the exhaust, a few cooling system things and a bunch of other bits & pieces.
Getting there.
Old 06-02-2019, 10:26 AM   #143
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Amazing work as usual. I'm really excited to see this car completed.
Turpid Porpoise is online now   Reply With Quote
Old 06-02-2019, 11:33 AM   #144
TDagen
Member#: 163648
V9 6mt R180 Brembos
Thumbs up!!!
What the dimensions on that IC core? Went back to look but missed it. Looks beefy!
Old 06-02-2019, 01:42 PM   #145
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Thumbs up!!!
Sheís 4.5x10x28Ē
Old 06-05-2019, 06:53 PM   #146
BLuRRnAWAY
Member#: 500725
This is unreal!
BLuRRnAWAY is offline   Reply With Quote
Old 06-06-2019, 11:28 AM   #147
JDMJNKY
Member#: 253498
05 RSTI
MURK'D
x2 Coming out amazing!!
JDMJNKY is offline   Reply With Quote
Old 06-06-2019, 12:23 PM   #148
SOOTactical
Member#: 502014
2006 9-2x
Arctic Silver
THEY AINT SUPPOSE TO MIX (said in loud redneck voice)
SOOTactical is offline   Reply With Quote
