Welcome to the North American Subaru Impreza Owners Club Tuesday December 18, 2018
Old 08-20-2018, 10:04 PM   #1
Chaudruc
Member#: 490311
2006 WRX STI
World Rally Blue
Default Oversized Valve Guides?
Im rebuilding my heads, and i was looking into valve guides, i understand they come in different bronze materials, but GSC Power Division offers them in +.001 & +.003 option. I am not quite sure the application purposes or what the pros and cons of oversized valve guides would be.
Chaudruc is offline   Reply With Quote
Old 08-21-2018, 09:29 PM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
I honestly don't know enough about oversize valve guides to talk intelligently about the subject. I also know if you don't have the proper tools and knowledge to install them which most people don't, it really doesn't matter to the end user. The shop that rebuilds your head's will replace the valve guides if necessary and size them according. The clearance value is more important for the end user than whether or not it was oversized by .001 or .003
Old 08-21-2018, 10:34 PM   #3
Barney145
Member#: 376219
Sometimes when a guide is removed, some parent material comes with it. In that case, a standard guide would not have enough press fit so oversizes are needed.
Barney145 is offline   Reply With Quote
Old 08-22-2018, 08:45 AM   #4
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
Correct. Oversized guides are on the OD for when a press fit cannot be achieved due to oversized guide bores in the head. As long as there is no damage (when removing the old guides) and you head is in good condition the STD sized guides should work fine.
vwown3d is offline   Reply With Quote
