Welcome to the North American Subaru Impreza Owners Club Monday October 23, 2017
Old 09-06-2017, 11:51 AM   #176
robschilke
Member#: 397553
2014 GR8 DGM
Subaru Ambassador
Since there's a big wildfire happening in Oregon, a lot of the ash is raining down on the rest of the PNW. I live in Seattle, so yesterday I checked to see if my covered parking spot did some work while I was at work. Looks like it did. May take it to a touchless after work today.
robschilke is offline   Reply With Quote
Old 09-07-2017, 03:37 PM   #177
ttgecko
Member#: 139392
2015 WRX LE
Smile
I removed my side AC vents and spray painted them flat black to remove/cover the silver trim and black out the interior. After a few minutes drying time I slid them back in and they look factory. No more reflection off my window tint!
ttgecko is offline   Reply With Quote
Old 09-07-2017, 03:45 PM   #178
ROTORCRAFT230
Member#: 385360
2014 Impreza WRX
Plasma Blue
Taking it off the blocks. Dodged a bullet. Creek cane with in 2 inches of overflowing. Haven't driven it in over 2 weeks.
ROTORCRAFT230 is offline   Reply With Quote
Old 09-09-2017, 03:53 PM   #179
Zombaru
Member#: 280577
2017 WRX Limited
Pure Red
G2 brake calipers paint. In the nick of time too before her first winter.
Currently waiting for the 2 hour cure time to remount the wheels.
Zombaru is offline   Reply With Quote
Old 09-09-2017, 04:48 PM   #180
Zombaru
Member#: 280577
2017 WRX Limited
Pure Red
Wheels reinstalled. I have the winters on right now with the OEM TPMS sensors as I am diagnosing an issue with my cloned ones on the aftermarket wheels I have. So I took this as an opportunity to give my summer wheels a thorough bath and swap these on to see if it's the car's TPMS system or my aftermarket sensors.
Old 09-13-2017, 12:28 PM   #181
cowboydandy
Member#: 474459
2003 Impreza WRX
Installed a few pieces from a GT Spec subframe brace kit.
cowboydandy is offline   Reply With Quote
Old 09-13-2017, 02:12 PM   #182
JasonWeir
Member#: 468269
Did a compression check! 132 across every cylinder, would prefer a higher number but very happy with consistency!
Of late did spark plugs, cleaned up engine bay and changed all fluids in driveline and coolant.
Just more aware of what I have now where it's new to me!
JasonWeir is offline   Reply With Quote
Old 09-22-2017, 11:22 PM   #183
monkeyposeur
Member#: 333468
1993 SS
03 WRB GD 205/22T 20G-XT
Got my JDM V7 STi seats installed today. I imported them from the UK for $350 shipped. They needed a serious cleaning. I think I need to clean them again because the driver's side (now the passenger side, lol) smells a bit like smoke with a hint British of arsehole.
I first attempted to swap the passenger side seat onto my USDM 03 Bugeye base but the V7 STi seat has an aluminum pan that is incompatible with the USDM WRX bases that use some stupid spring setup. Fortunately my buddy is the Subaru seat encyclopedia so we went to the junkyard today and pulled a seat base out of a '98 forester.
The forester seats have the same pan style as the JDM seats so after swapping the JDM seat over to the Forester base it was a perfect fit. I had to use the Forester pan. The JDM seat had an additional cushion brace but it is riveted on and will need to be drilled and bolted on the Forester in order to work but I didn't think it was worth it to deal with that today, maybe another day.
The driver's side required no mods to bolt to the passenger side and now the passenger will have height adjustability. Next I wired three 1 ohm resistors in series for each seat's side airbag connector to get the airbag light to go off.
The JDM seats are super comfy and feel a lot better cornering.
My seats are black, not the usual blue that you most often see on V7 STi seats. Here are some crappy cell phone pics :
There is some residual oxy clean I need to clean out and when I install OEM seat heaters I will paint the adjustment knobs on the JDM seats and swap the black seat trim back on after cutting holes for the knobs.
monkeyposeur is offline   Reply With Quote
Old 09-23-2017, 10:10 PM   #184
the_saintusa
Member#: 171486
2004 WRX STI
Installed the COBB IWG bracket. Not much room to uninstall the IWG actuator, but once removed so much more room
the_saintusa is offline   Reply With Quote
Old 09-26-2017, 07:31 PM   #185
TurboRev
Member#: 463945
I finally replaced by damaged left fog light on my ride. Looking online and I found the OEM replacement at a good deal. I ended up saving about $45.00 less shipping and it came with the factory warranty. I like the way things came out. https://www.subarupartsdeal.com/part...del=&Filter=()
TurboRev is offline   Reply With Quote
Old 09-26-2017, 10:34 PM   #186
tramp
Member#: 459629
2017 WRX base
WR Blue
Used the iPhone through the bluetooth on the radio for the first time to let them know I was stuck in traffic and would be late. Cool.
tramp is offline   Reply With Quote
Old 09-26-2017, 10:46 PM   #187
JRowland
Member#: 454620
2017 WRX
Red
You should have posted that in the old thread lol.
JRowland is offline   Reply With Quote
Old 09-26-2017, 10:53 PM   #188
curlyfat
Member#: 419121
2015 WRX
Replaced the cabin air filter (first time in my life doing that to any car ever, how did I miss that?), and put a MAPerformance map on the AP. Working on headlight plans and tail light plans.
curlyfat is offline   Reply With Quote
Old 09-26-2017, 11:03 PM   #189
91 RS RA
Member#: 457410
1991 Legacy RS RA
Started polishing it. Got the front left panel and rear left panel done. Bonnet is gonna need some time and lovetonight
91 RS RA is offline   Reply With Quote
Old 09-27-2017, 12:24 AM   #190
91 RS RA
Member#: 457410
1991 Legacy RS RA
I have now got free registration till the end of the year!!
The previous owner contacted me to say he got his RS and my plates mixed up and put the registration on my car and hes not worried about paying him back! stoked.
Old 10-03-2017, 12:27 AM   #191
STiNJ
Member#: 286054
2004 *BUILT* STi WRB
MODDED White bugeye-SOLD
Broke the caliper bolt off in the rear Brembo, drilled the bolt a number of time to fit the largest extractor.... Failed at extracting the bolt. Managed to unscrew the bolt by tapping it in circles and discovered the threads had NOT been compromised. Put the new wheels and tires on and gave her a bath.
STiNJ is offline   Reply With Quote
Old 10-03-2017, 06:39 PM   #192
91 RS RA
Member#: 457410
1991 Legacy RS RA
Realized my 2.5 N/A Auto Outback is a bit like me:
Slightly under powered and if you try to make it do something quickly it just makes a lot of noise and doesn't do much.
Old 10-03-2017, 06:46 PM   #193
Markuli
Member#: 473833
2013 WRX Base
Well i planned to do all my brakes and diff/ trans fluid today, and got everything but the fronts done, until i sheared an effin lug stud. I had all my lugnuts torqued to spec, but one would unscrew a little and then not go anymore whatsoever, which was super weird. tried going back and forth with it a dozen times until we sheared it with a breaker bar....
Markuli is offline   Reply With Quote
Old 10-03-2017, 07:04 PM   #194
91 RS RA
Member#: 457410
1991 Legacy RS RA
I hate that, and its always the 'I'll just turn it a little bit mor.... damn it snapped'
Old 10-03-2017, 07:09 PM   #195
SHAKEnBAKE_FO
Member#: 402835
2003 WRX
Filled her up with crap CA 91 and checked the oil.
SHAKEnBAKE_FO is offline   Reply With Quote
Old 10-06-2017, 04:54 AM   #196
brylemr
Member#: 414507
Replaced the engine air filter and adjusted the brakes.
brylemr is offline   Reply With Quote
Old 10-07-2017, 02:32 PM   #197
skyem68
Member#: 475736
Default What engine should I swap with a 2003 2.5rs
Iím looking for my very first car and today on craigslist I found a nice mint 2003 impreza 2.5rs and itís engine is blown. They are selling it for 2500 and I donít know what engine (likely an ej20) I should put into it or what else I need besides the engine (tranny, ecu, anything really)
I know this might be the wrong thread to post on but Iím a new member so it will only let me reply rather than make a new thread.
skyem68 is offline   Reply With Quote
Old 10-21-2017, 06:54 PM   #198
ScoobyDrooler
Member#: 135420
04 WRX "Casper"
Wingless White
Installed ProLightz fog light kit in my 2018 STi
ScoobyDrooler is offline   Reply With Quote
Old Yesterday, 12:41 AM   #199
curlyfat
Member#: 419121
2015 WRX
Put in Morimoto C-Lights with a DRL harness, and blacked out the chrome in the lights. Did the tail-as-turn on the rears, along with LED back-up lights and former turn-signal as additional back-up lights. Turned pretty awesome.
I have to say, though...dismantling these headlights is an insane pain in the ass.
