Welcome to the North American Subaru Impreza Owners Club Sunday September 22, 2019
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 01-15-2014, 04:29 PM   #926
Leafy
Member#: 330625
2006 WRX
Technically the subframe rule is to allow for engine mounting, and its intended for engine swaps but that isnt in the word of the rules. Pretty much how the rule is written is that if your engine mounts to the subframe you can change sub frames.
Leafy is offline   Reply With Quote
Old 01-15-2014, 05:17 PM   #927
willub
Member#: 245695
04 STi
Hey Sig, it says that beatrush subframe only works with the beatrush ALK, which isn't SM legal. Don't know how true that is, just something to look into. Also, the engine doesn't mount to the subframe (or at least the part that you're replacing) so it may be illegal altogether.
I have the same issue with the rust. Im just gonna sand/wire wheel everything and rustoleum it.
willub is offline   Reply With Quote
Old 01-15-2014, 05:31 PM   #928
Leafy
Member#: 330625
2006 WRX
The engine doesnt mount to the subframe? Pretty sure mine does. There is like 3 different frame things down there though. The U frame, the sub frame, and the steering rack cover. I had my U frame out and patched a few rust holes in it near the front.
Old 01-15-2014, 05:54 PM   #929
willub
Member#: 245695
04 STi
Yeah I edited my post to clear that up. That beatrush piece doesn't replace the engine cradle/subframe, where the motor mounts are, unless I'm missing something.
Old 01-15-2014, 07:06 PM   #930
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
At this point, it sounds like finding a stock one is your best bet to not worry.
Also, how are you planning on going national when you're in HI? Just curious if you'd be shipping the car somewhere.
subydude is offline   Reply With Quote
Old 01-15-2014, 08:35 PM   #931
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The "U" frame is the subframe.
The engine mounts to the "crossmember."
I'd just find another stock one. The Beatrush would work you just need spacers to lower the subframe, and of course have to ballast it up to the stock weight somehow... The Whiteline ALK comes with spacers for that reason.
Old 01-15-2014, 09:35 PM   #932
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Actually, according to Subaru the U-brace is just that....a "U-Brace". The Crossmember is what the engine bolts to.
Subframe and Crossmember are synonyms. However, the aftermarket has taken to calling the U-brace a Subframe...incorrectly.
According to the information i got from the national office, replacing the u-brace falls under the chassis stiffening rule, it would be like adding a cross brace. Thus, illegal for SM.
Squidz is offline   Reply With Quote
Old 01-15-2014, 10:09 PM   #933
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
No, Subaru actually calls it a subframe, hence the reason everyone has called it a subframe for the last 13 years...
http://subaruparts.com/parts/2002/SU...agramCallOut=1
Might want to tell Subaru they named the part wrong in all of their parts lists and diagrams.
Good to know on the legality of it though. I wasn't sure since the Beatrush doesn't seem to have any lateral additions or extra cross bracing like most of the others do, it's just a U.
Old 01-15-2014, 10:24 PM   #934
subydude
Member#: 80649
Dusty
Even if you could replace it with an aftermarket you'd be stupid to do so. Either buy the tubing and weld it yourself then ballast to weight, or find one in a junk yard/online. There is no reason to spend $$$ on something like this when the OE piece is just fine.
Old 01-15-2014, 11:06 PM   #935
Leafy
Member#: 330625
2006 WRX
How badly could yours be rusted anyways. You're from hawaii, I'm from a rust belt state and mine has lived life as a winter beater. I had some rust, most of it came off with an angle grinder with a wire cup wheel on it, in a couple spots it wore all the way through and I patched it with some random steel.
Old 01-16-2014, 07:49 PM   #936
Squidz
Member#: 142608
2003 Sonic Yellow
The 2003 parts book i have from when i worked at Subaru of Dallas listed it as a u-brace. But after closer inspection at the top of the page...it is under the heading of subframe.
Sorry, my mistake.
Either way, i agree that there is no reason to upgrade something like this is you are simply going to have to make it the same weight. The whole point of the aftermarket ones is that they are lighter. However...technically it could be legal if it weighed the same and didn't add any extra lateral or cross supports.
Old 01-16-2014, 11:45 PM   #937
sigterm
Member#: 264104
Chapter/Region: HIIC
05 STi
CGM
Yea, I'm guessing a stock one will do fine for now, I came across a friend of mine that was selling one so I figured I'd throw it out there and see if I'd have to undo it later on.
As for shipping out of Hawaii...
Not this year but next yes. Socal region.
sigterm is offline   Reply With Quote
Old 01-16-2014, 11:47 PM   #938
sigterm
Member#: 264104
05 STi
CGM
It's actually a New Jersey car that was transplanted. I'm pretty sure that it's seen it's share of salty winter roads. The rear was absolutely horrible, but I've replaced/grinded/painted all of it over the last year. I'll see if I can snap a pic but take my word for it. "Nasty" and "Terminal Cancer" come to mind when I envision it.
Old 01-17-2014, 07:16 AM   #939
Leafy
Member#: 330625
2006 WRX
Sounds like a chassis swap would make more sense.
Old 01-17-2014, 12:45 PM   #940
sigterm
Member#: 264104
05 STi
CGM
I'm not that bold as much as I'd like to think so.
Old 01-17-2014, 12:47 PM   #941
Leafy
Member#: 330625
2006 WRX
But a chassis swap is easy. You already put all the parts on the current car, so you know how to do it, you just take them all off and put them on a new car. Then take the stock parts from the new car and put them on the old chassis, then sell the old chassis.
Then you get to the feature creep part of, "if I'm gonna go through all the work to chassis swap, I should go to an early 90's impreza L chassis..."
Old 01-17-2014, 01:02 PM   #942
subydude
Member#: 80649
Dusty
Is it bad that I've considered doing that, and I already have what people consider to be the "light swap"
The frame on mine is ok, and I stopped the rust, but there are bits and pieces that could only be fixed by going to an earlier chassis. Maybe if mine proves to be "good" and I have a year or two of rest I'll do it, but until then...just keep on trucking.
Old 01-20-2014, 05:40 PM   #943
Leafy
Member#: 330625
2006 WRX
From the draft of the latest fast track, this is part of a proposed rule addition to the definitions section.
"Subframe/Cross Member – A component welded or bolted to the frame/tub/chassis of a car in order to increase its
strength and which may serve as a platform for mounting suspension or drive train components.
So IMO whatever the **** the subaru documents call it wont matter if this gets added to the rules.
Old 01-27-2014, 02:03 PM   #944
Squidz
Member#: 142608
2003 Sonic Yellow
Doesn't matter what subaru calls it anyway. I already tried the argument that it's not a "subframe" with copies of my parts book for proof.
Lol, they didn't go for it either.
Old 01-27-2014, 04:48 PM   #945
k-dogg
Member#: 115961
2005 Wide STi Wagon
WR BLUE
Have there been any updates regarding fender braces? Are they still illegal to upgrade?
k-dogg is offline   Reply With Quote
Old 01-27-2014, 05:32 PM   #946
subydude
Member#: 80649
Dusty
Still illegal.
Old 01-27-2014, 05:45 PM   #947
Leafy
Member#: 330625
2006 WRX
Still illegal.
No one cares.
If you're not running hoosiers who cares if you have fender braces you wont win anyways.
Old 01-27-2014, 05:52 PM   #948
k-dogg
Member#: 115961
2005 Wide STi Wagon
WR BLUE
Still illegal.
Thought so, but wanted to check as I seem to miss all of the updates.
Old 01-28-2014, 03:15 PM   #949
Squidz
Member#: 142608
2003 Sonic Yellow
No one cares.
That's not exactly true. There have been plenty of championships won on tires other than Hoosiers.
Old 01-28-2014, 03:27 PM   #950
Leafy
Member#: 330625
2006 WRX
Sure, but this year, there's two tires with a shot the A6 or A7 (depending on which one ends up being faster) and the R1S.
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
