Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 04-02-2018, 02:16 AM   #1176
m3n0_wrx
Member#: 465471
2017 Subaru WRX
Crystal White Pearl
Default 2015 WRX Dyno Thread
2017 WRX
Grimmspeed TMIC
Grimmspeed Charge pipe
Grimmspeed EBCS
MA Performance full exhaust system w/ muffler deletes
MA Performance intake
317whp 342wtq on 91
m3n0_wrx is offline   Reply With Quote
Old 04-02-2018, 10:12 PM   #1177
newsubylvr60
Member#: 462306
2016 WRX
Lapis Blue
I'm reading all these posts on tuning the motors and I'm tempted to do same, but does a tuned motor with TGV deletes and EGR blockoff plates pass emissions in Pa. I know they also do an OBD check in addition to dyno checks on the exhaust. It also states they do a visual inspect also. Does anyone have any experience with this from Pa.?
newsubylvr60 is offline   Reply With Quote
Old 04-03-2018, 09:06 PM   #1178
rexblake
Member#: 178426
2010 S4
Gray
In my experience with emissions people, they have no idea what they are looking at. The last car I had tested I had to argue with the manager about what engine was in the car (hint, it was the stock engine).
rexblake is offline   Reply With Quote
Old 04-08-2018, 12:42 PM   #1179
Lapwrx87
Member#: 470405
Got the car tuned this past Friday at Bren tunning.
2017 wrx 16k miles
Tgv deletes
3 port Ebcs
Cobb accessport V3
Protune
Car ended up making 307whp/316wtq
Trying to post the dyno sheet/numbers
Lapwrx87 is offline   Reply With Quote
Old 04-08-2018, 12:57 PM   #1180
Lapwrx87
Member#: 470405
delete
Old 04-08-2018, 07:18 PM   #1181
snake32
Member#: 167338
11 Wrx hatch
Dgm
Originally Posted by wheeliesteve View Post
This is off the Mustang dyno. 362/352 with typical bolt ons and flex fuel on E50 tuned by the master himself Ron Watson!
[IMG][/IMG]
Care to share what break-in procedure you went with or if none at all? seems like that engine it's making more and better powerband, factory freak possibly
snake32 is offline   Reply With Quote
Old 04-08-2018, 11:54 PM   #1182
GlarryHoodDIT
Member#: 460907
2016 WRX
Those numbers aren't really out of line for a full exhaust, Flex fuel, EBCS and whatever else he probably has. Bone stock cars with only FF were making almost 300whp at E50.
GlarryHoodDIT is online now   Reply With Quote
Old 04-09-2018, 12:53 AM   #1183
wheeliesteve
Member#: 455200
2017 WRX
I just did the normal break in on the motor keeping it below 4k rpms until I got over a thousand miles on the motor.
wheeliesteve is offline   Reply With Quote
Old 04-19-2018, 04:11 PM   #1184
IronmanDaremo
Member#: 461956
2017 WRX Premium
2017 WRX Premium, 10k miles
SRS resonated J-pipe
Torque Solution TGV deletes
Torque Solution EGR delete
Grimmspeed 3-port EBCS
Boomba BPV
Cobb AP V3
e-tuned by Clark Turner tuning
Virtual dyno of my latest 3rd gear pull I sent for tweaking. Had to zoom in for the chart because it rocketed up to 41000hp on the plot for some reason at redline. SAE corrected, 279whp/318wtq. Uncorrected it was 290whp/328wtq.
Stock everything else.
(Not sure why the image isn't working).
IronmanDaremo is offline   Reply With Quote
Old 04-19-2018, 10:10 PM   #1185
mp9475
Member#: 477459
2018 WRX
Crystal White Pearl
2018 WRX
TGV Delete
Grimmspeed EBCS
Borla Catback
Bren Protune
293hp/303tq
mp9475 is offline   Reply With Quote
Old 04-22-2018, 10:43 PM   #1186
rain164845y
Member#: 419917
Originally Posted by musubie View Post
2018 WRX
Mods-
Cobb Flex Fuel
DW300C
EGR/TGV deletes
Grimmspeed TMIC and charge pipe
Grimmspeed EBCS
Grimmspeed catted J pipe to Invidia Q300
Boomba BPV
I've been seeing 19.6 max boost.
91 - 284whp/315wtq
e54 - 366whp/352wtq
Dyno tuned by THE Ron Watson of Phatbotti Tuning, Anaheim, CA. There is no substitute.
Do you have exhaust video? I have q300 but don't really want to much more noise.
rain164845y is offline   Reply With Quote
Old 04-28-2018, 03:35 AM   #1187
Tmcoolin
Member#: 477900
2015 WRX Premium
2015 WRX
65,000 miles
Cobb J pipe w/ invidia catback
Cobb sf intake
Egr/tgv deletes
Cobb ebcs
Max boost 19.0 psi
93 Oct. - 273 WHP/ 307 WTQ
EFI Logics, Mustang Dyno
Tmcoolin is offline   Reply With Quote
Old 05-03-2018, 08:32 PM   #1188
DoomAtom
Member#: 458514
2019 STi
2015 WRX:
33,XXX miles (second engine...blew up first one)
TGV / EGR delete
Grimmspeed TMIC / light weight pulley
Catless Cobb Turboback exhaust
Steamspeed 67+ (blew up stock turbo along with first engine)
Stock Intake
228WHP / 243WTQ on 91 octane - max boost 22.5PSI (Dyno Dynamics on winter tires)
DoomAtom is offline   Reply With Quote
Old 05-03-2018, 09:45 PM   #1189
Deathfly7
Member#: 483661
Originally Posted by DoomAtom View Post
2015 WRX:
TGV / EGR delete
Stock Intake
Isn't that lower than stock?
Deathfly7 is offline   Reply With Quote
Old 05-03-2018, 11:21 PM   #1190
DoomAtom
Member#: 458514
2019 STi
When I had the car first tuned on stock turbo and summer tires (with all of the other above listed mods), it made approximately 220WHP on the same exact same dyno that Grimmspeed used to determine their stock FA20DIT as making approximately 160WHP. They acknowledged it read lower than most other Dynos.
After my catastrophe happened, I had my rebuild and tune done at a different shop which also has a low reading dyno (it's a loaded dyno). The tuner advised that winter tires read about 15-20% lower than summer/performance tires on his dyno. I also had it tuned more conservatively since there are a few gas stations where I travel that cater to older vehicles and dont have ethanol mixed in.
Shootout mode showed about 300WHP /330WTQ. I'm confident if I went back to do another pull or two, now that I have my summer set and turned up the "oomph" with 93, it would make quite a bit more.
Old 05-04-2018, 04:39 AM   #1191
ayau
Member#: 332408
I know where you went to for the dyno. I'm also from MN
My E50 15+ WRX made 295 WHP and 365 WHP (shootout mode). I was knocking a little at 5.8k+ RPM. I think I had low ethanol gas.
ayau is online now   Reply With Quote
Old 05-04-2018, 10:54 AM   #1192
DoomAtom
Member#: 458514
2019 STi
Ha! I'm glad you know the full picture then. The engine that blew was an IAG Stage 3 that gave up the ghost on the highway on a -30 degree January morning a few months ago. I had to use Non-Oxy 91 for a fill-up prior to that happening, and it's not confirmed, but it's likely what killed it. My FBK threw -11.XX's and then the back of the car turned into a flamethrower. Turbo and cats blew out as well. IAG examined the engine and alluded to signs of serious knock.
#farmlands
The first time I had it tuned with the stock turbo, the tuner noticed knock occurring at higher RPMs as well.
Old 05-04-2018, 12:09 PM   #1193
DrJibletz
Member#: 429404
2016 WRX
Lapis Blue Pearl
#farmlands
Ugh, that sucks man... sorry about your misfortune.
I really wish we had a better dyno/tuning facility nearby. I will likely be making a trip down to P&L in Illinois so I can get dyno tuned by JR. I don't trust DB Performance's tuner...
DrJibletz is offline   Reply With Quote
Old 05-04-2018, 12:36 PM   #1194
DoomAtom
Member#: 458514
2019 STi
Thanks for the condolences that was a $7000 misfortune as a result of that ***** show
I went with JM Auto and Devin Waitt as the tuner. I felt confident with JM since I was in contact with the owner, Jesse, the entire time my rebuild was being done. They were honest, gave me options, and communicated with me in a timely manner when I requested updates. Gave me that warm and fuzzy feeling I like when I'm "paying to play".
DB was great when I had my previous two Mustang GT / Cobra vehicles! But JM Auto advertises themselves as being Subaru specialists.
Old 05-04-2018, 09:33 PM   #1195
ayau
Member#: 332408
#farmlands
Who tuned the IAG motor? Did the tuner turn down the knock sensor? I would think you would have noticed some small knock prior to the big knock.
Old 05-04-2018, 09:50 PM   #1196
DoomAtom
Member#: 458514
2019 STi
DB Performance tuned the IAG motor. I honestly don't believe they did. I would notice occasional -1.41 / -2.81 FBK occurrences before the event, but nothing drastic enough to cause concern.
It all happened so fast (sounds cliche'). I was driving down the road, keeping out of boost (as best I could) until the engine warmed up, car started popping out the back, I let off the gas, a fireball came out the back, I saw the -11.XX, pulled over, and the car died, and wouldn't restart.
I could have been seen small FBK prior, but I was to focused on the "oh ****" factor and the flame from my blown out cat... sucks being stranded on the side of the road at 6am in -30 degree weather.
Old 05-04-2018, 10:22 PM   #1197
ayau
Member#: 332408
Sorry to hear that. Just reinforces the idea that the type of fuel you use is very important.
What happened to your original motor?
Old 05-04-2018, 10:50 PM   #1198
DoomAtom
Member#: 458514
2019 STi
I absolutely agree. I requested that JM make a "****ty fuel" map since I road trip to Memphis and Texas a few times a year and alot of the stations along the way are 89/91 Non-Oxy. Gives me that piece of mind to have.
The original stock shortblock is sitting in my buddy's garage, wrapped up. The blown IAG block was sent back to IAG to see if I could get some grace since I was 6,000 miles over the warranty miles, but under the 12 months. They helped me out and charged $2400 for new parts and services to get it up and running again. So technically this is my "third" engine...
Old 05-05-2018, 02:43 PM   #1199
YungBoba
Member#: 450808
2017 WRX Premium
WR Blue Pearl
Pardon my ignorance but what is non-oxy gas?
YungBoba is offline   Reply With Quote
Old 05-05-2018, 04:43 PM   #1200
GlarryHoodDIT
Member#: 460907
2016 WRX
I think it means ethanol free. E0 opposed to E10.
