Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 09-23-2015, 01:30 PM   #26
paprocjo
Member#: 387947
2015 OILEATR
Crystal Black Silica
Also on regards to spilling the tuners info...
Just so everyone knows I am hesitant to release the tuner's info since there is at least 2 other theories running around and I don't want this to turn into a bash fest.
Theory 1: Faulty fuel pump which caused the car to run lean.
Theory 2: Boomba was testing a product that caused the car to learn some bad numbers, ecu was never reset and car went straight on the dyno and blew up.
Without anyway to gather some of the data it's all just speculation anyway. The key is to learn as much as we can from an expensive mistake and move on.
paprocjo is offline   Reply With Quote
Old 09-23-2015, 01:32 PM   #27
paprocjo
Member#: 387947
2015 OILEATR
Originally Posted by Stretch18 View Post
Has any aftermarket vendor been working on a HPFP (High pressure fuel pump) replacement? The in-tank fuel pump is a good start, but the cam driven pump is probably a bigger factor once you start going too far beyond OEM output.
E85 is only going to exacerbate that, since you need a higher volume of ethanol, I'd be concerned about that cam driven pump being able to keep up enough pressure.
Note, I'm not saying this with any specific knowledge on the FA20, but all of the DI platforms have dealt with this problem (VW, Mazda, etc.) and I'd be surprised if there aren't higher volume options at least in planning...
I haven't seen anything and I have been watching very closely! I am grateful for your input as I am learning as I go at this point!
Old 09-23-2015, 01:32 PM   #28
Sillo
Member#: 423270
2015 WRX
Subbed
Sillo is offline   Reply With Quote
Old 09-23-2015, 01:34 PM   #29
paprocjo
Member#: 387947
2015 OILEATR
Originally Posted by Silentblack View Post
Sorry to see a nother one bit the dust. I guess I should make a thread about mine sooner or later.
I can't wait to see the build.
That really sucks and I am sorry for your loss. It's a very heartbreaking thing to have to experience financially and emotionally.
Old 09-23-2015, 01:51 PM   #30
paprocjo
Member#: 387947
2015 OILEATR
Old 09-23-2015, 02:00 PM   #31
miyagi
Member#: 162476
2016 WRX Limited
Gahh that sucks man, I'm sorry for your loss. I'm putting mine in the shop Friday to have a DW 65c installed and to get a protune. Videos like that scare the ***** outta me.
miyagi is offline   Reply With Quote
Old 09-23-2015, 02:13 PM   #32
_brian_
Member#: 337626
2015 WRX
Crystal White Pearl
Originally Posted by paprocjo View Post
yep that's straight out of my nightmares
_brian_ is offline   Reply With Quote
Old 09-23-2015, 02:21 PM   #33
jmwoz11
Member#: 387064
2015 WRX GBP
I have to say you seem to be taking this extremely well. It would be helpful to figure out what happened to see what other people need to look out for; this seems like it was a fairly standard stage 2 setup, and it makes me concerned about going stage 2...
jmwoz11 is offline   Reply With Quote
Old 09-23-2015, 02:39 PM   #34
paprocjo
Member#: 387947
2015 OILEATR
Getting pissed off and angry will close doors very quickly so keeping a positive attitude can go along way especially in a messy situation like this.
I though it was pretty standard as well! I am really hoping we can get to the root so others can learn from my mistake(s), I wouldn't wish this upon anyone.
Old 09-23-2015, 02:47 PM   #35
Boggie1688
Member#: 165955
2015 WRX Base
Was that a 4th gear pull?
Boggie1688 is online now   Reply With Quote
Old 09-23-2015, 02:47 PM   #36
Dorian7
Member#: 364950
2016 WRX
CWP
Since you pulled the block was there any noticeable carbon build up on the back of the intake valves yet?
Dorian7 is offline   Reply With Quote
Old 09-23-2015, 02:50 PM   #37
wuuusaa
Member#: 92894
2015 Wrx
Curious why did you go such long oil change intervals? On a turbo car that's way to long, I'm at least every 2,500-3,000 max. Have you considered the IAG or Outfront Motorsports FA motors?
Old 09-23-2015, 02:52 PM   #38
paprocjo
Member#: 387947
2015 OILEATR
3rd gear, first pull
Old 09-23-2015, 02:54 PM   #39
paprocjo
Member#: 387947
2015 OILEATR
I didn't check myself but I will contact P&L and have them take photos. I don't know exactly what would constitute as noticeable but now would be a great time to check. Car did 45 mins of stop and go traffic 5 days a week for a year and half so now is a great time to check! Thanks!!!
Old 09-23-2015, 02:58 PM   #40
miyagi
Member#: 162476
2016 WRX Limited
How long have you been running stage 2?
Old 09-23-2015, 02:59 PM   #41
paprocjo
Member#: 387947
2015 OILEATR
I followed the intervals that the Subaru dealership put inside the car always trying to show up 500 miles early. Car never showed signs of burning oil and I always checked it before I took it in and when it came to see how much they put in and how much I had used.
I did but I am going with P&L because one of the guys that works there has similar mods, and a ton miles on their built block no issues. I also live 6 mins from them so if there are any issues they are just a short tow away and have them fix it. They have a great rep for building subarus and have been around since 2001 so it just makes sense.
Old 09-23-2015, 03:01 PM   #42
paprocjo
Member#: 387947
2015 OILEATR
3 months 2 of which were a revised map with tgvs
Old 09-23-2015, 03:16 PM   #43
That_Boosted_Life
Member#: 422693
2016 WRX Premium
Lapis Blue Pearl
Almost looks like it ran really lean and hot since all the spark plugs have basically melted or broke. That or severe knock on all cylinders.
That_Boosted_Life is online now   Reply With Quote
Old 09-23-2015, 03:20 PM   #44
jasonc32amg
Member#: 36954
2016 Subaru
No intercooler upgrade?
jasonc32amg is offline   Reply With Quote
Old 09-23-2015, 03:23 PM   #45
paprocjo
Member#: 387947
2015 OILEATR
None, although once I have paddle out of **** creek from my soon to be wife, I will be throwing my money at ETS or Killer B for sure!
Old 09-23-2015, 03:41 PM   #46
jasonc32amg
Member#: 36954
2016 Subaru
That could certainly be part of the problem. I really appreciate you sharing your experience.
Old 09-23-2015, 03:58 PM   #47
jhill523
Member#: 427956
Where was this tuned? That deff seems like tuner fault there had to be some sign of issue as Rpms where climbing
jhill523 is offline   Reply With Quote
Old 09-23-2015, 03:59 PM   #48
tav303
Member#: 184982
2016 WRX
CBS
Originally Posted by cnaka View Post
the usual questions:
1) what oil and interval
2) what are your driving habits, do you let the oil come to temp before hitting boost? Do you floor it under 4k rpm?
3) If you have been monitoring knock, what were you normally seeing for FKL and FBK
Is it that bad to floor our cars under 4k rpm? If so why? I don't drive my car hard, but if I'm going to gun it a little it's usually under 4k rpm, that's where we get the most torque, after that it seems to level off.
Just wondering. Thanks.
tav303 is offline   Reply With Quote
Old 09-23-2015, 04:04 PM   #49
thill
Member#: 377200
17 Focus RS
Stealth Grey
I would never floor (WOT) my car in the upper gears (5th/6th especially) under 4K and would just downshift.
I actually like rowing gears so for me it has never been an issue. I don't even recall ever going WOT in 4-6th gear in any car I have owned under 4K rpm.
And holy crap how fast are some of you guys driving if you are WOT in 6th gear well above 4k RPM? That's not a speeding ticket, that is probably prison.
thill is offline   Reply With Quote
Old 09-23-2015, 04:04 PM   #50
NoSoup4U
Member#: 429202
2016 WRX Prem
CWP
Thanks! It sucks but it's the risk that is assumed once the modding beings.
I do, my goal is 400/450 on 93 and 500 on e85 so a new turbo will be in order. I'm literally getting married in a little over a week though and my wife to be has given me the thumbs down on a new turbo kit in the forseeable future although I have other plans in mind
Hahaha, happy wife happy life right? Congratulations on the marriage as well! Maybe she'll come around in time for some Black Friday sales
Will keep an eye out for your inevitable build thread so I can possibly follow suit (minus the blown engine, no offense )
NoSoup4U is offline   Reply With Quote
