Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 04-12-2018, 12:38 PM   #1
noobultimatum
Member#: 431550
2016 WRX
Ice Silver
Default Meth nozzle placement for FA20DIT?
I cannot seem to find any info for FA20DIT meth kit nozzle placement.
Anyone here running WMI on their 2015+ WRX that can share their set up?
Is it by the throttle body? Somewhere by the TGV deletes?
Just looking for info on how others have set it up. Or if you could point me to some youtube videos as well it would be much appreciated.
noobultimatum is offline   Reply With Quote
Old 04-12-2018, 12:43 PM   #2
standardtranny
Member#: 450713
2017 WRX Stage 2
world rally blue
Drill and tap your intake manifold. I've got one for sale if you want an extra to play with
standardtranny is offline   Reply With Quote
Old 04-12-2018, 03:32 PM   #3
tramp
Member#: 459629
2017 WRX base
WR Blue
Kill two birds with one stone. Grimspeed's intercooler has a bung machined into the downstream side of the 'cooler.
tramp is offline   Reply With Quote
Old 04-12-2018, 03:49 PM   #4
anjuna
Member#: 401977
IDFK Wat
bish whet
meh, post IC, pre TB for the performance per dollar
if money is not a price, buy a WELL BALANCED kit that will spray directly down the intake runners (pre TGV). You'll need 4x the nozzles and one-way valves... a well balanced kit, and a lot of plumbing, but hey.
Seriously, just do it in the intercooler outlet like others have said. Mishi used to have a bung there, apparently GS does too. It just makes sense. It may build up SOME spray on the intercooler in this area, but most of the mist will make it through, especially if you have it tuned right.
anjuna is offline   Reply With Quote
Old 04-12-2018, 04:05 PM   #5
noobultimatum
Member#: 431550
2016 WRX
Ice Silver
Oh wow. I recently picked up a grimmspeed TMIC and didn't know that bung was for that!
So then the nozzle would end up near the throttle body.
Old 04-12-2018, 05:49 PM   #6
anjuna
Member#: 401977
IDFK Wat
bish whet
yes.....
Old 04-13-2018, 11:58 PM   #7
nine5raptor
Member#: 473534
15 WRX Prem. w/ HK
CWP
I have a devil's own progressive kit sitting in my garage from my MINI that I sold. Hmmmmm....decisions, decisions.
I've run meth preturbo (not advised) on a DSM and just post intercooler on the MINI. The boxers have short tubing from IC to intake manifold, but just at the exit is a good place for the nozzle.
nine5raptor is offline   Reply With Quote
Old 04-16-2018, 10:58 AM   #8
alapilusa
Member#: 424692
2015 WRX
Anyone have thought on nozzle placement with a FMIC?
alapilusa is offline   Reply With Quote
Old 04-16-2018, 11:46 AM   #9
undyjr
Member#: 459692
2015 WRX
pure red
Disregard the TMIC. Supposedly it's easier to tune with four nozzles. A bit thirsty though.
undyjr is offline   Reply With Quote
Old 04-16-2018, 12:28 PM   #10
alapilusa
Member#: 424692
2015 WRX
Ok cool. I've been following along with your build for a while. Nice to see the manifold nozzles are working well. Wasn't sure if that was enough "time" for the meth mixture to mix with the air before hitting the cylinders. But with all cylinders getting the same amount, probably is the best way; plus probably helps keep the valves cleaner which is one of my main reasons for wanted WMI.
Old 04-16-2018, 03:26 PM   #11
noobultimatum
Member#: 431550
2016 WRX
Ice Silver
oh wow. thats a nice set up undyjr.
Old 04-16-2018, 03:28 PM   #12
noobultimatum
Member#: 431550
2016 WRX
Ice Silver
What size nozzles are you using to spray into all 4 runners? Also, how much more meth does it use up in whatever tank you are running?
Old 04-16-2018, 03:55 PM   #13
undyjr
Member#: 459692
2015 WRX
pure red
https://www.snowperformance.net/category-s/191.htm
TBH, I'm not sure what size they are. I have the Snow Performance 2.5 gallon tank and if I were to guess I go through that tank with a tank of E70.
Old 04-16-2018, 04:25 PM   #14
noobultimatum
Member#: 431550
2016 WRX
Ice Silver
that's not too bad for a 2.5 gallon while running flex. I am planning to stay on pump since I have my turbo upgraded to so cal v3. I also have the grimmspeed tmic that comes with a bung near the throttle body. Im pretty confident i don't or wont run my car as aggressive as you do to justify a 4 nozzle set up on my intake manifold. lol
Old 04-16-2018, 09:18 PM   #15
undyjr
Member#: 459692
2015 WRX
pure red
Good luck on your build.
Old 04-16-2018, 10:46 PM   #16
illuminaugty
Member#: 356294
Any issues drilling and tapping the stock plastic manifold?
Has anyone attempted to use TGV deletes to mount methanol injectors?
illuminaugty is offline   Reply With Quote
Old 04-19-2018, 02:43 PM   #17
anjuna
Member#: 401977
IDFK Wat
bish whet
I did,
It was easier to tune and (with my kit) more even distribution to cylinders injecting pre-TB.
More nozzles = more failure points = potential for one or more cylinders to be running less/no meth.
Old 04-20-2018, 04:55 PM   #18
noobultimatum
Member#: 431550
2016 WRX
Ice Silver
if you don't mind, would you be able to post a pic of your trunk set up? I'm trying to see how different tanks fit into our trunk lay out. The snow performance 2.5 gallon tank is on my list of potential meth tanks for use in the corner recessed area of the trunk.
Old 04-20-2018, 07:03 PM   #19
undyjr
Member#: 459692
2015 WRX
pure red
Old 04-20-2018, 07:31 PM   #20
noobultimatum
Member#: 431550
2016 WRX
Ice Silver
Perfect! this is what i was visualizing.
Do you still use the trunk cover/carpet? Are you using a low level sensor as well?
Old 04-20-2018, 07:34 PM   #21
undyjr
Member#: 459692
2015 WRX
pure red
There's a low level sensor in the tank.
