10-19-2001, 04:23 AM | #26 |
Member#: 7677
Vehicle:2005 WRX Blue |
10-22-2001, 12:40 AM | #27 |
Member#: 10405
Vehicle:2002 WRX Sport Wagon Midnight Black Pearl |
Has anyone done the Hoodscoop screen?
I was wondering if it impeded airflow and whether putting the on the intercooler instead was a better idea? I just got a stone through my hoodscoop and dented a few vanes while I was playing in the mountains this weekend so this mod's high on my list and I'm wondering which way would be better. Thanks Derek |
10-22-2001, 08:36 AM | #28 | |
Member#: 9531
Vehicle:2002 WRX Sport Wagon Aspen White |
Good luck to you with either that you choose to do. |
10-28-2001, 01:14 AM | #29 | |
Member#: 10145
Vehicle:2002 Impreza WRX Midnight Black |
11-03-2001, 07:14 AM | #30 |
Member#: 10007
Vehicle:02 Impreza WRX |
TT
wrx182,
for clarification can you state the TT you are using and what the blue and brown wires from the TT are that goes to the ECU? Which pins on the ecu? jasonmolinari, The Green/black wire goes to both the alarm/keyless module and the Green/Red wire goes to the integrated module(not sure what it is). These two wires carry the IGN signal from the key switch. By cutting these two wires, the alarm/keyless system always thinks the car is off. So I think you can arm the alarm at any time. I'm in the process of installing my TT. -initial Last edited by initialx; 11-03-2001 at 09:30 PM. |
11-03-2001, 01:39 PM | #31 |
Member#: 9531
first off, no, the car will not arm at anytime, i've tested this - it acts the same as it did before cutting those two wires.
secondly, i'm have the HKS Type-1 TT. The blue and brown wires that run to the ECU are for the speed sensor and the RPM. Check the mods section on my site (www.angelfire.com/ego/wrx182) - it has a pinout of the ECU, just track down the pin that you need and splice it, there's so many wires, I can't remember exactly which one, but all you need is the pinout. Good luck. |
11-03-2001, 09:28 PM | #32 |
Member#: 10007
wrx182,
14) On the security system module (located on the drivers side of the parking brake) find the gray wire and cut that, taping both ends. I believe it is also a green/black wire. I'm not sure what signal the grey wire is? Green/black wire also goes to the Security unit on the passenger side as the Green/black wire that goes to the Keyless entry unit on the driver side about the fuse box. Now I can arm the alarm when the car is running. I just can't locate the pink wire for the ebrake???? -initial |
11-03-2001, 09:32 PM | #33 |
Member#: 9531
ya..hehehah....that was a tricky one for me too - i was just looking in the wrong spot.
what you want to do, when you take off the center console, all you can are 3 wires running up to that little metal thingy in front of the brake. ok. on the pasenger side, pull back the carpeting a little bit, even with where the base of the brake handle meets the console. off to the side, you'll see a little sensor thingy with the pink wire running off of it. good luck. |
11-04-2001, 04:15 PM | #35 |
Member#: 10007
wrx182,
thanks--found it and got it hooked up. Had to take the whole center piece out to find it. -initial |
11-07-2001, 11:55 AM | #36 |
Member#: 11684
Vehicle:86 Porsche 944 Red |
thanks for all the info., i found it very useful, but i have a question about the last steps of the job
5) Cut this wire and tape the end coming from the dash. 6) Solder the piece of wire spliced to the orange wire with this new end and tape it up. tape the end coming from where in the dash? i.e. put a pigtail clip on it? does this wire go to the foglight switch? which 'new end' are you refering to? if you could help clarify the origins of either end of the wire you are refering to, i'd appreciate it. Brian |
11-07-2001, 03:07 PM | #37 | |
Member#: 9531
Brian, Locate the red w/ green stripe wire on the 4th relay down from the top. Once you find this wire, cut it - leaving a an inch or two coming from the relay. Now that you cut it, you will connect (solder, twist, wire nut, etc.) the orange wire the the inch or two stub that is still coming from relay box. Of the wire that you cut, the end that is no longer in use - just put some electrical tape over the end just for security and tuck it away under the dash or something. Hope that helps. If there is anything else you need, feel free to let me know. Jim |
11-12-2001, 12:42 PM | #38 |
Member#: 7702
Vehicle:2002 WRXsilverWagon v7 sti-ra drivetrain |
is the fuse box in the engine compartment the same as the fuse pnl. you are talking about in step 12 ? please let me know where the fuse panel is tring to get my alarm to work while my timer is on
also the grey wire is inside the center console? thanks for the help |
11-12-2001, 04:29 PM | #39 | |
Member#: 9531
The fuse panel we are talking about is inside the cabin. On the driver's side, remove the large plastic dash piece under the steering wheel and you will see the fuse panel on your left side. Any other questions, feel free to contact me or just reply here. Jim. |
11-19-2001, 09:32 AM | #40 |
Member#: 4402
NESIC
by the way the fan comes on on defrost and A/C on is because the A/C runs always on defrost (it speeds up defogging....) I think though that the A/C will not kick in below 35-40 degrees...
Cheers T. |
11-19-2001, 09:16 PM | #41 | |
Member#: 5670
yep
also, i think that if the mode is set to Feet/Defrost, the A/C does NOT come on... Kind of nice, since you don't always need the A/C compressor running to keep the windows clear... Mike Quote:
11-22-2001, 12:12 PM | #42 |
Member#: 7962
Vehicle:08 335i TwinTurbo PSM 02WRX, 97 Dipped CRV |
Turbo timer
It should be noted that the HKS turbo timer harness is the same as the WRX
I bought the connector for my Apexi turbo timer and used the HKS harness to plug it in. It took about 3 minutes to install.!!!! |
11-25-2001, 09:30 PM | #43 |
Member#: 7792
Vehicle:2002 Prodrive widebody Cosworth 2.5 6sp |
Just one question, for the foglight mod, will the fogs run even if all other lights are off?
11-25-2001, 09:52 PM | #44 | |
Member#: 9531
11-26-2001, 04:28 PM | #45 |
Member#: 10780
SCIC
Vehicle:---- BRZ Galaxy Blue Silica |
LOL wrx182, I used yer site to do the silencer removal awhile back and didn't even realize it when I met you this past weekend... Thanks man
sherif |
11-26-2001, 08:59 PM | #46 | |
Member#: 9531
11-28-2001, 02:00 PM | #47 | |
Forever Scooby Newbie
Member#: 11172
Vehicle:2000 GC8 RS Coupe' FlatBlack&BlueRidge Pearl |
11-28-2001, 04:06 PM | #48 | |
Member#: 8883
Vehicle:2002 WRX Blue |
12-01-2001, 07:28 PM | #49 |
Member#: 11657
SCIC
Vehicle:2002 Impreza WRX Aspen White |
First off, WRX182, thanx for the awesome instructions. I removed my DRL module as you advertised. Second, I pulled my dash apart to look into the foglight mod.
I hope I'm not beating a dead horse here, but with the foglight mod, it is my understanding that I can run the foglights with just the parking lights on. I can also run them with the high beams on. Is this correct? And secondly, there is some confusion on my part about the status of the green light on the foglight switch. Does this only come on when it is running the "stock" combination (i.e low beams and foglights), and does not come on with the parking light/foglight or high-beam/foglight combination? Again, I appologize for re-hashing this one again. It's just that in my searches, it is never really clear as to the status of the green light on the switch. Before I cut into the stock loom, I'd like to find this out. Thanx for your time. |
12-02-2001, 08:46 AM | #50 | ||
Member#: 9531
Check out my site for a ton more mods / installs. Good luck & take care, Jim www.angelfire.com/ego/wrx182 |
2005 Sti Tranny Swap into 05 Wrx---Posted this in the Tranny Section too | Needsacar | General Community | 2 | 11-10-2009 01:39 AM |
Wonder if I can put this in the car before the next dyno day? | wcbjr | Texas Impreza Club Forum -- TXIC | 7 | 01-02-2003 02:39 AM |
For all those who ran in the Biltmore Sq. Autocross | deadbolt | South East Region Forum | 4 | 05-05-2002 07:45 AM |
EVERYONE please read ALL. Lets Put this South East Subaru club together already! | Turk | South East Region Forum | 41 | 08-17-2001 10:36 AM |
Update in the mods section?Rear spats | jagcars26 | Interior & Exterior Modification | 2 | 05-12-2001 06:04 AM |
