01-26-2003, 10:45 PM | #1 |
Member#: 30710
Vehicle:04 STI |
Want to get an update on the TXS Stage 4 guys..
how is your car doing ? :-)
did you changed your Unichip to a UTEC ? How was it ? and Is your car a daily driver ? and how is the clutch / transmission holding up ? I'm asking this since Stage 4 is very interesting, But I'm afraid the stock clutch won't live very long, under normal driving of course. then, I'll have 2 choices, 1- change it for a better one. hello transmission problem. or 2- simply replace it,..every now and then. Thanks Sam
01-26-2003, 10:47 PM | #2 | |
Visiting NASIOC Timeout
Member#: 25223
Vehicle:2003 Black EVO aka Shannon |
Re: Want to get an update on the TXS Stage 4 guys..
01-26-2003, 11:02 PM | #3 | |
Member#: 3574
NESIC
Vehicle:2002 WRX Blase' Yellow----R.I.P. |
Re: Re: Want to get an update on the TXS Stage 4 guys..
Bill |
01-26-2003, 11:22 PM | #4 |
Member#: 10842
Vehicle:07 2.5i Wagon Black |
Your transmission and clutch should hold up fine (mine has)....if you don't abuse it. I had my TXS stage 4 for about 6,000 miles and everything went dandy! Drivability was perfect.
01-26-2003, 11:28 PM | #5 |
Member#: 31350
Vehicle:2002 WRX Blue |
ditto with s-1
01-27-2003, 12:33 AM | #6 |
Member#: 30710
Vehicle:04 STI |
oops..typo
thanks for the info ! |
01-27-2003, 07:53 AM | #7 |
Member#: 10921
Vehicle:04 04 STi 12.8 @ 105 mph |
Stage 4, 15k miles on my WRX.
Car runs great. Its my daily driver/weekend drag racer. 12.7 @ 108.6 mph I have over 100+ runs down the track. Still on the stock clutch and tranny. By the way I use an off the shelf Stage 4 Unichip with race pipe, and XS TMIC. |
01-27-2003, 09:34 AM | #8 |
Member#: 15194
Vehicle:2004 Lightning, 2001 BMW 330ci |
I have had TXS Stg4 for 4-5k miles so far and everything has been good. The transmission holds up fine.
The difference will be how well the car is maintained and driven. This car is my daily driver for now. I am using a UniChip but switching over to Link. |
01-27-2003, 10:32 AM | #9 |
Member#: 25194
RMIC
Vehicle:2008 Forester XT 5mt Dark Gray |
I have I guess what you would call a stage IV +.
Utec TXS TMIC Walboro pump Turbo back Then my + stage parts PE 650 injectors PE 1820 turbo Perrin fuel rails with -6AN fitings through out Canton Meca fuel filter SX FPR GT Spec Headers with up pipe and some other odds and ends here and there Car holds up great. I use it as the daily driver, car has 5500 miles on it, 4K when everything installed. Runs around on 290 whp every day. If I ever get a hold of C16 then 340 whp. Car never skips a beat. Runs great. Had dyno tuned by Phil and Nathan. 2 thumbs up. As for Uni vs. Utec, make the switch. You will be very satisfied. Your 1/4 mile times will make a hefty jump, based off of others results. |
01-27-2003, 11:16 AM | #10 |
Member#: 24852
Vehicle:2003 WRX Black |
Stage IV w/ VF34 here. I do a lot of commuting (10k miles on my '03) I sit a lot in Chicago traffic and I've never had a problem. Under normal driving, the car drives just like stock. If you don't beat the hell out of it, the car should hold up fine. Just watch the 1-2 shifts, don't powershift or you'll snap 2nd like a few people did.
01-28-2003, 05:00 AM | #11 |
Member#: 9008
Vehicle:2002 slvr wrx sedan 07 CBR 600RR |
A OK here!
01-28-2003, 09:31 AM | #12 |
Member#: 7468
Vehicle:2008 Outback very limited |
I have had my stage IV + for over 25,000 plus and no worries. Dug E Fresh and I just did another compression check and all cylinders check out 150 plus and a +or- of 2, so all cylinders are pretty close. My car has 45,325 miles I have used stage1,2,4+ since 4,000 miles. I now use the Utec and run only 100 octane sunoco.( i don't drive my car to work anymore too many miles.) I have run a 12.86 @ 108.28 with a 1.98 0-60 ft ( don't ask me about launch techniques ) I have replaced the tranny once so far, do not bang gears and you will be fine. Thanks Michael
01-28-2003, 10:31 AM | #13 |
Member#: 30710
Vehicle:04 STI |
how much did it cost you to replace your tranny ?
Sam |
01-28-2003, 11:20 AM | #14 |
Member#: 8785
SWIC
Vehicle:02 c_turner@ix. netcom.com |
I have stage 4 plus:
Pe1820 PE210 pump vishnu rails Dual feed FPR STI IC Zero sports intake pipe Prova duct BPM GT Perrin upipe PWR radiator Canton mecca Oil filter. ect...ect..ect... Oh and a 50-70 shot of nitrous depending on how I jet it. The car has had a big turbo on it (vf22 or larger) since about 5k miles. Drag raced over 100 passes. Including 4 or 5 road races. The car has 28,000 on it now and I Just drove it into work this morning. Stock clutch and stock trans. Best pass is 11.82@ 117mph on the bottle and 12.2 off. I switched from a unichop to a Utec. Difference is night and day. Single best thing I have done to the car. The utec made the car enjoyable again. The car was running 12.6's @ 109 mph with the unichip. I tossed in the utec and did some tuning. 12.2 @ 112.5 mph. A remarkable difference in power. Probably 40-50hp on my setup. Since the utec I have not used the nitrous because I am afraid to. The car is running so strong I dont want to mess up a good thing.. Stock clutches are great. My stock clutch has been a real trooper. The only time it really slips is running Race gas big boost and big nitrous shot. Probably around 450-475 crank hp. Even then it just smells a bit. At 28k its tattered and the pedal is stiff from the disk being thin. If your stock clutch toasts with stage 4 you where probably the leading cause of the failure. Clutches are $400-$600 bucks. Figure $400 to install it. Oh and dont let the stories of broken trannies scare you away from this kind of power. As many have said before its all in how you drive the car. Plus, Trannies are $1200 bucks. If you mess up and break it just "thow it in the gutta and go buy anotha" CT |
01-28-2003, 01:58 PM | #15 |
Member#: 7468
I got mine under warranty. The service manager was very understanding and I caught him on the right day !!! I was very lucky. Thanks Michael
01-28-2003, 05:54 PM | #16 |
Member#: 14456
Vehicle:09 BMW 335i Sedan 69/72/01 Corvettes |
Mine is a daily driver. Had Stage 4 since last April (Stage 1 and 2 before that).
Switched to the UTEC in early October. It is 100% better, more power, very consistent and when it is cold the car will actually start on the first try. The knock protection and light is great too. Since switching to the UTEC I have felt the clutch slip a little under WOT acelleration but I expected that based on a discussion with Phil. If the clutch ever goes out I will just replace it with another stock one. Though I have not had any high EGT or det problems I will be putting on a set of Perrin fuel rails and possibly a differnt IC (TXS top or APS D/R 500 front) this spring just for safety. Troy |
An update on the Forester | Bartop | Member's Car Gallery | 39 | 05-11-2007 11:35 AM |
Any updates on the TXS wideband's release date?? | eightballrj | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 10-28-2003 10:59 PM |
Request for help - I screwed up on my TXS Stage 4 install | fragment | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 02-05-2003 08:01 PM |
('93-'01) Want to get an RS | Homie6915 | Impreza Forum | 12 | 05-09-2002 11:36 PM |
