Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
Old 01-04-2013, 02:20 PM   #1
blue sedan
Member#: 311622
2010 WRX
Default Intercooler gaskets
Can the rubber bpv gasket and rubber IC to turbo gasket be reused?
The car is a 2010 WRX with 17k miles.I'm taking the intercooler off to replace OEM pitch stop.
blue sedan is offline   Reply With Quote
Old 01-04-2013, 05:56 PM   #2
rdieder
Member#: 257818
2007 STi
CGM
Sure as long as its not ripped, dab some rtv sealer on there too.
rdieder is offline   Reply With Quote
Old 01-04-2013, 06:09 PM   #3
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Reuse the gaskets / o-ring type seals unless ripped. Do not use any sealants - that's what the gaskets / o-ring type seals are for.
What happens the next time you want to do some work and used sealant?
Old 01-04-2013, 08:05 PM   #4
meebs
Member#: 3251
2009 WRX Hatch
To reiterate, do NOT use sealant. Just make sure they are in good shape and that you have them set right if they pop out. There is a notch and a tab that acts as a key.
meebs is offline   Reply With Quote
Old 01-04-2013, 08:14 PM   #5
blue sedan
Member#: 311622
2010 WRX
Thanks! I don't want any problems with install.I'm putting in a Perrin pitch stop and replacing IC to Throttle Body hose with AVO.Much Appreciated!
