Welcome to the North American Subaru Impreza Owners Club Saturday September 21, 2019
Old 05-17-2019, 09:08 PM   #1
maxthegrear105
Member#: 496126
Default 2019 WRX hail damage
So yesterday there was a relatively big storm and there was 1/2 inch diameter hail that pored down for around 5 minutes. I counted 16 dents that are visible and there's others that I can see but are small, so I have 2 questions.
1. Does Subaru have thin metal on their body panels because the 2 other cars I had didn't get near the damage
2. How should I deal with this issue, should I repair it myself or have it done by a body shop?
maxthegrear105 is offline   Reply With Quote
Old 05-18-2019, 08:09 AM   #2
soloz2
Member#: 260128
2019 WRX Limited
Lapis Blue Pearl
Hail damage is very finicky. Growing up in areas where we got frequent hail, I saw varying degrees of damage on cars parked next to each other, even on dealers lots, of cars that came off the same assembly line.
This is what insurance is for. Pay your deduct and have a repituble body shop fix the damage. Paintless dent repair can be pretty good.
soloz2 is offline   Reply With Quote
Old 05-18-2019, 12:33 PM   #3
n2oiroc
Member#: 141952
18 golf arrrr!
Yes, fix it yourself. Take a ball peen hammer and hit from the inside out where you think the dents are.
n2oiroc is offline   Reply With Quote
Old 05-18-2019, 03:53 PM   #4
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Depends on how much it's going to be.
Take it to a bodyshop or PDR place and get an estimate. If it's gonna be higher than your comprehensive deductible, I would go though insurance.
jasonwrx86 is offline   Reply With Quote
Old 05-19-2019, 05:17 PM   #5
0wl
Member#: 501801
I would try what n2oiroc said first. If at that point it isn't fixed up to your liking you can always take it to a shop. Plus you'll at least learn something.
0wl is offline   Reply With Quote
Old 05-20-2019, 09:19 PM   #6
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
Yeah, Subaru metal is pretty soft in areas that are steel.
Being a trained PDR tech myself, I suggest you take it into your bodyshop who knows what they are doing. The more misc dents you add into the dent, the more difficult it will be for the PDR tech to repair. You also need to remember that metal stretches. If you stretch the metal, it will never be repairable completely even by the best tech. 99% of the time, the untrained eye do not know where to push (or pull), where to knock down.
GL.
oichan is offline   Reply With Quote
Old 05-22-2019, 11:34 AM   #7
vica153
Member#: 76586
2006 9-2x Aero
GL.
+1, If you have to go on a forum to ask about it, then you're going to do more harm than good hitting your car with a hammer.
I would have assumed N2oiroc was being sarcastic because thats a really bad idea. Your own shiny new car isn't the place to try to learn to do body work.
vica153 is offline   Reply With Quote
Old 05-22-2019, 11:39 PM   #8
Jeff Kaufman
Member#: 501941
2019 Outback
Metallic red
That's a bummer about your dents from the sky. I have to say, the metal on my '19 Outback seems to be pretty thin compared to other cars I've owned. Enough so that the hood flaps around right at the base of the windshield starting at about 60 mph.
Jeff Kaufman is offline   Reply With Quote
Old 05-23-2019, 07:31 PM   #9
R15
Member#: 409971
2018 WRX
Light body panels are (part of) how Subaru hits its fleet fuel economy goals. Compare the weight of the hood or roof of your car to anything on the market under 100k, bet it will be lighter. I know a guy that put a cheap carbon fiber hood on his 16 WRX, it actually weighs more than the stock hood.
R15 is offline   Reply With Quote
Old 05-24-2019, 05:19 PM   #10
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
That's true. The hood is made out of aluminum which is very difficult to PDR vs steel. Subaru went cheap by using thin steel vs aluminum to reduce weight which result in flimsy panels that are easy to dent.
One can easily dent the door panel just by pushing at it hard enough with their finger. Different story if aluminum.
Old 06-16-2019, 10:30 PM   #11
maxthegrear105
Member#: 496126
thanks for the input, I ended up getting it done by a guy who does dent repair on the side and he did a great job. this wouldn't have been my first rodeo with body repair but I wasn't to worried the first time because my first repair was on a Porsche 944 that I beat.
Old 07-06-2019, 09:24 PM   #12
bgdbrz
Member#: 503507
I've been looking to try this on a few kind of large dents on the doors of my BRZ. Rather try and fix it for free before taking it to a shop.
bgdbrz is offline   Reply With Quote
Old 07-10-2019, 01:57 PM   #13
2011SubieWRX88
Member#: 504102
I used a plunger on my previous car (e36 bmw) on the hood to remove a golf-ball sized dent and it worked - maybe worth a shot.
2011SubieWRX88 is offline   Reply With Quote
Old 07-13-2019, 04:37 PM   #14
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
Those were steel hoods. VA hoods are aluminum and plungers will not work.
Get it done right the first time using a PDR professional.
