01-06-2015, 07:13 PM | #1 | ||||
Member#: 401977
TXIC
Vehicle:IDFK Wat bish whet |
If you have a question, look here first!!!
I have seen a TON of repeated questions on this forum, so I am going to try and sum up all the information in one place just for some sanity.
First - LIKZ OMG WHERE IS TEH BOOST? Answer: It's cold. You run less boost. Nothing is wrong. Let's have this conversation again when it's summer. Taken from the Cobb Tuning Guide... Quote:
Second - BUT BRO, BROTELLA T6 IS TEH BEST I RUN IT IN MY EJ. Or 0W40 FTW BRO! Answer - Yep. We all get that there has been tons of success in running the EJ with T6. Don't do it to the FA20. Run conforming 5w30 oil, as called out in the manual. There's no need to get fancy at this time. There have been only a few reported incidents of spun bearings and T6 was linked to each story. Additionally, I had personal experience with T6 making my AVCS go crazy. This information will change as we gather more information about the little infant engines. If you'd like, there is an oil analysis thread over in service and maintenance just for 2015s. For the love of all things good in this world, please don't make another oil debate thread. Just don't. It's already been discussed on several subforums. Go there. No, your particular type of oil, weather, or driver doesn't make you exempt to searching and participating in threads already created. Third - YEAH BUT BRO INTAKES ARE AWESOME AND MAKE ALL THE DIFFERENCE IN THE WHOOOOOSHHHH. Answer - Yeah, they sure do sound different. However the concensus is and has been that unless you're pushing 400+whp, there is no need for an intake. Additionally, if the intake changes the MAF housing design, MAF scaling will NEED to take place to correctly meter air. This can only be accomplished with a tune either designed for the intake (Cobb has a Mishi OTS map) or a protune. Fourth - SOMETIMES I GET 22.X PSI PEAK BOOST SHOW UP? IS IT BROKEN? Answer - No, the OEM tune has an infinitely debatable boost control system. Most people say that this is a built in "feature" and others say it's not a big issue. Some cry hose clamps (there's even a sticky at the top of this subforum). Most tuners can tune it out, but it was still pretty much always there for me through my journeys. After changing to a 3-port interrupt style EBCS, I have rock solid boost that NEVER exceeds my target boost at peak torque. Again, this is infinitely debatable. Fifth - YEAH BRO I CAN JUST STICK HIDs IN MY STOCK HALOGEN HOUSINGS. Answer - Stop right there bromethius, unless you enjoy pissing off the world, having a worse beam pattern, and just generally screwing up your night vision. A true retrofit is the way to go. There have been a few people who have done TRS Mini-d2s projector retrofits with ZERO retrofit experience - myself included. We are always happy to answer your questions. Sixth - OH NO. I DON'T WANT MY WARRANTY VOIDED! Answer - Your warranty can never be void. You can have a claim denied though. Don't participate in warranty fraud. Zillionth - BROFITEROLES, WILL A COBB AP VOID MY WARRANTY? Answer - Read above question. Your warranty can never be void. However if you have some sort of catastrophic engine failure, do not attempt warranty fraud. Not only is it illegal, but there is currently no way to tell with absolute certainty that the dealer will and/or will not be able to tell if it's been tuned. Own up to your own mistakes because you have to pay to play. There is no post from Cobb or Ecutek that states with absolute certainty that their tuning modification is untraceable. There is also no direct evidence that a dealer will be able to tell sans ECU reset before service. Use your best judgement here. Don't ask this question. Eighth - HEHE NOOB A BOV WILL BLOW YOUR ENGINE UP! Answer - No, a BOV/BPV will not blow your engine up. If you run a 100% recirculating BOV/BPV you will have ZERO issues. I personally do this. Adds some PSH without any flash. There have been many others who run 100% atmosphere as well. Question - DOODZ THE RADIO SUUUCKS Answer - there are a few ways to change how your radio sounds. You can do the "hidden menu" mod to access some different settings. BEWARE OF THOSE TRYING TO TELL YOU THINGS THAT ALMOST MAKE SENSE "Yeah, a lightweight pulley helps rev hang because less weight" WUT??? How does removing weight from a rotating assembly make the throttle plate close faster? This is a PROGRAMMING issue and no amount of weight removal will ever fix that. Last edited by anjuna; 04-17-2015 at 01:48 PM. |
01-06-2015, 09:59 PM | #2 |
Member#: 232940
Good writeup. I like how you identify topics as infinitely debatable.
03-16-2017, 09:20 AM | #3 |
Member#: 419605
Vehicle:2017 WRX RED |
Awesome
04-11-2017, 10:43 PM | #4 |
Member#: 465934
Posting
So if I have a question that I want to post in the forum but it turns into a couple just fighting can I ban them from posting on the thread. Don't want to be an ass but I junk we all know what happens sometimes.
01-06-2015, 10:28 PM | #5 |
Member#: 391748
NESIC
Vehicle:2015 WRX CWP (sold) 2019 STi CWP |
Can you post this on the Facebook page too please?
Christ this is literally what I am thinking when I read every thread. How did you read my mind??? |
01-07-2015, 01:38 PM | #6 |
Member#: 388366
SCIC
Vehicle:2016 SUBARU WRX(cvt) CBS w/eyesight |
01-07-2015, 01:50 PM | #7 |
Member#: 407842
TXIC
Vehicle:2015 WRX CWP |
Great write up. Glad to see it all in one place.
01-07-2015, 12:54 AM | #8 |
Member#: 381706
Vehicle:2015 WRX LR |
+1 man, good write up.
01-07-2015, 01:00 AM | #9 |
Member#: 273906
NESIC
Vehicle:2005 Lexus Grandpa |
Yes but how do I get new WRX?
01-07-2015, 02:49 PM | #10 |
Member#: 391967
MAIC
Vehicle:2015 WRX Limited CWP |
But brocules, do i need winter tires? Brocrates?
01-07-2015, 04:57 PM | #11 | ||
Member#: 401977
TXIC
If you have to ask, you'll never know.
This is why I don't have a facebook. Last edited by anjuna; 01-07-2015 at 05:17 PM. |
01-07-2015, 03:04 PM | #12 |
Member#: 387796
NWIC
Vehicle:2015 WRX RED |
+1 to you man
01-07-2015, 06:41 PM | #13 |
Member#: 278326
MAIC
Vehicle:2015 WRX DGM |
Sticky this.
Sent from my iPhone using NASIOC |
01-07-2015, 09:06 PM | #14 |
Member#: 395626
MWSOC
Vehicle:2015 wrx hot pink |
01-08-2015, 03:49 AM | #15 |
Member#: 395111
South East
Vehicle:2015 WRX Silver |
I concur! Sticky is in order! Good post
01-08-2015, 11:54 AM | #16 |
Member#: 403451
MAIC
Vehicle:'16 370 Z |
+1 on excellent write up/sticky-worthy
...Even though the kind of people who are regurgitating the dribble in multiple threads don't read the stickies anyway... |
01-08-2015, 11:59 AM | #17 | |
Member#: 387796
NWIC
big ass huge BOV sticky thread...still makes post about BOV... |
01-09-2015, 12:00 PM | #18 |
Member#: 407842
TXIC
This needs to be stickied ASAP. It just blends in with the rest of the post, and we are getting the same questions.
01-09-2015, 12:33 PM | #19 |
Member#: 387796
NWIC
there are like 3 boost questions right now lol
01-09-2015, 01:17 PM | #20 |
Member#: 401977
TXIC
01-09-2015, 02:02 PM | #21 |
Member#: 332408
Maybe add this to the section regarding the stock halogens.
Modifying H9 bulbs to fit in the stock H11 socket. http://forums.nasioc.com/forums/show....php?t=2083911 The general consensus is that this will not blind oncoming traffic like improper HIDs will. |
01-15-2015, 01:08 PM | #22 | |
Member#: 395992
Vehicle:2015 WRX Premium ISM |
http://store.candlepower.com/mohirbuba.html Same idea, as the low beam with a noticeable difference in output. It works well with my RX350 HID bi-xenon retrofit. Of course, if you start adding all of that, you'll probably just end up with another Epic Thread of Knowledge. http://forums.nasioc.com/forums/show....php?t=2623235 |
01-17-2015, 01:57 AM | #23 | ||
Member#: 401977
TXIC
Thanks for the suggestions, although this is in the FA engine subforum as opposed to the 2015 WRX forum. (Personally I would have set up the subforums to go by generation, but alas that would make too much sense)... I'll admit, the HID projector retrofit comment was more of a personal nitpick, but as stated, the epic thread of knowledge is a great resource as well that I will add to the top of the post, when I'm not mobile If anyone has any FA20 related info to add, I'm open to suggestions - PM me. I'll keep updating this as more information is available. Sent from my iPhone using NASIOC |
01-15-2015, 04:58 PM | #24 |
Member#: 217193
Vehicle:2015 wrx red |
Great post, most all my questions answered lol
01-20-2015, 03:29 AM | #25 |
Member#: 387796
NWIC
apparently, an aftermarket BPV/BOV (full recirc) will actually do this car good, there are reports that the BPV in our WRX is the same as the JDM LGT, and it has trouble holding stock boost. nice excuse to get a GFB
