04-09-2008, 05:40 PM | #1 |
Member#: 157082
Vehicle:2004 STi WRB |
Intercooler Tilted
When look at the front of my car through the scoop the whole right side of the intercooler is tilted. It doesn't seem that my motor is tilted just the intercooler.
It seems like the motor mounts are fine. I pulled my ebrake all the way up put it in first and let the clutch out slowly and the motor moves a little. But my car is also high mileage and from the records from the previous owner there is nothing saying that he changed the mounts. So im assuming thats normal from all the wear and tear. Anybody ever come across this problem? When I bought the car it was never like that, but I recently noticed it.
04-09-2008, 05:59 PM | #2 |
Member#: 79222
W. Canada
Vehicle:'09 STi 297.5 WHP Blue |
Normally it should be level from L to R with a slight tilt up from the front towards the rear. At least that's how mine is/was with the stock set up...
04-09-2008, 06:11 PM | #3 |
Member#: 157082
I know that its supposed to be tiltled like that but it is tilted down on the right side.
04-09-2008, 06:22 PM | #4 |
Member#: 79222
W. Canada
04-09-2008, 06:23 PM | #5 |
Member#: 157082
Obviously, thats why I posted this, lol.
04-09-2008, 06:41 PM | #6 |
Member#: 161666
SCIC
Vehicle:2005 STI CGM |
The intercooler is bolted up wrong. Check the bolt on the drivers side of the intercooler, most likely it is bolted the wrong way. If so, it will cause the intercooler be at an weird angle.
04-09-2008, 08:48 PM | #7 |
Member#: 50072
South East
Vehicle:2017 STI Blue |
Wow, is it possible to bolt up the intercooler wrong? You must have to be one of those folks that can break anything to accomplish that, heh.
04-09-2008, 09:23 PM | #8 |
Member#: 100694
Vehicle:2003 WRX MPB |
Have you checked the brackets that the intercooler mounts too?
04-09-2008, 10:51 PM | #9 |
Member#: 98961
Vehicle:2003 WRX Black |
Mine's tilted a bit too. I'm not worried about it. Looks like one of the brackets is slightly bent. Probably the passenger side bracket. It doesn't really matter.
04-09-2008, 11:39 PM | #10 |
Member#: 157082
Thanks guys. I mounted the bracket on top instead of underneath.
04-10-2008, 01:06 AM | #11 |
Member#: 98961
How exactly did you do that? In case mine's wrong too.
04-10-2008, 01:20 AM | #12 |
Member#: 150794
SCIC
Vehicle:Qcab dakota 4x4 LT1 Formula Firebird |
Are you sure the passenger side is tilted up, and not the driver's side a little lower? Close your hood slowly and see if you can tell from outside, look how the splitter meets up with it. Is the passenger side scrunched, or is there a gap on the driver's side?
crap I took too long Last edited by Audiosavvy; 04-10-2008 at 01:47 AM. |
04-10-2008, 01:44 AM | #13 | |
Member#: 60685
SCIC
Vehicle:2005 WRB STi 371whp/368ft-lb on 91 |
Similar Threads | ||||
Intercooler tilting for lower IC temps! | o2sys | General Community | 11 | 07-27-2013 09:21 AM |
TablesawerZ Left hand tilt or Right hand tilt? | tom@kartboy | Off-Topic | 11 | 09-08-2006 06:37 PM |
Is the 5Zigen Fireball muffler tilted like the apex n1? | Keiho | Normally Aspirated Powertrain | 3 | 04-25-2001 12:10 AM |
Tilt sensor in the RS? | Duva | Mid Atlantic Impreza Club -- MAIC | 3 | 10-12-2000 12:34 AM |
My Car is Tilted | nizz | Technical Forum Archive | 22 | 07-26-2000 04:09 PM |
