Welcome to the North American Subaru Impreza Owners Club Tuesday May 11, 2021
Old 12-30-2020, 03:42 AM   #1
ScoobyGT
Member#: 404382
2004 GDB STI
SanRemo Red
Default 2004 SanRemo Red GDB STI -> EJ207 VF49 TwinScroll Power
Hi Guys !
I am Kevin, 27 years old and live in a small town near Lucerne in Switzerland.
Work as IT System Specialist and am mainly responsible for the development and maintenance of the communication network.
I had my first Subaru in 2011 and since then it hasn't let me go. I have had several so far (Justy KAD / Impreza GF8 / GC8 / GG Wagon / GD Prodrive...)
In the meantime I own a 2004 GDB STI.
Original color was Java Black Pearl (Painted in SanRemo red by a previous owner)
European version (EJ207 powered)
---------------------- MODLIST -----------------------------------
Brakes
Grimmspeed Brake Master Bracke
OEM Brembo Discs and Brake pads (hopefully i will change soon)
Engine
Grimmspeed 8mm Thermo Spacers
Pierburg 3-Port Solenoid
AP Hard Inlet Pipe 3" (modified for AOS / +1 Connector)
IAG AOS Street v3
COBB Injector Dynamics 1050x Injectors
IHI vf49 TwinScroll Turbo
TwinScroll Header
Killer B heavy duty Oil Pickup
RCM Oil Baffle Plate
EJ25 Oil Sump Pan
GR STI Intercooler
Modified intercooler air baffle
Cusco Turbo Heat Shield
AERYS 3" Exhaust with 300 Cell Catalyzer
Exterior
APR Mirrors
Work Emotion XT7 (8.5x18 ET42)
Advan Racing RG1 (7.5x17 ET45) fitted with Nankang NS-1R (235/40 R17)
20mm wheel spacers per side
Interior
STI S204 Defi Style Speedo
STI 05-07 Center dash
Defi Gauges (Boost, Ext. Temp, Oil Press, Oil Temp)
Callaway Displays Lambda Gauge with AEM Lambda
Suspension
Cusco front and rear strut bar
Cusco Suspension
STI GDA Lateral Link Arms with PowerFlex PU bushings
Whiteline Rear sway bar 25mm with endlinks and mounts
Tanabe Front 21mm sway bar with Whiteline endlinks
STI Group N rear trailing arms
STI Group N knuckle carrier bushings
------------------------- DO DO ------------------------------------
Mapping
Aligment settings
Install the cusco 1.5way diff
ScoobyGT is offline   Reply With Quote
Old 01-22-2021, 07:46 AM   #2
DaveS16
Member#: 311573
2004 Impreza Spec C
Wie immer antwortet keiner auf Threads aus anderen Ländern ;-)
Geile Autos hast du !!! :-)
DaveS16 is offline   Reply With Quote
Old 01-29-2021, 04:34 AM   #3
ScoobyGT
Member#: 404382
2004 GDB STI
SanRemo Red
Hi Dave
Thank you so much !
Yes, unfortunately no one but you has left a comment yet.
Old 01-29-2021, 08:40 AM   #4
Fndragn
Member#: 470845
2011 Sti
Nice cars, the red Sti looks great!!
Fndragn is offline   Reply With Quote
Old 01-30-2021, 10:20 AM   #5
dobie0791
Member#: 72713
2005 STi
Wie Gehts?
Nice cars! What do you use for engine mapping?
dobie0791 is offline   Reply With Quote
Old 01-30-2021, 05:27 PM   #6
archer1.8
Member#: 148335
2018 STi Type RA#454
Need more pictures of this car!
archer1.8 is online now   Reply With Quote
Old 02-02-2021, 04:20 AM   #7
ScoobyGT
Member#: 404382
2004 GDB STI
SanRemo Red
Thank you !
Originally Posted by dobie0791 View Post
Wie Gehts?
Mir gehts gut, ich hoffe dir auch !
I don't do the mapping by myself.
Maptec has a great name in Switzerland for engine optimization.
They have many experience in motorsport (Porsche Team Mecanic, engine and data engineer TCR Europe, over 13 years of experience in engine development and tuning). So, i will bring my car to them, when the build is done.
Engine:
- COBB 1050x Injectors
- Deatschwerks DW300 Fuel Pump
- IHI VF49 TwinScroll Turbo
- 300cell catalyzed downpipe (needed to be street legal in Switzerland)
- 3" Aluminium inlet pipe
- 3-port Boost solenoid from Fuji Racing
- TwinScroll Oil pan with RCM dampened oil pickup and baffle plate
- Grimmspeed 8mm Thermo Spacers
- GR STI Intercooler with self made shroud (under construction)
Wheel / alignment:
- Whiteline 24mm rear swaybar with mounts and endlinks
- Tanabe 21mm front sway bar with witheline endlinks
- STI v7 Lateral link bars with PU bushings
I own the car since Mai 2019 and drove only around 2000 Miles till now.
So, i sadly don't have more pics at the moment.
Currently, it looks like that
Old 02-02-2021, 07:03 AM   #8
horsePOOGAS
Member#: 450712
04 STi
I've never heard of a VF49 Twin scroll? I know of the VF37 and VF36 (which is what I have)
https://forums.nasioc.com/forums/sho....php?t=1141476
BTW Love your car and color. I wish more WRX's came in red. I think I would have picked it over WRB if given the chance.
Edit: Just did a some Googlefu and found some info on the VF49's. I had never heard of it before, but yet it's been out there for a long time. Really neat. Makes your car that much more unique!
horsePOOGAS is offline   Reply With Quote
Old 02-04-2021, 03:26 AM   #9
ScoobyGT
Member#: 404382
2004 GDB STI
SanRemo Red
The VF49 are installed on de GR STI (JDM 2.0L Version). It's simmilar to the VF37 but the compressor side intake diameter is some milimeters wider.
Slowly goes forward with the build
The COBB 1050x Injectors are in
Old 02-08-2021, 08:00 AM   #10
ScoobyGT
Member#: 404382
2004 GDB STI
SanRemo Red
IAG AOS is nearly installed om my EJ207. Just need some little things to finish.
Old 03-02-2021, 02:39 AM   #11
ScoobyGT
Member#: 404382
2004 GDB STI
SanRemo Red
Found a place to install my Defi control unit and the Air/Ratio Display for my AEM gauge.
Old 03-02-2021, 07:01 AM   #12
horsePOOGAS
Member#: 450712
04 STi
Did you make the Defi control housing or was it purchased from somewhere? Looks really nice!
Old 03-02-2021, 07:44 AM   #13
ScoobyGT
Member#: 404382
2004 GDB STI
SanRemo Red
Hi,
Yes it's purchased from SubtleSolutions.
I made the holes for the control unit and the display
And thank you for the flowers
Old 04-12-2021, 01:34 AM   #14
ScoobyGT
Member#: 404382
2004 GDB STI
SanRemo Red
I have some updates from my site.
GrimmSpeed brake master bracket installed
Could not get out the Jesus bolt, so i got some new knuckle carriers, bearings and seals.
For some more beauty i got STI group N trailing arms and bushings for the knuckle carriers
