Welcome to the North American Subaru Impreza Owners Club Friday May 7, 2021
Old 12-10-2019, 07:49 AM   #1
Ty_d22
Member#: 509181
Default 2017 wrx turbo fins chipped
Hi guys ! New to the site ! Would love some insight on my issue here , or to hear of any people experiencing this themselves .
Today I had went to but a new diverter valve on my rebuilt 2017 wrx 6mt with 19000km on it , and as I looked into my turbo I could see that the fins on the wheel were chipped , 3/6 of the fins are badly chipped the other 3 are almost fine , has anyone els had this happen to them with such low mileage ? It almost seems as if my turbo had sucked somthing in, if anyone has any insight or thoughts pls let me
Know ! anyways thanks guys
Ty_d22 is offline   Reply With Quote
Old 12-10-2019, 01:05 PM   #2
BostonShaun
Member#: 416873
2015 WRX
A lot of info missing here. Why was it rebuilt? Past and present mods, ect.
BostonShaun is offline   Reply With Quote
Old 12-10-2019, 06:15 PM   #3
Razzro666
Member#: 509198
Hard to say need more info that lead to finding out
Razzro666 is offline   Reply With Quote
Old 12-11-2019, 07:55 AM   #4
Ty_d22
Member#: 509181
Sorry ! Car is completely stock other then axel back borla exhaust, car was rebuilt from a front right end crash needed a new hood , bumper , and rad support , car is acting completely normal but I just found it out when I went to change my bypass valve
Old 12-11-2019, 08:24 AM   #5
Phirebeard
Member#: 483407
2004 Mitsubishi
Montero Sport
They are definitely not supposed to look like that. Something may have broke off in the cold side during the accident while the engine was running.
Phirebeard is offline   Reply With Quote
Old 12-11-2019, 09:03 AM   #6
Bansheeboy11
Member#: 182415
1999 RS
They had a recall where the inlet came apart and sucked in parts, and its also likely something broke from the accident as its right behind the rad/support. I would definitely get a used replacement or have a new wheel put in there soon.
Bansheeboy11 is offline   Reply With Quote
Old 12-11-2019, 10:34 AM   #7
rtv900
Member#: 428511
2016 STI
no question some metal went through that, it had to end up somewhere, most likely in your intercooler and stopped.
Certainly won't hurt anything, just reduces efficiency of the fan as long as there's no more burs ready to let loose
Old 12-11-2019, 10:27 PM   #8
Bluestreak03
Member#: 125887
2001 EJ207 V7 RSTi,
Mica Blue
I would be more worried about where that FOD ended up
Bluestreak03 is offline   Reply With Quote
Old 12-11-2019, 10:33 PM   #9
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
That wheel is toast, get rebuilt or new turbo asap. Also look downstream, hopefully the big pieces stopped in the intercooler...which I'd also throw out. Something obviously got sucked in and destroyed those blades, and some bits may have even made it past the intercooler, small as they would have to be. I'd remove the intercooler and intake manifold and thoroughly clean the manifold and toss the intercooler. Not worth keeping, a small piece could become dislodged and cause a valve to stay open long enough to misfire under boost and cause other problems.
Old 12-14-2019, 10:53 PM   #10
Subie_
Member#: 419354
2007 STI
Crystal gray metallic
The wheel has relatively low inertia, but it spins in the ballpark of 150k rpm. That sucker is waaaayyyy off balance and has definitely seen some debris. I would replace it.
Subie_ is offline   Reply With Quote
