Welcome to the North American Subaru Impreza Owners Club Thursday December 3, 2020
Old 11-19-2020, 02:44 PM   #1
Redtape
Member#: 517309
2004 Impreza WRX
Exclamation HELP! no start, I dont know what else to do.
Please excuse the long write up
I have a japanese ej205 with avcs swapped into my 2004 wrx. Its paired with a V7 sti ecu and has the added wires to have acvs running. Pics
https://ibb.co/0sh9g6N
https://ibb.co/Jk6ttLC
https://ibb.co/B6xc8y0
https://ibb.co/PxK2DWG
https://ibb.co/tCNj2BP
https://ibb.co/8DmsGvz
My main problem is that I cant get it to start, it just cranks. Ive gone throught the steps of troubleshooting already. Fuses under the hood and by steering whel were all good, fuel pump primes and im getting proper fuel presure in my lines, brand new spark plugs were put in this week and coil packs were checked with a multimeter to show the proper internal resistance and connectors were checked to makesure that the coil packs are getting 12v with the ignition on. Ive checked my timing and everything seems to be lined up right, heres some pics:
https://ibb.co/Gs3KFnm
https://ibb.co/LQtRXDY
https://ibb.co/M5mxnMf
https://ibb.co/1GkRByy
https://ibb.co/6rGsHSk
https://ibb.co/KL8b1tr
I was also getting a code for the crank position sensor so I changed that and the code went away. Its a 2 wire crank sensor and connector but idk if that matters or not, however I dont know if i have the correct crank sprocket for my engine since I know the usdm ones have a different teeth set that the ecu can read. heres wahat I got (remember this is a jdm engine with a jdm ecu)
I tried taking my spark plug out to see if I was actually getting spark and I didnt see one, but when turning the engine over it will occasionally back fire which tells me something is igniting the fuel (maybe?)
One final piece of info; the car has been sitting since summer, I tried a cold compression test and get 105 on all cylinders except for #3 which was 90. I know that sounds really low but I dont think it would stop the engine from starting (just make it run like a dog). I know that is a big issue but honestly I just want the engine to last me atleast through the winter before I rebuild/swap it.
Any help would be appreciated because I feel like ive tried averything I can think of and i know some of you guys have way more subie knowledge that i do. Thanks
Redtape is offline   Reply With Quote
Old 11-19-2020, 03:32 PM   #2
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
V4 GF8 White
Lightbulb
It would be a lot easier for people to see your images if you embedded them into your post using the NASIOC image host.
Vancouver98STi is online now   Reply With Quote
Old 11-19-2020, 03:52 PM   #3
Redtape
Member#: 517309
2004 Impreza WRX
Here you go, hopefully its visible now
Old 11-21-2020, 04:11 PM   #4
EvanSutton
Member#: 520431
Pull the coil pack out and watch for spark against a solid ground . And check all of your grounds.
EvanSutton is offline   Reply With Quote
Old 11-21-2020, 10:14 PM   #5
NewSilverWRX
Member#: 58485
2004 RASC.207 WRX 5M
Try starting with your original ECU assuming you have it. Oh, and unplug the MAF. Do you have an Openport or other way to talk to ECU or log?
NewSilverWRX is offline   Reply With Quote
Old 11-22-2020, 02:52 AM   #6
TwistedAxles101
Member#: 379235
2002 Impreza WRX
Blaze Yellow
Take a look at the peaks and valleys of your crank sprocket, make sure none of the teeth are missing.
TwistedAxles101 is offline   Reply With Quote
Old 11-22-2020, 10:32 AM   #7
Redtape
Member#: 517309
2004 Impreza WRX
Doesnt start with the usdm ecu either. The fuel pump will still prime and it cranks but no start. Also i dont have a tactrix cable
Old 11-22-2020, 10:33 AM   #8
Redtape
Member#: 517309
2004 Impreza WRX
All the teeth seem to be there on the cam and crank gears :/
Old 11-23-2020, 10:44 PM   #9
Bluebieru
Member#: 520461
2004 WRX
Im having the same problem. jdm engine and ecu whick isnt getting a spark.
No idea why since fuel sistem works perfect and crank sensor was just replaced
Bluebieru is offline   Reply With Quote
