Welcome to the North American Subaru Impreza Owners Club Sunday December 16, 2018
Old 12-07-2018, 03:35 AM   #1
psimitar
Member#: 494749
Default what do these electrical connectors connect too?
Hiya peeps,
So I've an FA20 engine that been used as part of an engine swap. I hope this doesn't offend people?
There are 3 connectors on the engine wiring loom that weren't connected to anything, what with just having the engine delivered from the scrappers.
Now I'm pretty sure the 5 pin wire goes into the airbox on a BRZ but aside from air temp does anyone have any idea what else it's sensing?
The other 2 connectors bolt on a bracket to the top of bank 1 chain cover, as marked by red oval in picture below.
Any idea what these 2 connect too?
Cheers in advance
psimitar is offline   Reply With Quote
Old 12-07-2018, 07:48 PM   #2
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
Do you have a photo of the actual connectors? Also, you might have better luck in the FA forum section.
CaptainSlowbaru is offline   Reply With Quote
Old 12-08-2018, 12:14 AM   #3
psimitar
Member#: 494749
Here's a photo taken from the web with the connectors circled.
I may have had a light bulb moment and these are the pre and post cat lambda sensors.
