10-28-2004, 03:02 AM | #1 |
Member#: 56626
Vehicle:2004 S2000/STi seabring silver / BLUE |
horrable grinding sound when i turn off auto on my sti center diff.
HELP when i turn off auto on my Driver Controlled Center Differential like if i put it to 50/50 or somthing like that i hear a HORRABLE grinding clunkey just horrable sound coming from the fron axel or somthing in the front when i turn the car ....... WHAT IS THIS !!!
10-28-2004, 04:52 AM | #2 | |
Member#: 152
Vehicle:2002 Impreza WRX WRB |
10-28-2004, 09:22 PM | #3 |
RIP
Member#: 38867
Vehicle:11 Mazda |
or try a search.
10-28-2004, 09:51 PM | #4 |
Member#: 22040
Vehicle:2016 VW Golf R Rent-a-car White |
Youre not supposed to use the 50/50 lock on dry pavement. Its called LOCK because it LOCKS the center differential, thats why you hear grinding when you turn the car. Use LOCK on snow, otherwise, leave it in AUTO.
-Geo |
11-02-2004, 02:27 PM | #5 | |
Member#: 47769
11-02-2004, 09:14 PM | #6 |
Member#: 73496
Vehicle:2005 STi Crystal Gray |
some of you guys are just plain silly sometimes... you can lock the diff anytime you want ...but NOT when you TURN!!! when you lock it, it is like having both front tires are moving at the same rate. But wait if you are turning, theinside tire always turs faster!! if you keep doing this it will break!!!
11-03-2004, 12:36 AM | #7 | |
Member#: 40192
NESIC
Vehicle:04 STi Blue/Gold |
11-03-2004, 07:18 AM | #8 |
Member#: 13110
NESIC
Would you drive a part time 4wd truck on dry road with all 4 wheels locked? I don't think you would.
Why do you think it would be a good idea to do that on your STi? |
11-03-2004, 08:23 AM | #9 |
Member#: 47769
Technically neither turns faster hence the noises. The tires spinning at the same rate is what causes all the problems with the differential because they want to spin at different rates, but are not allowed. Not if you leave it in auto one will spin faster than the other.
Grinding sound when I let off gas? | USF97J4x4 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 32 | 07-27-2008 04:30 PM |
Differential Problems? Grinding sound when turning at low speeds | 409Industries | Transmission (AT/MT) & Driveline | 4 | 05-06-2007 10:09 PM |
rub/grind sound when i turn the wheel | VTSubieRS | Brakes, Steering & Suspension | 7 | 03-29-2006 08:34 PM |
horrable grinding sound when i turn off auto on my sti center diff. | SMOCKRAT | Southern California Impreza Club Forum -- SCIC | 5 | 10-28-2004 03:14 AM |
Squeaking sound when engine turns off? | AlexGeez | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 11-20-2003 11:07 PM |
