05-13-2013, 01:17 PM | #551 |
Member#: 153880
RMIC
Vehicle:03 Evo VIII 2011 STI |
Your clutch wasn't holding but you exploded your transmission and diff? Than you switched to a clutch that is rated for less TQ?
05-13-2013, 01:21 PM | #552 | |
Member#: 242700
Vehicle:2015 Impreza Wrx White |
I beg to differ... |
05-13-2013, 01:24 PM | #553 | |
Member#: 193757
Vehicle:2006 XTI Limited OBP, Junior tuned 573WHP |
05-13-2013, 01:36 PM | #554 | |
Member#: 242700
You want us to change the tune? |
05-13-2013, 01:50 PM | #555 |
Member#: 193757
Naw, I'd just keep breaking ****.........I'm being a richard cranium again
I'd defer to the experts you mentioned and find and fix the weak link. Trouble is another will develop somewhere else. It's definitely a dilemma to think through though!! |
05-13-2013, 02:00 PM | #556 | |
Member#: 242700
Finding the weak links is exactly what we are doing and upgrading accordingly lol Axle breaks... replace with dss stg 5 axles Differential breaks... replace with cusco Clutch breaks... replace with triple disc |
05-13-2013, 02:23 PM | #557 |
Member#: 260937
Vehicle:2005 wrx sti OBP |
You guys deffinently need to switch to the M&H rAcemasters . They are way more forgiving and I ran a 1.42 60ft ! With my stock axles and drive shaft and trans with 113k lol
05-13-2013, 02:24 PM | #558 | |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
Why not keep the weak link the cheap and easy part to fix |
05-13-2013, 02:30 PM | #559 |
Member#: 56179
Vehicle:05 LGT 407hp/372tq Tuned by mike@Innovative |
05-13-2013, 02:33 PM | #560 |
Member#: 193757
Or build in some give/ slip in the drive line, like the tires or maybe a just a tad less early torque, just saying!
Junior and I were talking about running just rear drag radials, matching diameters of front and rear and seeing if you could get it to leave more like a RWD, maybe dial your DCCD to the rear. |
05-13-2013, 02:34 PM | #561 | |
Member#: 242700
What happens if the turbo breaks? What happens if the axle breaks? Everything is costly when it comes to modifying these cars and it sucks but in order to play, you got to pay... |
05-13-2013, 02:50 PM | #562 |
Member#: 254796
Vehicle:04 Sti |
05-13-2013, 03:05 PM | #563 |
Member#: 242700
Exactly!
Some people like to buy drinks, I prefer engine and tranny fluid if possible... Some people like to smoke, I much rather prefer smoking tires and clutches! My grandfather helped buy this car for me and he loved it as much as me while he was living and now that he is gone, this build is dedicated to him and I will not stop until I hit a 9 in his honor! Last edited by baseballdbk1; 05-14-2013 at 08:32 AM. |
05-13-2013, 03:44 PM | #564 | |
Member#: 254796
Vehicle:04 Sti |
05-13-2013, 04:00 PM | #565 | |
Member#: 242700
Yea it should make very close to 700 on a dynojet. I dont know about over that but I can always dream lol As far as the tb, I can exactly say I have l "felt" a difference but it showed on the dyno graph! Last edited by baseballdbk1; 05-13-2013 at 05:21 PM. |
05-14-2013, 11:43 PM | #566 | |
Member#: 153880
RMIC
Have fun smoking your twin. |
05-15-2013, 12:00 AM | #567 | |
Member#: 242700
I thought the heavy duty twin was rated to over 600 but after taking to Josh @ IIR, I changed to the triple! I have smoked two 6 puck discs already, with this most recent one only lasting about 8k so please tell me more about a clutch actually withstanding the amount of torque that the company states on their website... Even if I did buy the twin and that wasn't enough, I would just build it into a triple which was my initial plan |
05-15-2013, 12:00 AM | #568 | |
Member#: 77470
Vehicle:04 sti 10.41@141 on e85@ 30psi--spinning |
05-15-2013, 12:07 AM | #569 | |
Member#: 242700
The way the car felt and the way my clutch looks beg to differ with you thinking that the clutch was not slipping lol Last edited by baseballdbk1; 05-15-2013 at 11:10 AM. |
05-15-2013, 12:11 AM | #570 |
Member#: 77470
without a log its hard to say but think about it this way at the power level you are at and the load is the highest in 4th the engine would have went into the rev limiter if it was slipping that bad ---been there done that.Like I said I hope you do hit 9's.Also you would not believe how bad a clutch will look after a couple good hard launches from a high hp suby.
05-15-2013, 12:33 AM | #571 | |
Member#: 242700
We are dropping off the tranny at AndrewTech on Thursday or Friday to get torn down, check out internals, also install the new diff and bellhousing! The plan to install the tranny when it is finished, the clutch and if my wallet allows it, carbon drive shaft and stg 5 rear axles! Slipping clutch, short shifting and 1.51 60"= 10.43 @ 132mph Good clutch, shift @ 8k and 1.40 60" = 9.9X @ 140+/-mph |
05-15-2013, 12:37 AM | #572 |
Member#: 77470
hope it all comes together for you,keep us posted.
05-15-2013, 12:51 AM | #573 | |
Member#: 185725
Nate TPG |
05-15-2013, 12:54 AM | #574 |
Member#: 77470
know what your saying hope you guys get it ready to go,you do know that dss has a 850whp axle set available now so you don't actually have to jump to the expensive stg 5 setup.
05-15-2013, 12:59 AM | #575 |
Member#: 242700
