Welcome to the North American Subaru Impreza Owners Club Monday March 4, 2024
Mid Atlantic Impreza Club
Old 03-24-2006, 09:16 AM   #1
Jard
Member#: 34935
Dad- Core
OG
Exclamation Gas smell in cabin...not so much in engine bay?
Symptoms happened this morning in Shannon's wagon. We smelled gas while sitting at a light right by home and then again in the parking lot at work once we stopped and idled for a few moments.
I popped the hood and sniffed around in there, but didn't smell any gas. Shannon says the smell was really strong on her side(driver's side) outside of the car.
What do I check first?
Jard is offline   Reply With Quote
Old 03-24-2006, 09:18 AM   #2
AcquaCow
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
Lift left-outter cheak and inspect for leaks in das pooper?
AcquaCow is offline   Reply With Quote
Old 03-24-2006, 09:19 AM   #3
Jard
Member#: 34935
Dad- Core
OG
Gasoline.
Old 03-24-2006, 09:22 AM   #4
blubaru703
Member#: 71380
Oh noes your NOZ is leaking!!!
blubaru703 is offline   Reply With Quote
Old 03-24-2006, 09:28 AM   #5
D_Block
Member#: 64127
2001 PY ITR, 2012 X5
on order
Was it cold this am? That is a known issue..do a freakin search n00b!!!
D_Block is offline   Reply With Quote
Old 03-24-2006, 09:30 AM   #6
Nuc1earWinter
Member#: 44638
04 Sage 2.5 WRX
going to the pants party
The issue you are refering to would cause the gasoline smell to emanate from the engine bay. N00b!
Nuc1earWinter is offline   Reply With Quote
Old 03-24-2006, 09:30 AM   #7
VipersEatLotus
Member#: 21007
[asshat-ish mid-a representative] do a ****in search noob and you will find your answer...this has been covered a million times!!! [/asshat-ish mid-a representative]
VipersEatLotus is offline   Reply With Quote
Old 03-24-2006, 09:32 AM   #8
Jard
Member#: 34935
Dad- Core
OG
Dyyyrrrrrran already beat you to that.
Sean already told him he was stupid.
We're past that.
Old 03-24-2006, 09:33 AM   #9
D_Block
Member#: 64127
on order
I have had the cold gas smell in the cabin...this was prior to doing anything with my injectors, and it was on cold mornings....n00b!!
keep it up. No red hazard button
Old 03-24-2006, 09:34 AM   #10
Nuc1earWinter
Member#: 44638
04 Sage 2.5 WRX
I hate you.
Old 03-24-2006, 09:34 AM   #11
D_Block
Member#: 64127
on order
Seriously, I have had the same smell. The reason it may not have been noticeable in the engine bay, logic dictates, would be it is in the OPEN FREAKIN AIR!!!! Duhhhh!!! Gaaawsh!!
Old 03-24-2006, 09:35 AM   #12
Jard
Member#: 34935
Dad- Core
OG
So why does it smell outside the car right by the driver's door and not by the throttle body?
a;slkdjf;laskdjf;kahsd;flkjas;dlf
Old 03-24-2006, 09:36 AM   #13
VipersEatLotus
Member#: 21007
i have only had it bad once and then it went away...way back when i first had my car.
only happens on cold morning it seems.
some say it is the fule rails, that if you replace those you will be just fine.
http://forums.nasioc.com/forums/show...as+smell+cabin
can i have the red hazard button?
Old 03-24-2006, 09:37 AM   #14
D_Block
Member#: 64127
on order
Oh, somebody must have thrown gas at your door last night..DUHHHHHH!!!
Old 03-24-2006, 09:41 AM   #15
Jard
Member#: 34935
Dad- Core
OG
Now that we're done with that...
I mean I obviously think it could be the TB fuel leak. I'll check all lines when I get a chance and see if there are any loose clamps or crap like that.
I was just surprised since it was 39 F this morning and it has been a lot colder out in the last few months and this never happened.
Old 03-24-2006, 09:54 AM   #16
Nuc1earWinter
Member#: 44638
04 Sage 2.5 WRX
You also said it was after idling.
Was the car already warmed up or was the engine still cold?
Old 03-24-2006, 09:58 AM   #17
lotusdrift
Member#: 24308
Oh, **** it
I'm gonna have a party
typical issue with the 240 is to not have the inner gastank cover sealed properly...just a thought, if you happen to have installed a pump.
I would then just check all the lines, especially near the firewall where it goes from hard to soft (he heh heh heh).
lotusdrift is offline   Reply With Quote
Old 03-24-2006, 10:05 AM   #18
Jard
Member#: 34935
Dad- Core
OG
The car had been idling for a while when we first smelled it (Remote Start before we leave in the morning), but we were less than a block from our place.
The car was warmed up when we got to the parking lot at work and smelled it again.
Old 03-24-2006, 10:08 AM   #19
Grap
Member#: 6590
Didn't you just finish installing a drivers-side flamethrower option on her car?
Grap is offline   Reply With Quote
Old 03-24-2006, 10:16 AM   #20
BryanH
Member#: 993
Did you get the exhaust gaskets fixed?
BryanH is offline   Reply With Quote
Old 03-24-2006, 10:25 AM   #21
D_Block
Member#: 64127
on order
upscale!
Old 03-24-2006, 10:43 AM   #22
jetwagon
Member#: 59872
2004 Impreza WRX
My sub stinks like gas a lot. And I drive from inside the car rather than the engine compartment so I tend to smell the gas from inside the car.
jetwagon is offline   Reply With Quote
Old 03-24-2006, 10:46 AM   #23
Jard
Member#: 34935
Dad- Core
OG
Yep...we got that all fixed up. No more raw exhaust smell...just gas now.
Another note: The car idles and runs fine.
Old 03-24-2006, 10:46 AM   #24
Jard
Member#: 34935
Dad- Core
OG
Thank you "Capt. add nothing to the thread" guy.
Old 03-24-2006, 10:48 AM   #25
VipersEatLotus
Member#: 21007
add your region/chapter info and we will start paying attention to your posts
if they are helpful
Lisa Fleming, so hot or not so much? rice h8r Off-Topic 37 05-28-2007 03:19 AM
Gas smell coming from alternator and a check engine ansonb505 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-17-2007 09:38 PM
Gas smell that is not related to cold weather ImpreziveWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-08-2006 09:41 PM
I like what you've done here, and here, but not so much here...... Ripper Off-Topic 12 12-13-2003 08:21 PM
Not knowing much about engine design, I have this question. redoktober_99 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-14-2002 09:43 AM
