Welcome to the North American Subaru Impreza Owners Club Monday May 21, 2018
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 02-11-2008, 01:20 AM   #1
wrxwagon253
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
Default Can I use my 05 Wrx clutch and Flywheel w/ my 6spd and Sti block???
So I finally got ahold of my 6spd and have had the block just waiting and now comes the point where I need to figure out if I can use my Exedy clutch kit with Act flywheel from my 5spd or not..Im getting a 04 tranny which is also a pull style tranny so im not sure..Any advice would help..Thanks..
wrxwagon253 is offline   Reply With Quote
Old 02-11-2008, 03:47 AM   #2
abgusaf
Member#: 143122
07 WRB STi
in the werks
I know you can use the 5sp clutch with the 6sp on a wrx block, not sure with it being the sti block though
abgusaf is offline   Reply With Quote
Old 06-01-2008, 11:18 AM   #3
cquirki
Member#: 171466
02 WRX
Built 2.5 6speed
i think u can... im wondering the same thing.. but i swapped to an sti block and im using 02 wrx clutch works fine... im guessing the tranny will be able to aswell.
cquirki is offline   Reply With Quote
Old 06-01-2008, 12:01 PM   #4
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Why would the block have anything to do with it? Head into the main section of the forum and do some searching, this question has been asked hundreds of times before.
lancelucas is offline   Reply With Quote
Old 06-01-2008, 12:59 PM   #5
FigNuts
Member#: 125413
IIRC you can use 5 spd clutch/flywheel with the 6 spd tranny. But you cannot use the 6 spd clutch/flywheel with a 5 spd tranny.
FigNuts is offline   Reply With Quote
Old 06-01-2008, 01:52 PM   #6
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
yeah its kinda like PS1 games on a PS2 but no PS2 games on a PS1
B00st3dWRX is offline   Reply With Quote
Old 06-01-2008, 11:20 PM   #7
Cone Klr
Member#: 73072
02 wrx, 04sti
WRB squared!
Default clutch
you most definitely can use the 6 speed clutch with a 5 speed transmission, you have to clearance some of the bell housing though. The blocks are exactly the same externally.
Cone Klr is offline   Reply With Quote
Old 06-02-2008, 02:17 AM   #8
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
the amount of bellhousing clearing you have to do, is a lot... and most of the time if you use the right part for the job, you dont have to take a die grinder to your transmission.....
BREWPUBEAVER is offline   Reply With Quote
Old 06-02-2008, 03:38 AM   #9
Cone Klr
Member#: 73072
02 wrx, 04sti
WRB squared!
Default clutch
yes brewpub you are right I would recommend using the right part in most cases. I have a customer that wanted the 6 speed clutch because the 5 speed is too noisy. you don't have to take that much material off of the bell housing to fit the clutch. if you are going the opposite way as the op i would only recommend doing that with a high quality aftermarket clutch, ie.exedy twin plate or hyper single.
Old 06-08-2008, 07:15 PM   #10
wrxwagon253
Member#: 125620
05 3076R Wagon
Whatever bro ive had my swap done for months now and got plenty of help from people and you not being one of them.
Old 06-08-2008, 07:18 PM   #11
auslyle
Member#: 129737
04 Sweet Impreza
you guys do know that this will not work right??? the sti clutch pushes while the wrx clutch pulls... check with a shop but im allmost 1000% sure that that is a false statement
auslyle is offline   Reply With Quote
Old 06-08-2008, 09:56 PM   #12
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Congrats bro.
02-05 WRX clutch and flywheel type in a 07 STI mcu81 Transmission (AT/MT) & Driveline 8 04-11-2010 07:30 PM
Fidanza Flywheel (4.6 kg) and STI clutch for Impreza WRX-STI 03-07 # 110661 -J.M.G.- Drivetrain 2 10-12-2009 08:48 AM
FS: Pickup in S.NJ Used 5-speed WRX Clutch with Flywheel ScoobyNubieToo! Tri-State Area Private Classifieds 0 01-27-2009 06:51 AM
if i buy new clutch and flywheel for my 98 RS; will sti v4-6 tranny mate? Rallyspec Transmission (AT/MT) & Driveline 0 08-29-2003 09:19 PM
Can I use a Exedy WRX clutch and flywheel on a sti 6spd? eightballrj Transmission (AT/MT) & Driveline 5 08-11-2003 11:05 AM
