Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Old 08-06-2010, 07:29 PM   #1
MaxPower
Member#: 18084
1994 Subaru WRX
Default Gear oils for my 94 WRX? All of them. What kind to use?
The owner's manual is in Japanese, so its no help.
I want to change out all gear oils in the car and I don't mind spending money on quality oils. I assume trans, front diff, rear diff, right? Or is it just trans and rear diff? Center diff? I have no idea how the specifics of it work. I haven't seen the car from beneath.
And throwing this one out there. Anyone know the capacities?
MaxPower is offline   Reply With Quote
Old 08-06-2010, 07:47 PM   #2
RB2B
Member#: 222663
2004 STi
I used the GrimmSpeed Tranny Cocktail. It works great; check it out.
RB2B is offline   Reply With Quote
Old 08-06-2010, 08:23 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
DO NOT MIX DIFFERENT GEAR OILS!!! All the "cocktails" are total BS.
If you can get Mobil1 Delvac where you are, use that in the gearbox. The gearbox contains the front and center differentials. In the rear end use Redline LW shockproof.
I don't post this in the Tranny forum because that place is littered with self proclaimed experts who don't know what they are talking about. You won't find me endorsing anything there. You will find many people telling you other things there.
Old 08-07-2010, 12:18 AM   #4
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Could you argue with Uncle Scotty and prove yourself right?
I'm curious too. I'm curious about why the 'Scotty's cocktail' is popular and "effective."
Why not mix fluids?
Smoke is offline   Reply With Quote
Old 08-07-2010, 01:28 AM   #5
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
I'm pretty sure MM can since he does this for a living.
Speaking of which, I forgot what you recommended I use in my trans. I've only driven the car around 7000 miles, but I figured it would be good to know when the appropriate time comes.
JDMFLCL is offline   Reply With Quote
Old 08-07-2010, 03:41 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
I always stick with what the factory recommends: 75W90 gear oil.
Marnix is offline   Reply With Quote
Old 08-07-2010, 01:56 PM   #7
MaxPower
Member#: 18084
1994 Subaru WRX
Do I use GL4 or GL5? Or other?
Old 08-07-2010, 02:29 PM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
I used GL-5 before.
Old 08-07-2010, 10:03 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
Why not mix fluids?
Why not? Because it's a waste of your time and money to buy single quarts and mix them when you can just get a gallon jug and pour it in there.. There's not some deep mystical chemical explanation not to do it, though many have argued from that anglein the transmission forum against using.
As Dave mentioned, what I do for a living is manufacture gears and LSDs for Porsche gearboxes, primarily for use in motorsports. Though a lot of our clientele daily drive their cars and "just" use them for DEs. They're sportscars and track or not Porsche owners, like Subaru owners, like nice things and they drive their cars hard wherever they go.
The modern Getrag Porsche gearboxes use a 3 piece synchronizer assembly for 1st and 2nd gear, much like the Aisin gearboxes do. And like many of the Subaru guys, the Porsche guys develop shifting problems in those positions that they attempt to remedy through various choices of gear oil and they argue about it just like the Subaru guys do. Furthermore, just like a Subaru, all of our Porsche gearboxes are transaxles, containing a differential and ring and pinion, and as such should be run with a GL5 oil.
That said, we recommend the Delvac because of the particular mix of oil and detergents and additives has shown itself to be quite durable in a racing environment and the long term wear characteristics are very good. In particular, when coupled with our LSD, which adds upwards of 20-30 degrees F to gearbox temperatures, the oil holds up very well. This is why we recommend it.
One other thing I would like to point out, that I think is way way more relevant than exactly what gear oil you use is service interval. What's the Subaru service interval? 60K? These days Porsche is telling people 90k mi. That's a freaking joke. These are cars that people drive hard. This isn't your grandma's Buick. For a 100% street driven car I recommend a 20-30k mi service interval. For my street driven RS, I change it once a year, regardless of mileage.
For the one that we take to the track that interval is increased. Track use exponentially accelerates the breakdown on the gear oil. Obviously DE/open track days are a different sort of abuse than a 1 or 2 hour enduro event because how long the oil gets hot and stays hot (often Gearbox temps will approach or exceed 200 degrees in those circumstances). For DE/open trackday use, I recommend changing the oil after every 3rd or 4th event. If you actually race the car and do real timed race events where you are at the limit, I recommend changing it every 10-12 hours of track use. People are religous about engine oil service and many people change it after a single track day. You almost never seen them talk about changing their gear oil more often because they go to the track.
I think 95+% of the "results" people see with Scotty's mix is they are replacing worn out gear oil. It wouldn't matter if they put in Valvoline or Redline or Castrol at that point. If they put in fresh oil that is up to it's rated viscosity it's going to shift better.
In closing, put whatever you want in your gearbox. My street RS has Valvoline in it. My sometimes track RS has Mobil One Delvac. My Carrera has a speciality oil from a small company called Swepco in it. It's as good as the Delvac, but harder to get, and for whatever reason it works better with Porsche's old proprietary split ring synchros than anything else I've found. If I had a G50 with Borg Warner synchros in my Carrera, it would get the Mobile One like the Subaru. Just make sure it's at least 70w90 and GL5 and you'll be fine. Just change it more often than Subaru tells you to...
Old 08-07-2010, 10:22 PM   #10
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Thank you, that clears it up.
I wasn't arguing or questioning you, just curious.
Old 08-07-2010, 10:24 PM   #11
jackolafedon
Member#: 232089
2007 Impreza 2.5i
Crystal gray metallic
Subaru recommends a 15K change of the diff and manual trans fluid in severe duty applications. I'm currently running Pennzoil bulk GL5 in both my trans and read diff, shifting is very smooth. I don't see why there are so many arguments about what to run when using the properly rated oil is all that's really necessary.
jackolafedon is offline   Reply With Quote
Old 08-08-2010, 12:21 AM   #12
CALIBAN
Member#: 188527
use Motul 300 75w90 gear oil. they work great for me.
CALIBAN is offline   Reply With Quote
Old 08-08-2010, 12:30 PM   #13
MaxPower
Member#: 18084
1994 Subaru WRX
So any popular GL5 should be fine? Is synthetic required or is dino fine if I am going to change it often?
I've never heard of such frequent service intervals. Most of my life I have driven Volkswagens and have never changed gear oils. Thought because it was sealed that it wasn't subject to getting dirty and it doesn't break down. But it seems that now with the Subaru, I should for surely change them all out and continue doing it regularly? At least it's not a difficult job.
Are they like my VWs where I just add the oil until I can't add any more? Or is there a specific amount? As I said, my owners manual is in Japanese and I can't seem to find capacities anywhere on the web. Its just a standard 94 WRX with the EJ20G engine.
Old 08-09-2010, 01:42 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
The gearbox itself is 3.7 qts. It's kind of a pain in the arse because you fill it through the dipstick tube. Get a really long skinny funnel and don't hurry.
The rear end takes .8 qts. It's like your VW with a drain and a fill plug. Always remove the fill plug before draining so that you know you can refill it. It uses a 1/2" square drive, with is a bit of a PITA. Just fill it up until it starts to leak out the hole.
I generally run my rear end twice as long as my gearbox and only change it once every 2 years.
One other thing to mention is you can ignore any discussions you see in the transmission forum about friction modifiyer. Neither of the LSDs in a stock configuration (center or rear) is a clutch type LSD. They are viscous and as such don't care about modifyers like a clutch style LSD does.
Old 08-10-2010, 05:55 PM   #15
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Matt, feel free to rip this appart, but from my experience, after you pick the GL and weight as listed by the manufacturer (GL5 in our case), it's a matter of finding the brand that matches the best to your particular synchros for smooth shifting.
For example for my old '88 Toyota All-Trac Celica, the proper GL5 Redline fluid caused problems with shifting, whereas Redline MT90 in my MR2SC shifts fantastically.
Since Matt recommended Mobil 1 Delvac I assume that it works well with our syncros.
I have gone so far as to put ATF in my '91 All-trac box to help solve a balkly 2nd gear upsift (and wow what an improvement it made). However it was understood that it wasn't GL5 rated and maybe not so good for the Hypoid gears.
-Rob
rob is offline   Reply With Quote
Old 08-13-2010, 07:16 PM   #16
beaviscih
Member#: 123362
'93 Crapcan EJ22
FTW
I'm running 3Qts Redline Shockproof with 1Qt of Motul 300 75W-90. I tried this after reviewing some posts by Andrewtech. I have not had any issues, but will switching to one oil at my next change for the simple reason I don't want to futs with a blend, and quite frankly it seems odd to do this.
I also would like something that I can buy locally and not have to order, so it's good to hear feedback on the Delvac.
beaviscih is offline   Reply With Quote
Old 08-13-2010, 09:30 PM   #17
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 17 FoST
I used Uncle Scotty's cocktail once and it was great for a few weeks. But it degraded quickly. Personally I think if you don't mix the lubes that it will be more consistent over time. But I can't really prove anything and just go by what my perception was of the cocktail.
scrappydoo is offline   Reply With Quote
Old 08-16-2010, 02:11 PM   #18
sharp2whlz
Member#: 255024
Default Mobil 1
I always used the Mobil 1 Delvac and it seemed to work great....smoother and quieter....but I think it had been neglected before I got it.
sharp2whlz is offline   Reply With Quote
Old 09-14-2010, 07:38 AM   #19
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
I use OEM Subaru Extra-S Gear oil.... it definitely made a difference!
sizzflair is offline   Reply With Quote
Old 09-17-2010, 04:32 PM   #20
basel_520
Member#: 257798
i like redline MTL 90, makes me happy. ive tried castrol 90w. MTL is alot smoother.
basel_520 is offline   Reply With Quote
Old 09-17-2010, 09:09 PM   #21
RealDealTarheel
Member#: 142447
2018 F-150 Lariat
17 Focus RS
I've used Uncle Scotty's transmission cocktail on a 94 WRX that I thought for sure the 2nd gear synchro would need to be replaced on, it cleared right up after I changed it. What was the change interval between the cocktail and the previous 75W-90 oil I used??? 2 weeks. Run what ever you like, don't trust what people say on the internet, get some real world experience and use what you find to work.
RealDealTarheel is offline   Reply With Quote
Old 09-21-2010, 11:48 PM   #22
Jarrod164
Member#: 253937
1995 WRX
Ok I'm a total noob when it comes to cars so don't get too frustrated... I learn as I go =P
I just imported a JDM 95 WRX and I need to change ALL of the fluids in the car. I guess I didn't think about the differentials in the car and didn't realize until today that the rear one needed a fluid. So am I correct in assuming that when you talk about the gear box oil, that is just the transmission fluid?
And I guess there is a drain and filler area for the rear differential, I hope I can find it heh. I hope I can find some photos but I'll probably be able to point it out and change it.
The car arrives on Thursday so I want to get things done slowly to it and make sure I do it right!
Thanks for the help!
Jarrod164 is offline   Reply With Quote
Tire Chains - What kind to use? OBSinSDCA Brakes, Steering & Suspension 8 02-16-2015 03:59 AM
I have my dealers license, great deals for my friends AKA all of you. sleepysubie Rocky Mountains Impreza Club Forum -- RMIC 35 11-20-2009 03:02 PM
while searching for redline gear oil for my front/rear diffs... kaisersouse Service & Maintenance 4 04-25-2006 06:59 PM
need info on how to flush antifreeze and what kind to use as replacement jbsubie Service & Maintenance 6 03-25-2006 08:44 PM
best gear set for my 2002 wrx? wrx2nv[erc] Transmission (AT/MT) & Driveline 5 10-15-2003 11:17 PM
