Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2022
Old 08-18-2006, 09:44 AM   #1
WRXINTX
Member#: 96712
Default any special procedure to remove Cam pulleys on 2.5 STI engine?
Hello all....
is there anything special about removing pulleys from 2004 STI 2.5 AVCS heads???
having problems....
only have a service manual for a 2003 2.0L WRX without AVCS....
Thanks...
RYNO
WRXINTX is offline   Reply With Quote
Old 08-18-2006, 12:01 PM   #2
benw
Member#: 103320
1998 swapped
Forester L
shoot me a PM and I'll send you some service manual pics tonight when I get off work. I've got it on CDROM at home
benw is offline   Reply With Quote
Old 08-18-2006, 12:09 PM   #3
TheMadScientist
Member#: 23717
2005 Big red
Good luck.
They can be a bitch doing it alone. All but the last one I took off came off with the impact gun. The last one I had to remove broke the alen bit for the gun. I had to use a 10mm alen key and a hammer with a second person holding the cam gear still with the old timing belt.
TMS
TheMadScientist is offline   Reply With Quote
Old 08-18-2006, 12:31 PM   #4
WRXINTX
Member#: 96712
Thanks guys... we finally got it loose...
It took a miracle from GOD, a 6 foot cheater pipe, and 2 big oilfield rednecks to break them loose.... and the engine was on a stand....
Hard to believe that got that tight....
Thanks again!!!
RYNO
Old 08-18-2006, 01:31 PM   #5
dlowman
Member#: 22998
2004 WRX STi
GT35R 572 whp 93/meth
lol yeah I remember doing this. It is a major pita
dlowman is offline   Reply With Quote
Old 08-18-2006, 01:41 PM   #6
TheMadScientist
Member#: 23717
2005 Big red
Thanks again!!!
RYNO
Next time instead of steady force with a cheater bar. Shock an normal size alen wrench with a hammer, just make sure you go in the correct direction. Shock forces on a nut or bolt will break it loose a lot easier than a steady gradual build up like with the cheater bar.
TMS
Old 08-24-2006, 03:23 PM   #7
[email protected]
Member#: 106514
http://www.cobbtuning.com/pr-cam-wrench.html
We do not have a cam gear tool currently for the AVCS gears, but hopefully in the near to distant future. Having the correct tools really help the job go alot faster.
- J.
Jeremy@Cobb is offline   Reply With Quote
Old 08-24-2006, 03:32 PM   #8
InfamousDX
Member#: 25413
nice..... like the subie removal tool but cheaper. you should post this in the cam gear removal thread in Built Motor.
InfamousDX is offline   Reply With Quote
HELP: Advice on 2.5 Turbo engine blue05wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-23-2009 02:55 AM
STI intake manifold on 2.5 RS engine SubeSTIle Subaru Conversions 10 02-16-2007 03:15 PM
Oil psi sending unit install location on 2.5 Turbo engine? BIGDLM Baja Forum 2 10-16-2005 04:14 PM
You want a 2.5 STI engine? HOK Canada Region Forum 2 05-16-2003 09:15 PM
Obtaining 2.5 Sti engine. Sakuraba STi Forum Archive 58 01-26-2003 07:44 PM
