02-07-2008, 08:36 PM | #1 |
Member#: 58131
NWIC
Vehicle:05 STi 6,879 miles 04 Forester XT |
Best EM for supercharged application???
The vehicle is a 98 OBS. 6 speed swap with matching gear all the way out to the hubs. 4 pot / 2 pot calipers with matching rotors. The motor will be a 2.5l of ''some kind.''
What would be some of the best engine managements to run if you're intending to run a positive displacement supercharger? If the vehicle were wired for a wrx harness / engine, would a UTEC or Cobb AP be able to offer enough ability to tune the normally aspirated portion of the fuel and ignition maps? I was looking at AEM and Greddy's generic forms of EM and they look like they would be pretty useful for offering a wide scope of ability to tune the fuel and ignition maps for normally aspirated as well as forced induction states. I'm very familiar with tuning Hondas for supercharged forced induction and I'm trying to look at this Subaru similarily in that the Honda motor ran NA most of the time until the throttle pedal was past about 3/4 throttle, so the NA portion of the fuel and ignition tables required just as much tuning as the boost tables for fuel and ignition. Basically the plan is to put the engine together, install it as well as the fuel delivery system intended for the forced induction and get it running very well NA first. Then I'll install the supercharger, build crude maps for fuel and ignition, and dyno tune after that. I could leave the stock harness in place, install a built 2.5 RS engine and use AEM or Greddy's generic EMs or wire it for a WRX harness and ECU (which I already own) and build a 2.5l STi / FXT engine and go from there. I don't really care about the ability to tune AVCS if the engine I run has it. What do you think?
02-08-2008, 12:13 AM | #2 |
Member#: 170215
SCIC
Vehicle:2003 Toyota Tacoma |
EM on your mut sc project
If you're going to use a WRX harness, I would imagine the best bet would be the AEM. Have you seen the list of features on that thing too?
02-08-2008, 10:04 PM | #3 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
depends on what head you use the aem won't work as the cam pickups are different on the 98 head
you would also have to change the crank trigger start thinking about a hydra |
best em for 02 rex | 4Play | Engine Management & Tuning | 2 | 02-25-2006 05:13 PM |
the best turbor for my application | superdupersubaru | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 11-15-2005 10:23 PM |
Best EM for my setup? | Propaganda | Engine Management & Tuning | 1 | 05-29-2005 03:01 PM |
Best Downpipe for my application? | RobPA | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 03-26-2002 02:57 AM |
What's the best box for my application? | CRAZY KEN | Car Audio, Video & Security | 1 | 02-15-2001 07:33 PM |
