Welcome to the North American Subaru Impreza Owners Club Friday May 27, 2022
Old 01-18-2022, 02:10 PM   #1
yaffirious
Member#: 517334
2005 Impreza WRX
Aspen white
Default What nut is used for 05 WRX rear diff studs?
I called Subaru to order a stud for the rear diff on my 2005 WRX and they had no idea what nut is used with this stud. Does anyone know what nut should be used and/or a part number?
Thank you so much!
yaffirious is offline   Reply With Quote
Old 01-18-2022, 05:08 PM   #2
ether947
Member#: 297799
2003 WRX
EJ207 version 8
The parts are listed in two different sections. I found the studs but couldn't figure out the lock nuts. Someone from IWSTI was having the same issue and figured it out.
Lock Nut - 383875200
https://parts.subaru.com/p/SELF-Lock...902350027.html
Stud - 800912060
https://parts.subaru.com/p/STUD/49286614/800912060.html
FastWRX sells a kit too, but it seems a little pricy.
https://www.fastwrx.com/products/sub...2456e2da&_ss=r
ether947 is offline   Reply With Quote
Old 01-18-2022, 07:17 PM   #3
yaffirious
Member#: 517334
2005 Impreza WRX
Aspen white
Stud - 800912060
You rock, man!!! Thank you so much!!!
