Welcome to the North American Subaru Impreza Owners Club Sunday June 4, 2023
Old 06-05-2002, 01:58 PM   #1
slidesquad
Member#: 17944
Question WRX Instrument Cluster wiring diagram
Does anyone have the wiring diagram for the WRX instrument cluster?
I need it to track down the wire that leads to the VSS.
Thanks!
slidesquad is offline   Reply With Quote
Old 06-05-2002, 02:45 PM   #2
silvercharged
Member#: 19295
The vehicle speed sensor has 3 wires coming out of it. Green w/ black tracer(stripe), Green w/yellow tracer, and Black w/ red tracer.The wire you want is the Green w/ yellow tracer. This wire goes from the VSS to the connector that plugs into the Instument cluster's printed circuit board (Called by Subaru - Combination meter custom CPU). Note, that if you have an Automatic trans this wire also goes to the Auto trans control module, and in both trans cases (Auto and Manual) it also goes to the ECU. Hope this helps....
Joe
silvercharged is offline   Reply With Quote
06 STI Cluster Wiring Diagrams quaam Electrical & Lighting 1 10-24-2006 10:15 PM
Gauge cluster wiring diagram 04scooby Interior & Exterior Modification 0 09-07-2006 09:42 PM
2000 Impreza RS Instrument Cluster Wire Color Code Sunrise City Rider Subaru Conversions 0 04-21-2003 08:11 PM
Instrument Panel Wiring Diagram? mesocyc Newbies & FAQs 0 08-22-2002 12:10 AM
Instrument cluster wire harness question cyborg7_ Normally Aspirated Powertrain 1 06-20-2002 12:40 PM
