Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 10-14-2002, 07:43 AM   #1
Pierre
Member#: 25068
Default Oil Change @ 1000 Miles?
I have an '03 OBS and my dealer told me I need to get an oil change after the first 1000 miles. I asked him why, and he can't seem to put together an explanation for me. Does anyone know if this is true, or does he just want me to give him some more money? Thanks.
Pierre is offline   Reply With Quote
Old 10-14-2002, 07:45 AM   #2
Thug
Precious ❄
Member#: 603
It's to flush out any metal shavings of a freshly broken in motor.
Thug is offline   Reply With Quote
Old 10-14-2002, 07:56 AM   #3
jamz
Member#: 8725
2013 Black Company
Annalist
Subaru doesn't recommend it, but I did it anyway- the first miles on the motor will be the hardest- when all the freshly-assembled parts start working together for a long time. It can't hurt, that's for sure.
jamz is offline   Reply With Quote
Old 10-14-2002, 08:08 AM   #4
DustinR
Member#: 8264
2001 Impreza 2.5 RS
95 Impreza 1.8 Coupe
what they said. Changin your oil never hurts and helps alot. Expecially when new. I did mine and 1 and 3k.
-Dustin
DustinR is offline   Reply With Quote
Old 10-14-2002, 02:01 PM   #5
Snowphun
Member#: 1800
It could hurt if the initial oil that the manufacturer put in the car has additives to aid in the break in process. Not saying that Subaru does this, but people on this board have suggested Subarus (and others) do. I waited until 3k miles, changed to synth at 10k.
Paul
Snowphun is offline   Reply With Quote
Old 10-14-2002, 02:12 PM   #6
jfalcon001
Member#: 23062
2002 Impreza WRX
Paul is right. Infact SOA recommends the first oil change occurs after 3,750 miles... yes i called them. And then the second at 7500 miles. I would change to full synthetic after those two periods... which would be 15000 miles.
Justin
jfalcon001 is offline   Reply With Quote
Old 10-14-2002, 02:16 PM   #7
DustinR
Member#: 8264
2001 Impreza 2.5 RS
im pretty sure my manual said to change after 1k don't know what would make any difference in that from 01 to 02 but ooh well not that it really matters now
-Dustin
Old 10-14-2002, 02:21 PM   #8
rkkwan
Member#: 5596
2010 Honda Fit Sport
Hahaha... One of the two most common questions asked on i-club. "When should I do my first oil change?" "When should I switch to synthetic?"
There are as many answers as there are i-club members. Really. I've seen answers to the first question from "immediately", "600", "1000", "3000" to "3750. Answer to the second is even more varied, with addition answers like "5000", "7500", "10K", "never", etc...
So, it's basically pointless to ask, unfortunately.
-Ray
rkkwan is offline   Reply With Quote
Old 10-14-2002, 02:34 PM   #9
Karl
Member#: 13110
If you are worry about your oil, get it tested.
I got mine tested at Blackstone lab and the result will tell you how your engine is doing.
If anyone wants to see the report on my engine, let me know. I will find a way to host the pdf file they send me.
Karl is offline   Reply With Quote
Old 10-15-2002, 11:28 AM   #10
staninct
Member#: 5393
2010 Mercedes
ML450 H -100% Subaru Free
Our dealership offers a 1000 mi service for free to new owners for the metal shavings, and also to make sure everything is breaking in properly, belts are right tensions, fluids are right colors, tires properly inflated, and so on. Also helps many non-car nuts get into the habit of servicing their car. At least that's how a salesman like me explains it!
staninct is offline   Reply With Quote
Old 10-15-2002, 11:30 AM   #11
JGard
Member#: 1904
2017 Impreza Sport
E36 M3/4/5
on my 00 RS, it said to have the first at 1000 miles.
On my next new car, I'll be changing it around 50 miles.
JGard is offline   Reply With Quote
Old 10-15-2002, 11:56 AM   #12
neuromancer
Member#: 5973
2005 Scion tC
I too changed my oil after the first 1000 miles. I am pretty sure the dealer did it free of charge or it was part of my extended service contract.
Karl, if you could post the results of your oil analysis, I would definatly be interested in seeing them. At how many miles did you have this done?
neuromancer is offline   Reply With Quote
Old 10-15-2002, 12:03 PM   #13
mattnis
Member#: 25326
2002 WRX Wagon
1000 is too early, 1500 is a better first oil change mileage.
Now this is very important....if you are braking in your engine by not revving above 4k rpms then get the first oil change at 3000.
I got my first oil change at 1500 miles but I was high revving the engine frequently. That oil still came out perfectly clean.
There is no reason to change the oil soon if you are gentle with the car. It is very important to break in the engine by either driving gently for 1000 miles then getting oil change at 3000 or driving hard from the beginning and getting oil change at 1500 miles.
mattnis is offline   Reply With Quote
