04-19-2010, 08:23 PM | #1 |
Member#: 32951
RMIC
New clutch whine when pedal is engaged - help!
Car has 72k on it. I just started noticing a whine that sounds similar to a power steering whine when you are low on fluid. It only sounds when i push the clutch pedal in and it sounds like it is coming from the firewall. master cylinder seems to be at the full mark on the fluid. Does anyone know what this could be from?
04-19-2010, 08:25 PM | #2 |
Member#: 41762
International
Vehicle:04 STi in ur Floriduh |
Release Bearing? (Throw out bearing)
04-19-2010, 09:28 PM | #3 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
Does it do this all of the time or only when it's been raining out or it's wet/damp/foggy out?
I too say throw-out bearing. If you're going to replace it, replace the clutch at the same time. |
04-19-2010, 11:33 PM | #4 |
Member#: 32951
RMIC
It does it all the time regardless of humidity/moisture.
Is this premature failure of the throwout? Not sure what the usual life is but 72k seems early for anything transmission related. |
06-02-2010, 11:23 PM | #5 |
Member#: 232672
AKIC
Vehicle:2003 Impreza WRX Rally Blue |
This sounds similar to a problem I am having with my 2001 RS. Everytime I put in the clutch to change gears there is a whirring (whining) noise from the front of the car. Did you find out for sure if its the throwout bearing?
06-03-2010, 12:17 AM | #6 |
Member#: 32951
RMIC
I took it to one shop and they couldn't hear it. They said that to wait until the clutch goes out. I'm just driving with it and hopefully I can get a clutch/flywheel in the fall.
06-03-2010, 02:19 AM | #7 |
Member#: 232672
AKIC
hmmm, ok. Yeah, I am hoping to have a shop guy take a listen and see what they say.
06-03-2010, 12:42 PM | #8 |
Member#: 133814
SCIC
Vehicle:2004 WRX JBP |
Throw Out Bearing!!!
double-clutching upshifts when tranny is cold | Mike Wevrick | Transmission (AT/MT) & Driveline | 14 | 12-07-2010 11:20 PM |
Car rolls when gear is engaged when parked | dsolis | Transmission (AT/MT) & Driveline | 11 | 05-14-2008 11:01 PM |
not in WOT when pedal is all the way what would the problem be? | Syms-STI | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 19 | 11-01-2005 04:25 PM |
Clutch noise when car is on. | LESLIEx317537 | STi Forum Archive | 5 | 08-07-2003 04:21 PM |
Weird noise when 1st is engaged? | STIRS | Newbies & FAQs | 4 | 06-12-2003 06:31 PM |
