08-30-2013, 08:24 AM | #26 |
Member#: 321409
SWIC
Vehicle:2003 Big Effing Van 7.3L powerstroke diesel |
Since everything was good in your wot pull and your problem keeps showing up in cruise then I would suspect the front 02 sensor is failing. As soon as you get that wideband on there you can compare AFR's.
08-30-2013, 09:59 AM | #27 | |
Member#: 232458
SWIC
Vehicle:2005 & 2008 STi Cobb 20g & EFR 7670 |
Lot's of progress made Joshua! If you fill up with Ethanol remember that it's not quite E85, rather E73 now. So tune your injector scale accordingly. If your O2 sensor is failing then the knock may be legitimate due to poor/false corrections. Seems like you are really close in figuring out your issue! Keep up the good work. |
08-30-2013, 10:04 AM | #28 | |
Member#: 323310
SWIC
Vehicle:2002 WRX Wagon Silver |
I found more paperwork on all the work done on my car though. My injectors are 812cc/min. Joshua |
08-30-2013, 10:16 AM | #29 |
Member#: 232458
SWIC
Gotcha. You should get the E85 retune later if you deem it necessary.
Right now what you can do (to get you running on ethanol) is pull the 91oct map off of your car with your tactrix, open the map in ECUFlash/RomRaider and find the injector scaler. It should be around 812cc (give or take). Multiply that injector scaler whatever the number is by .72 (which should make it now ~584cc). Make sure your scaler is now ~584cc in that box. Now save that map and name it something along the lines of E85_Troubleshooting_Map. When you fill up with E85 flash that and log the car. Those settings should get your fueling close. I don't know how aggressive your old E85 map is, but I will bet it's more aggressive then your current 91oct map. So what your are doing by modifying your injector scaler on your 91oct map is keeping the 91oct map timing/boost/ect...and making it a really safe E85 map for troubleshooting. Last edited by wgr73; 08-30-2013 at 10:26 AM. |
08-30-2013, 10:25 AM | #30 |
Member#: 232458
SWIC
Let me know if you need help.
08-30-2013, 10:30 AM | #31 |
Member#: 321409
SWIC
That would be all fine Winfield if his 91 map was dialed in. Since his cat pretty much fell out of his downpipe is it possible that he needs to touch up his fueling on his 91 map first due to less restriction?
08-30-2013, 10:34 AM | #32 |
Member#: 323310
SWIC
Okay, I get it. I'm just making the ECU think the injectors are smaller so it will increase the pulse width to match the current fueling map. I will pull my map today and see what I can find. Thanks.
08-30-2013, 10:36 AM | #33 |
Member#: 323310
SWIC
I still have an intact honeycomb in my cat. It looks like the front half came apart but the back half still exists. There is not a passage around the honeycomb structure at all.
08-30-2013, 10:38 AM | #34 |
Member#: 321409
SWIC
Edit I guess my question to winfield should be if maf needs rescaling? I think I would have completely gutted it anyways.
08-30-2013, 10:54 AM | #35 | |
Member#: 232458
SWIC
I agree, gutting it would've been a good idea since it's not needed and isn't going to help anything in that condition. No his maf shouldn't need to be rescaled. As long as his intake is still the same and that scaling was correct. |
08-30-2013, 10:58 AM | #36 |
Member#: 232458
SWIC
I just thought of something. Joshua, do you still have your rear O2?
08-30-2013, 11:08 AM | #37 |
Member#: 323310
SWIC
Still have my rear O2. Cat is out of the car still so I can gut it. But if I move to a state where I have to pass emissions, won't that cause problems?
08-30-2013, 11:24 AM | #38 |
Member#: 232458
SWIC
Rear O2 effects fueling as well, so if your cat is junk/deleted then it may effect your fueling up to 7%(?). Disable your rear O2 (CEL) sensor in ECUFlash and unplug it.
If you move to a state where you have to pass emissions it may. If its only a sight inspection then you can probably pass. You're not thinking about leaving us are you?! :P |
08-30-2013, 11:56 AM | #39 |
Member#: 323310
SWIC
Yeah, I really am thinking about leaving. Been planning on moving further west sine I moved here. Probably December/January.
I will leave my cat as is. I may try unplugging the rear O2. how do I disable the CEL for it? |
08-30-2013, 12:42 PM | #40 |
Member#: 321409
SWIC
From what you describe Joshua, half your cat is gone anyways. Would it pass emissions in it's present state? Who knows, but whatever caused the front part to break up (high heat etc.) may have effected the rear to be brittle as well. I'd gut it and be done with it. Just keep the car registered down here at your sisters.
08-30-2013, 02:30 PM | #41 |
Member#: 323310
SWIC
Unplugged and disabled the Rear O2 Low Input CEL. Still no dice. Lots of FLKC in the same place. Cat is still intact. Still waiting on the wideband to show up. It may be at the post office now actually.
I'm pretty sure my cat came apart due to a rock. I tend to find lots of rocks with the underside of my car :/ Joshua Last edited by joshuajayg; 08-30-2013 at 02:43 PM. |
08-30-2013, 06:03 PM | #42 |
Member#: 232458
SWIC
Hey Joshua, sorry I was away from my computer. Darn, sucks that didn't work. :-/ Wideband comparison should be next.
08-30-2013, 06:32 PM | #43 |
Member#: 323310
SWIC
I got it in the mail but won't be able to weld in the bung until Sunday probably. I'm headed to Roswell tomorrow afternoon and don't have a welder here. Would forcing open loop do me any good? I'm excited I can finally take a look at my map.
08-30-2013, 08:25 PM | #44 |
Member#: 323310
SWIC
Meh
08-31-2013, 09:13 PM | #45 |
Member#: 323310
SWIC
Ran E85 today. Still the occasional FLKC or FBKC but it the FLKC clears itself very quickly. I also had 4 gallons of 91oct in the take so if the E85 was 73% ethanol, that leaves me at 53% ethanol content. I changed my injector flow scaling from 824.08 to 595.88. The A/F learning was a lot happier with max learning usually +8% max.
Installing my AEM UEGO in a couple days, checking the plugs at that time as well. Joshua |
08-31-2013, 10:54 PM | #46 | |
Member#: 232458
SWIC
Seems like you got your scaling pretty ball park. So my guess is something is rattling to cause the knock. Even E53-ish shouldn't knock at low loads (probably not even under high load). Good work, keep us updated! |
09-06-2013, 04:37 PM | #47 |
Member#: 323310
SWIC
Alright, time for an update.
My plugs looked kind of like they were soaked in salt water. They had a layer of brown, gritty stuff on them. The plugs I removed were NGK PFR6G. I replaced them with NGK BKR7EIX. Gapped .029 in. out of the box. Dynamic compression test indicated: 120 - 130 - 130 - 135. I installed my AEM UEGO today about 18 inches behind my turbo. I have a few logs I will post up. I'm still getting knock and eventually my IAM dropped. Graphing A/F Sensor #1 against the AEM in RR shows very similar indications between the sensors with a very slight lag in the AEM due to its distance from the first sensor. I finally got a hold of my tuned E85 map. We will see how that goes once I get a bit of E85. Here are the logs: https://dl.dropboxusercontent.com/u/...s%20WB%201.xls https://dl.dropboxusercontent.com/u/...s%20WB%202.xls Joshua |
09-06-2013, 07:43 PM | #48 |
Member#: 321409
SWIC
09-06-2013, 09:32 PM | #49 |
Member#: 323310
SWIC
I can't do a leak down test, I don't have the equipment. I'm not sold on the cracked ringland. I am not a big fan of the dynamic compression tests due to their inconsistencies. The gauge I used is marked in intervals of 5psi. I rounded to the nearest five. And, if I turned the engine over four revs instead of three that will change the reading. Basically, 12.5% difference doesn't tell me anything other than I don't have an obvious big issue with a cylinder.
09-06-2013, 09:55 PM | #50 |
Member#: 321409
SWIC
^^^ it also depends on hot or cold engine. I said "may". Right now I am just trying to figure out what is triggering your knock sensor.
