01-21-2018, 12:16 PM | #1 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
KillerB Spoolinator users install and build thread
My goal is for this to be the thread for owners who run the Spoolinator setup, to show and list build specs, and even dyno charts if possible. I can't find a better forum to fit this into, since you can run this setup on anything from a modified 93 impreza up to an 07 wrx sti.
My build is going slowly, mainly because of the constant ordering and waiting on tiny random gaskets, bolts, etc but also because I want it done "right" the first time around. The parts I chose aren't to make a 1000hp monster, but for something 500whp+ that I can street and not worry about. I'm not converting to a fuel cell or demolishing my trunk space and spare and tools, the goal is a sneaky "street" car that can be driven on trips. I will eventually find a way to get some pics of the progress up, but at this point the only parts assembled are the extremely built longblock done by Larry's in CT and a few bolt ons. I installed the KillerB cast pan with pickup and windage tray. Also got all timing components and covers installed recently, and still need to adjust the outer bolt holes in the 2.5i intake manifold. It's going to be facing rearward oem style, so getting the intercooler piping in there is probably going to suck, especially since it will have a drive by cable oem throttle body with aluminum adapter pushing it back. Another member mentioned the transmission housing needing to be ground, I thought only the engine needed it. This puts another twist in the build because the room for this at my workplace is limited, so having the engine bolted to the trans just for grinding for turbo clearance would be a big deal. If someone with the Spoolinator setup could post some pics and maybe even any helpful tips on the block and trans grinding, it would be appreciated. Obviously these kits are relatively rare considering how most would rather a quick bolt on solution, but maybe this thread will give more the opportunity to see what the install entails and what the benefits can be. I've seen dyno charts of a few setups and there is obviously a more usable and streetable power band. KillerB is making some instructional vids soon, but I'm not sure they will make one for this kit. Parts list so far: Longblock- -Larry's Auto Machine AEBS sleeved and O-ringed, pinned mains, case with oil mods -Manley I beam rods -Manley pistons with upgraded pins -OEM 79mm crank -King bearings -oem 11mm oil pump -ARP case bolts -EJ205 heads with CNC modified chambers and CNC ported int and ex by Ken Carlson of Larry's Auto Machine -14mm head studs -GSC valve guides -GSC S2 cams -GSC +1mm valves -GSC springs -JE headgaskets Supporting mods/externals- -KillerB Spoolinator kit with GTX3576r G2, downpipe, adapter, etc -KillerB oil pickup and windage tray -KillerB extra capacity cast oil pan -IAG fuel rails -All fuel lines ptfe -Injector Development 2000cc injectors from Corr Performance -Haltech Elite 2500 ecu from Corr Performance where it will be tuned -Haltech alcohol sensor -Innovate or ? wideband and controller (not purchased) -DWR2000 fpr -DW400 + ? brand pump speed controller -8AN ptfe from tank to engine, 6AN ptfe from return to tank -Perrin FMIC designed for 02-07 -Custom intercooler piping, see below v -Custom "cat"back exhaust at DD Performance Research Drivetrain- -2011 6mt and rear diff -ACT HD single disc clutch and streetlite fw -DSS carbon center driveshaft -Oem front gd axles -Oem rear gc axles with Suberdave inner race adapters -Torque Solutions Poly engine and trans mounts
01-21-2018, 01:47 PM | #2 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
I'll share some pics and info on the install with our shop 2012 STi This was with a GTX3576-R Gen I.
Here's the block grinding. There's no reason the trans should need to be ground, only the bellhousing on the block. Here's another shot from the back... Side shot... |
01-21-2018, 01:49 PM | #3 |
Member#: 198281
Looking forward to your progress. If you, or anyone else, has any questions I'm here
01-21-2018, 02:45 PM | #4 |
Member#: 140444
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
I'd love to see data logs of 3rd-gear pulls from those GTX3576 setups. Or anyone else's.
(I don't trust dyno charts to show realistic boost curves, I've got one that shows my turbo waking up 1000 RPM later than my logs.) |
01-21-2018, 03:02 PM | #5 |
Member#: 90539
South East
I'd love to see posts from owners who run the spoolinator setup, but thanks for the free bump
I will try and get logs from the tuner when things are finally rolling. They tune on a DD so at least there's no fluff. |
01-21-2018, 08:10 PM | #6 | |
Member#: 198281
Here's the E85 |
01-23-2018, 01:24 PM | #7 |
Member#: 108091
Vehicle:2002 WRX |
So of you be willing to share those logs killer b
04-05-2018, 10:23 PM | #8 |
Member#: 90539
South East
A few pics, not perfect but should hold up fine.
04-26-2018, 04:58 AM | #9 |
Member#: 154608
HIIC
Vehicle:2004 Sti WRB |
Thinking about this kit on my 04 Sti. I’m currently stock block, Perrin ELH, up/dp/catback, FMIC, HTA Green with 50/50 meth seeing 380/430 dynojet PDX tuned, so wondering how much difference this’ll be. As much as I enjoy the top end of my setup, I miss my stage 2 Sti with the quick spool. If I can get that spool back with the power of my green or more, I think I’d give this a shot. I know my journal bearing green is old tech. Almost pulled the trigger on the Dom 1.5xtr, but just can’t make up my mind. Money isn’t an issue, just trying to keep my stock 66k mile motor together as long as I can before being forced into a built block
04-26-2018, 09:04 AM | #10 | |
Member#: 344329
Vehicle:2008 Wrx, 6mt |
I went with the full race stock location 7163, which I had to grind out the same spot on the block, FYI. IF I would have gone with the spoolinator-I could now easily swap in for a 3576 genII, since you always want more power . |
04-26-2018, 11:10 AM | #11 |
Member#: 90539
South East
/\ I got the 3576 gen 2, knew the power itch would happen. Should be pretty insane for the street. The 3582 is now available on the KillerB site, but that may be a hassle for daily or congested traffic driving.
04-26-2018, 01:23 PM | #12 |
Member#: 45574
SCIC
Vehicle:2004 CRP SG5 FXT 1998 Bright blue GM4 |
04-26-2018, 01:24 PM | #13 | |
Member#: 198281
I think we can still get the GTX3067-R hybrid which would put you down a bit on power compared to the 3071 or green, but your spool is super fast.; ^ I really can't say enough about the 3576. The compressor/turbine balance is ideal for the EJ25 engines; makes really great power and tolerable streetable response. The 3582 is more the big gun setup if you're looking for BIG power, are built for it, and don't mind the rev range to be in the 4,500-7,500 RPM range. For me the 3582 is more the weekend racer setup, but a bit too laggy for jetting in and out of traffic during 'normal' driving. not everyone will agree, but this is my take |
04-26-2018, 09:11 PM | #14 | |
Member#: 154608
HIIC
2slo thanks also for the info. The need for more never ends. Killer B great info. I like zippiness. Let’s just say I’m coming for a mustang GT 4.6 with 6psi from a whipple ***128520;. I just needed a more family friendly, quieter toy. Plus I owned an 04 Sti back in 07 in my broke college days. So nostalgia set in. Not to mention the Sti sounds way more interesting while driving with the turbo spooling and the blow off blowing off haha. |
04-26-2018, 09:17 PM | #15 |
Member#: 154608
HIIC
Just found out from a buddy that we can buy e85 from a shop on island. No e85 pumps out in the middle of the Pacific yet.
Since I barely use a tank of gas per 6-8 weeks, I might try the e85 route. I know my 850 injectors and walbro 255 probably won’t work. But which turbo with the spoolinator kit would be more suited for e85 on a stock 2.5 Sti motor based on what I’m looking for? |
04-26-2018, 11:00 PM | #16 |
Member#: 344329
Middle of the Pacific-Mmmmm Giovanni's!
I need me some garlic shrimp!! (Was there two months ago) |
04-26-2018, 11:33 PM | #17 |
Member#: 154608
HIIC
Garlic shrimp ftw! I think I'll head north shore this weekend with the sti and family in tow just because you mentioned it haha!
KillerB's idea of the GTX3067-R hybrid sounds sickening. Plus I can just swap turbo later when I get that inevitable itch |
04-27-2018, 06:58 AM | #18 |
Member#: 198281
So here is a really poorly done compilation of our 2012 STi with a GTX3067-R (hybrid). Even with my grandpa slow shifts you can see it builds boost incredibly fast. The slower scenes (around town and highway traffic) are just to show boost response dipping into the throttle under 'normal' driving conditions.
To add to this... This was on the middle Tial housing (0.82 A/R), but on E85 I would recommend the larger housing. It would definitely make more power than what we had, but should retain similar response on E85. |
04-27-2018, 12:48 PM | #19 | |
Member#: 154608
HIIC
Wicked boost response you have there! Thanks for sharing that vid!! I can already envision this setup on my Sti Grinding of the block: something I can do in my garage? I’m a home remodeling contractor and am pretty handy with tools. I use my 4” grinder quite often, but I’m not sure what to use on a car motor. How much material comes off the block? 1/8”, 3/16, 1/4”? Just a guestimate really. And about how much time to do said grinding? |
04-27-2018, 02:42 PM | #20 | |||
Member#: 198281
Here is the partial install of when we did it with the engine IN the car... |
04-28-2018, 12:09 AM | #21 |
Member#: 154608
HIIC
That doesn’t look that bad at all. Looks like once the turbo is out there’s room to grind away.
04-28-2018, 03:07 AM | #22 |
Member#: 154608
HIIC
Well it is my birthday in May, and I got a nice bonus from work, so I'm thinking of pulling the trigger soonish. Will update this thread with dyno results once I do. I just found the dyno graph from the current HTA green setup. Would be cool to only change to the spooinator setup and compare the two graphs and share with everyone here.
I noticed on the KillerB site on the drop down menu, "kit options", for the spoolinator kit that there are different prices for the same turbos. Can please advise? And where would the pricing of the GTX3067R fit in price wise? What Tial housing is larger than 0.82ar? Sorry for being noob here. Though I read a ton, it's going to take some time to really understand everything related to my sti. It sure is fun learning though! |
04-28-2018, 03:41 PM | #23 | ||||
Member#: 198281
1.06 is going to be the largest A/R for the Tial housing. This is what I'd recommend for E85, C16, or for racing only applications. Don't be sorry. Everyone one of us started where you are at some point |
04-29-2018, 12:10 AM | #24 | |
Member#: 362723
E. Canada
Vehicle:2002 WRX w/ V7 EJ207 WRB |
04-30-2018, 09:49 AM | #25 | |
Member#: 198281
The Tial and Garrett V-Band housings are on par performance wise (not tested, just what I've heard), but IIRC they do have difference geometry in regards to the v-band and in/out location. You thinking AMS intake manifold? I'd strongly recommend waiting on more independent testing/results on that one. From my understanding, you really see a benefit at very high power/flow numbers. Not really anywhere near where a 3067 would put you. If anything, I would consider going to the plastic WRX manifold as the smaller runner/bigger plenum would provide improved response AND better power. |
