Brakes & Suspension Forum sponsored by The Tire Rack |
04-17-2006, 11:03 PM | #1 |
Member#: 26529
Vehicle:04 STi White |
camber bolts in the rear... put them on if you want to be able to adjust them for competition. For street driving, I wouldn't worry about the rear camber.
04-17-2006, 11:52 PM | #2 |
Member#: 74589
Vehicle:2000 94 Infiniti G20 90 S13 Coupe |
bad toe kills tires not bad camber?
I installed springs on my car with almost dead tires so i decided against getting it aligned until i got new tires. i took the tires off and all 4 had MAJOR negative camber wear, the front is lowered 2 inches and the rear is lowered .7 inches. I put my stock wheels back on until i picked out a new tire and got my car aligned. after looking at the tires on the stock wheels after this alignment they seem to all be wearing evenly , even the rears which had no camber adjustment like all wrx's. is this because toe is the real reason for tire killage?
Before i put my new tires on do you guys think its worth getting camber bolts for the rear when its lowred less than an inch? |
04-18-2006, 02:48 AM | #3 |
Member#: 10313
SCIC
Vehicle:2002 WRX wagon silver |
bad toe kills tires not bad camber = true
Your tire wear issue is likely toe. How much wear you get from negative camber depends on how negative, and how you drive. Just the little increase you would get from .7 inches in the rear should make no difference at all. Drivers who corner hard are likely to wear the OUTSIDE of the tires if they don't have ENOUGH negative camber, though this is primarily true in front. For my setup, I've found setting camber at -1.5*F/-1.0*R, and toe at zero, rear yields a good balance and even tire wear. Your mileage may vary. |
04-18-2006, 07:34 AM | #4 |
Member#: 92551
Vehicle:2005 Saab 9-2X Black |
Toe being out of spec causes wear much faster, but camber causes solid wear, also.
04-18-2006, 01:04 PM | #5 |
Member#: 82311
SCIC
Vehicle:2006 Evolution IX Electric Blue |
Bad camber does cause wear. I had -2 degree's on my old car with 0 toe and I killed my tires. Toe will help the process, but when you have more weight on the inside of the tire then the outside. Of course there will be uneven wear.
04-18-2006, 01:31 PM | #6 |
Member#: 39514
SWIC
Vehicle:2003 WRX 2.5L Hybrid Mostly Blue |
Strange................... you do realize that -1.7 to -1.8 camber in the rear is not uncommon for a stock WRX. I don't hear massive reports of excessive tire wear.
I run -2.0 camber and +0.02 toe in the front. -1.6 camber and +0.02 toe in the rear. About 5K, 2 autoX, and 2 hours of actual track time on my new Max performance summer tires. No wear issues to report. To be safe, one can simply swap tires from left to right unless the are a corner specific tire. |
turbo bad or not bad | zblad | Newbies & FAQs | 4 | 03-11-2010 06:04 PM |
Does Rear Toe change if you change camber? | Boxer4Dad | Brakes, Steering & Suspension | 7 | 03-31-2009 09:25 AM |
kill or not to kill the roomate | WrxWonderWagon | Off-Topic | 52 | 01-15-2006 05:17 PM |
FS/WTB tires. (roger is bad mojo). Clipped tire. Tire useless. Need tire | TSDScooby | New England Impreza Club Forum -- NESIC | 5 | 11-05-2003 11:48 AM |
to toe out or not to toe out | TheWRX | Brakes, Steering & Suspension | 6 | 05-03-2002 11:42 AM |
