Welcome to the North American Subaru Impreza Owners Club Wednesday December 2, 2020
Old 10-27-2020, 12:49 AM   #1
knesek
Member#: 508145
2007 WRX Wagon
Default downpipe gurgle
I just installed a cobb catted downpipe and a cobb stage 2 91 map on my 2007 wrx and it's making this terrible gurgling noise. It's not like a burbling noise that I can tell but I may be wrong.
The noise happens always except idle and neutral. Accelerated, decelerating, or going a constant speed it's just always there. It's most pronounced when I accelerate though. I'm hitting target boost properly and not knocking.
I've also noticed that with the windows down or outside of the car I can't hear the noise, but inside it's very loud.
I thought it might be an exhaust leak but I've repeatedly torqued everything down properly and got new gaskets. HOWEVER I am missing the lower left nut that connects the turbo and downpipe.
Any ideas what this is? Should I double-check for an exhaust leak? Or is it normal?
Thanks .
knesek is offline   Reply With Quote
Old 10-27-2020, 03:42 AM   #2
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
I'd start off by getting the nut on that stud and seeing if that makes a difference. It's most likely leaking there.
snow_bound26 is offline   Reply With Quote
Old 10-27-2020, 01:39 PM   #3
knesek
Member#: 508145
2007 WRX Wagon
https://imgur.com/hCRO6Tp
I tightened everything up even more and put soapy water on the connections but couldn't see a leak. Here is a video of the sound. It is the garbage disposal sounding thing in the background. You can especially hear it at the end. It is significantly louder in person and overpowers everything else.
Does this sound like an exhaust leak? Also on my 2 minute drive I hit -9.58 knock. Would this be a misread because of the loud noise?
Old 10-27-2020, 01:44 PM   #4
ericsson
Member#: 208672
2013 WRX STI Limited
Obsidian Black
Here's what a BROKEN catalytic converter sounds like... See if it sounds similar to yours..
ericsson is offline   Reply With Quote
Old 10-27-2020, 01:56 PM   #5
knesek
Member#: 508145
2007 WRX Wagon
it sounds similar to that around 1:00 but a lot deeper and louder.
Old 10-27-2020, 09:09 PM   #6
knesek
Member#: 508145
2007 WRX Wagon
After many more hours I finally figure out that it was the downpipe shaking a little more and the muffler was hitting the frame and resonating back up the exhuast. Its an spt catback on the wagon so the fitment was already very very tight.
