Welcome to the North American Subaru Impreza Owners Club Thursday April 15, 2021
Old 06-04-2007, 11:02 PM   #1
Robstunner
Member#: 134222
2015 WRX Limited
ISM
Default 02 WRX Raw Fuel Smell (not the common one)
ok, so heres the problem. started smelling this, oddly only at night(cooler temps) and very rarely if ever in the day have i smelt it. it smells like its coming from in between the alternator and the intake manifold, right dead center manifold wise. i have a picture of the area. i haven't taken anything off to find a leak but i know its there b/c it smells pretty bad. anyone know what could be leaking?
Robstunner is offline   Reply With Quote
Old 06-04-2007, 11:16 PM   #2
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
Im going to say the one under the inlet. I also had this about a year and half ago and only in cold weather, i didnt bother with it and it went away,never came back. But some have it worse than others.
99subi is offline   Reply With Quote
Old 06-04-2007, 11:24 PM   #3
Robstunner
Member#: 134222
2015 WRX Limited
ISM
i dunno if thats it. its not as strong there. unless its leaking from the right side under the inlet
Old 06-05-2007, 08:16 AM   #4
turd_ferguson
Member#: 114609
2006 Legacy GT
That actually is the "common one". There are two hard fuel lines under the intake that are connected by a short rubber section. I would imagine it's spraying out of the rubber section somewhere.
Here's a post I made a long time ago with pictures:
http://forums.nasioc.com/forums/show...3&postcount=98
In my case, a few hose clamps took care of the problem.
turd_ferguson is offline   Reply With Quote
Old 06-05-2007, 08:55 AM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
There is also one that will leak on the other side of the IM behind the AC compressor. I have fixed that one a couple times for some people.
Tony
Old 06-05-2007, 09:53 PM   #6
Robstunner
Member#: 134222
2015 WRX Limited
ISM
thanks for the help.!
Old 06-09-2007, 01:43 PM   #7
Robstunner
Member#: 134222
2015 WRX Limited
ISM
Tony
how hard is it to remove and re-install the perrin turbo inlet?
Raw Fuel Smell/Leaking Fuel Line on WRX pumpkyn Rocky Mountains Impreza Club Forum -- RMIC 40 10-01-2020 06:48 AM
Raw Fuel Smell Inside Cabin - WRX Kenneth2000 Warranty Issues & SOA Problems 13 12-21-2012 10:28 PM
02 WRX slow to start/raw fuel smell tobylazur Service & Maintenance 4 05-21-2009 02:15 AM
Raw fuel smell - not the garden variety TSB kind? pieces Normally Aspirated Powertrain 1 12-15-2007 07:18 PM
I'm finally plagued with the raw fuel smell! Bubba G Vancouver Impreza Club Forum -- VIC 22 01-18-2005 12:18 AM
