10-26-2016, 12:07 AM | #51 |
Member#: 237145
SCIC
Vehicle:02 WRX 12 FXT |
10-26-2016, 05:02 PM | #52 |
Member#: 148974
SCIC
Vehicle:2017 Forester XT Prodigal STi 600whp |
Updated instructions on POST #2 for Arduino Nano.
10-27-2016, 12:41 AM | #53 |
Member#: 316476
SCIC
Vehicle:12 WRX WRB |
So i finished installing this kit. I flashed the map, start the car and then the check engine light came on. I checked the code in AP it says... ETHANOL SENSOR VOLTAGE LOW INPUT.
Can someone point me to the right direction to troubleshoot? Thanks! |
10-27-2016, 12:47 AM | #54 |
Member#: 148974
SCIC
Don't start the car until you have checked and made sure you are getting a reading by turning the ignition on and monitoring TGV voltage or Ethanol Raw.
10-27-2016, 12:51 AM | #55 |
Member#: 316476
SCIC
Ok.let me reset the ecu and try again. I did check the tgv voltage before using a multimeter before i installed it and it read fine. Well, 91 oct was reading like 9% ethanol.
10-27-2016, 12:57 AM | #56 |
Member#: 148974
SCIC
10-27-2016, 01:07 AM | #57 |
Member#: 316476
SCIC
Ethanol raw was fluctuating from 8 to 12. Final was 8.7. That was when the engine is running. When the engine was off. Ethanol raw was reading 8.4 to 8.7.
10-27-2016, 01:11 AM | #58 |
Member#: 148974
SCIC
10-27-2016, 01:12 AM | #59 |
Member#: 316476
SCIC
Ethanol raw was actually jumping a lot. Like it will jump to 34, back to 8 then 60, etc. I recorded a video. Im uploading now.
https://youtu.be/9RcADXW5bzk Last edited by peekeesh; 10-27-2016 at 02:30 AM. Reason: Added video |
10-27-2016, 01:19 AM | #60 |
Member#: 148974
SCIC
10-27-2016, 01:20 AM | #61 |
Member#: 316476
SCIC
Ok ill go buy one tomorrow. Thanks jeff. Appreciate the help.
10-27-2016, 08:26 AM | #62 | |
Member#: 220816
Vehicle:2018 Exotruck |
but those weird spikes at 1:11 & 1:40 are not normal |
10-27-2016, 10:32 AM | #63 |
Member#: 316476
SCIC
^^ i'm hoping swapping the cap from 10uf to .1 uf will fix this issue.
10-27-2016, 04:48 PM | #64 |
Member#: 316476
SCIC
So i swapped the cap and the check engine light never came back which is good. But the weird spikes still occur. Is this ok? Here's a datalog:
https://docs.google.com/spreadsheets...it?usp=sharing spoke too soon. change engine light came back on so i unplugged the kit for now. Last edited by peekeesh; 10-27-2016 at 05:26 PM. Reason: update |
10-27-2016, 06:08 PM | #65 | |
Member#: 148974
SCIC
I'm not sure why the CEL came on again, though. Hmmm. Did you ever see it go down to 0% with the engine running? |
10-27-2016, 06:32 PM | #66 |
Member#: 316476
SCIC
yes it did go down to 0% again. it's in the log.
should i try powering the Arduino using a voltage regulator instead of USB? By the way, the only difference i did on my install is i put some molex connectors between arduino and ff sensor and tgv so I can easily disconnect/connect in case i need to uninstall. rest are same, i powered flex fuel sensor from rear o2 harness. |
10-27-2016, 06:43 PM | #67 | |
Member#: 148974
SCIC
Other option is use a 3.3k ohm resistor and change this line of code; pwm_output = 1.11 To whatever gets you back to 9% ethanol, because changing the resistor will make the voltage go up a little bit. Try going lower, like 1.05, 1.00, etc |
10-27-2016, 07:01 PM | #68 |
Member#: 316476
SCIC
Ok, i'll try those and see what'll happen.
Also, I think I'll make another one. i have a nano and will follow your instructions from post #2 |
10-27-2016, 08:21 PM | #69 |
Member#: 148974
SCIC
Arduino Uno powered by USB car charger:
use pwm_output = 1.08 * [rest of code] with 3.3k ohm resistor and 0.1uF capacitor. I confirmed this is pretty rock steady. |
10-27-2016, 08:25 PM | #70 |
Member#: 316476
SCIC
Sweet. Ill go test it out. Will report back and will let you know the outcome.
This time, ill monitor the output thru sketch and see if there will be spikes. |
10-29-2016, 01:26 AM | #71 |
Member#: 316476
SCIC
I think i made a stupid mistake. I may have grounded the flex fuel sensor to the wrong wire on the rear o2 harness. I think i tapped it to the wire that feeds the rear o2 signal to the ecu.
I found out because i tapped the aem uego to the rear o2 harness as well and it was not showing accurate data on the ap. It is stuck at 10. So i rechecked your other thread and found out what i did wrong. I will reinstall the kit tomorrow and flash the flex fuel map and see how it goes. Hopefully that takes care of it. By the way, I also changed the resistor to 3.3k ohm and updated the pwm output on the code as you've suggested. |
10-30-2016, 12:25 AM | #72 |
Member#: 316476
SCIC
I plugged the kit again today and drove for about 30 mins. i still get spikes on Ethanol %. it's not as often as before though.
Here's the datalog: https://docs.google.com/spreadsheets...it?usp=sharing Spikes occur at rows 650, 3658, 3956. Are these normal or they shouldn't be happening at all? Jeff, do you even see similar spikes on your set up? Last edited by peekeesh; 10-30-2016 at 04:58 AM. Reason: update |
10-30-2016, 11:22 PM | #73 | |
Member#: 148974
SCIC
10-30-2016, 11:36 PM | #74 |
Member#: 316476
SCIC
Ok. I guess this kit ain't gonna work with my car.
I thought maybe the issue is related to power since i tapped the usb to ignition using fuse taps. So i went ahead tried powering it using the rear o2 harness and as soon as i start the car, the ethanol % drops to 0 thus triggering cel. It cuts power when the engine cranks. |
10-30-2016, 11:40 PM | #75 | |
Member#: 148974
SCIC
Is the cap wired properly in the RC filter? Properly grounded, too? |
