Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Old 11-15-2019, 10:24 PM   #1
mEmENT0m0RI
Member#: 365299
Default 2019 STI Smell from the vents
Non-exhaust like smell coming from the vents. Comes and goes, most often happens after starting the car up.
Took to the dealer several times. Last time made the dealer perform pressure test on the cooling system.
What else could it be?
mEmENT0m0RI is offline   Reply With Quote
Old 11-16-2019, 06:55 AM   #2
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Non-exhaust doesn't tell us much. What does it smell like? Old socks, strawberries? More info would help here.
A 2019 is probably too new for mold/mildew buildup in the evaporator but anything's possible. Pull the cabin filter and see if there's anything there.
Mulder is offline   Reply With Quote
Old 11-16-2019, 10:28 AM   #3
CoronaWRX
Member#: 431618
Are you using your AC when getting these smells?
CoronaWRX is offline   Reply With Quote
Old 11-16-2019, 05:05 PM   #4
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
The ventilation system is designed to automatically cycle the a/c compressor, even though the controls and/or notification (mode setting display) do not say/state that the a/c is on and/or in use.
Therefore, depending on the outside and inside atmospheric conditions, when the a/c cycles, you will get an odor, whether or not it definitely smells like mold or mildew.
Big-E is offline   Reply With Quote
Old 11-18-2019, 06:02 PM   #5
mEmENT0m0RI
Member#: 365299
Definitely more like strawberries than old socks . I replaced cabin filter (nothing weird on it) - did not help. Hard to describe smells with words, If I were to guess, it smells like car-wash detergent.
I normally wash the car myself, only took it through the car wash once about a year ago. Is it possible for that stuff to accumulate somewhere for such a long time?
Old 11-18-2019, 06:04 PM   #6
mEmENT0m0RI
Member#: 365299
It did smell a bit in the summer too with A/C on, not nearly as much though as when the heat is on.
Old 11-18-2019, 06:07 PM   #7
mEmENT0m0RI
Member#: 365299
One other thing, I had custom audio put in. Anything that those ppl could've messed up with wiring that would impact the ventilation subsystem in this way?
Old 11-19-2019, 02:01 PM   #8
Shinji N
Member#: 3987
1998 2.5RS
Does it matter if you have the system on external air or recirculating?
Have you tested every single different combination of settings to see if they have smell or don't have smell?
Be methodical. Understand what you're testing.
Shinji N is offline   Reply With Quote
