Welcome to the North American Subaru Impreza Owners Club Wednesday April 14, 2021
Old 02-01-2021, 07:43 PM   #176
Pitcrew91
Member#: 271718
2005 STi
No problem.
I might venture to route the wire for the AP differently, but with how the wire goes into the connector straight i think id have to move the mount up higher.
Pitcrew91 is offline   Reply With Quote
Old 02-01-2021, 10:34 PM   #177
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Originally Posted by Pitcrew91 View Post
No problem.
It's to bad Cobb doesn't offer a right angle plug on AP part.. I have the Right Angle for the OBDII connection.. it definitely would make a cleaner install if that plug was right angle too..
Thanks again.... I have a Grimmspeed Catted Limited DP so the Wide band mounts to the very top of the DP at the Turbo ...how hard was the install for the Vent/WideBand???? and 'special' instructions??
Bill
Scooby South is offline   Reply With Quote
Old 02-02-2021, 08:01 AM   #178
Pitcrew91
Member#: 271718
2005 STi
linkto some info.
Youtube of a guy doing a LHD gauge install.
I didn't mean to imply I did the mod myself, car came with it already done and I've enjoyed it.
Old 02-02-2021, 05:33 PM   #179
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
linkto some info.
Awesome thanks again
Bill
Old 02-02-2021, 10:48 PM   #180
noktrnal1
Member#: 90957
2016 WRX
Crystal White Pearl
Originally Posted by Scooby South View Post
I am trying to keep it as original as possible and updating some OEM items with a later version of OEM.. I have them both.. so I think I am going to go with OEM at first to keep my 'scheme' as you put it . I really don't think there is going to be a huge difference over one or the other with my desired power levels. The Factory OE 19 STi intercooler can support up to 400 hp reliably.. The car has been a Stage 2 before with the larger aftermarket intercooler.. so I know what it 'can do' with it.. I am curious to see what the OE 19 I/C can do..
Previous Stage 2 ..323/376 for reference:
Either way it will look awesome. The upgraded OEM parts are a nice touch, I wish they came with a FMIC at some point.
noktrnal1 is offline   Reply With Quote
Old 02-03-2021, 04:41 PM   #181
jetjaguarxp
Member#: 522106
That's very nice!!!
Nice work.
jetjaguarxp is offline   Reply With Quote
Old 02-03-2021, 08:12 PM   #182
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Originally Posted by jetjaguarxp View Post
That's very nice!!!
Nice work.
Thank you guys.. means alot.. I think everyone will enjoy the final product once I get the way I want it in my head Should be an Eye Turner... As I said before.. I want people to see it.. and say "DAAAAAMN.. That's pretty Friggen Sweet."
Bill
Old 02-04-2021, 02:17 AM   #183
nappingcub
Member#: 222725
2006 WRX
CGM
For gauge mounting, check out the SMY dual bezel. They also make a 52mm adapter mount for the Accessport
nappingcub is offline   Reply With Quote
Old 02-04-2021, 03:50 AM   #184
ScoobyGT
Member#: 404382
2004 GDB STI
SanRemo Red
https://www.ortizcustompods.com/subaru.html
They make some nice gauge pods to !
ScoobyGT is offline   Reply With Quote
Old 02-04-2021, 09:14 AM   #185
Jaws4God
Member#: 521646
2003 Impreza WRX 207
02C, 42C World Rally Blue
Question
New Suspension to replace the tired old factory Struts/Springs. nothing fancy.. just needed some adjustment in my life
so what suspension did you get?
i'm just trying to figure out if i can tune my BC Racing Coilovers to give me a better ride or if I need to just switch to lowering springs and struts..
Thank you.
Jaws4God is offline   Reply With Quote
Old 02-04-2021, 04:46 PM   #186
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Excellent...thank you .. I am still undecided on where I want the Wide Band gauge... especially since it will probably be the one I look at most??? maybe ???
Thanks again
Ohhh Coool.. thank you some interesting configurations in there for sure..I Am all about information.. the more information the better
I have some time before all this.. probably once winter leaves and I can actually work on the car ...
Making a list of Stuff to do in the Spring to continue getting it back to my liking along with the updated components
Bill
Old 02-04-2021, 04:58 PM   #187
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Thank you.
I got my coilovers off Amazon... knowing what I know about spring rates and stuff... I opted for non-adjustable, Very similar to Stock Spring rates that are Height adjustable and allows Camber.. Nothing real fancy.. My ride quality is about the same as stock.. *Maybe a little bit stiffer but not really interfering with the ride quality I expected.
As for your situation.. I would suggest a spring change on the Coilover... The problem then becomes the valving.. You might get away with changing the springs that are on your coils to something softer..IIRC the BC come with like a 10k front and 8k rear... Converted to lbs..thats .. Heres a quick Chart to show you what rates you have ...
Spring Rate conversion
I would suggest for ride quality to get maybe a 350lb Front Spring and 275lb Rear spring .... You can get 2.5in Springs separately in any rate you want.. Hope that helps. Oh.. if you change the springs on your coils... you still get to control the dampening with the knob and you still get your height adjustment out of it and it would be about the same as you putting a lowering spring on...
Bill
Old 02-08-2021, 12:00 AM   #188
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Intercooler is ready to drop in.. Looks New..
I will try the STi 2019 OEM one first.. I might test to see how the AM one looks before I decide.. We'll see going to be doing the turbo/injectors/Downpipe and 3 port EBCS.. I really am contemplating either painting my OE manifold or just getting a new one.. Anybody painted theirs with either the Grimmspeed Cherry Blossom Red or the Wrinkle Red VHT???
How did it turn out???
Heres a pic of the 2019 Intercooler ready to go
Bill
Old 02-08-2021, 12:35 PM   #189
g_nutter
Member#: 471884
06 CGM Impreza
06 WRB STi
https://forums.nasioc.com/forums/sho....php?t=2907283
This is one thread that I've seen with VHT wrinkle red. Resprayed SPT intake. Looks like a slightly brighter shade of red with a slight orange hue. I like it personally. Funny how his car started out similar to yours as well Might be worth messaging him to see how well it worked!
g_nutter is offline   Reply With Quote
Old 02-08-2021, 03:41 PM   #190
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Thanks... been following his build... some pretty trick stuff he's using.. will reach out and see how he liked the Wrinkle Red VHT..
Bill
Old 02-12-2021, 10:09 AM   #191
Silver571
Member#: 88361
2013 Zentorno
Great thread, Bill. I am about to be taking on a similar endeavor, though without the awesome backstory. I had a 2005 STi in PSM from 05-12. Last week I picked up a 2005 STi in OBP for $7k and will be starting the restoration process very soon. Cheers!
Silver571 is offline   Reply With Quote
Old 02-12-2021, 11:32 PM   #192
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Thank you and Cool... Good luck. Let me know if you need any help
One of the best resources I have is knowing the part#'s of things..
I use this website : http://opposedforces.com/parts/impreza/us_g11/ That should help you get started.. There still is limited items that Subaru still stocks for a Blob.. Hopefully you have a decent relationship with your parts Dept.
Bill
Old 02-14-2021, 09:11 PM   #193
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Had some time to work on the rear spats finally . they are coming out ok. I had to basically sand them completely down to get the finish I am looking for. Not a expert at all, but learning. have to wet sand them then clear them. then wet sand them again.. The things we go thru for perfection of our vision
To Dang cold out to do anything actually on the car. *0degrees* lately. Brrr
So finishing up some things I can do in my basement..
*polishing the intercooler
*working on the paintwork on the spats.
*Putting all the parts in a pile so I can install them when it gets warmer
More Later
Bill
Old 02-17-2021, 08:26 PM   #194
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Getting Antsy.... Just got my annual invite to our local SUBIEFEST...I WILL be there.. Hopefully everything I want to get done to make this thing a show winner as well as something for everyone to drool over Hopefully in THIS: configuration or with the OE 18's... It really is going to be sweet ... at least in my vision it is..
Bill
Old 02-21-2021, 10:33 PM   #195
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
My painting skills are getting better.. not perfect by no means... but acceptable.. Reference: Rear Bumper Aprons for the STi..Don't know if I will actually install them. but at least I have the option. Still need to clear them, Sand, polish, Buff ...Repeat ... Tell your thoughts on actually installing them..
Bill
Old 03-01-2021, 01:28 PM   #196
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Snow is melting and I am getting excited to add all my new parts.. Painting is nearing completion of the Rear Spats and Rear Aprons.. Color is on, Just doing the clear then they will be ready to install.. Intercooler is Ready, Downpipe is ready, Turbo is Ready, 3Port is ready... Tuner is Ready.. 18"Rims/tires are Ready... All I need is a decent day temperature wise to get all this done.. Then enjoy it for a while.. Not much left to do after that.
Bill
Old 03-02-2021, 07:14 PM   #197
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Updated Intercooler pics.. with breather tube update.. Secured using 1/2" black nylon Hose connectors. looks great Have to trim the throttle body hose .. but overall looks great Enjoy
New OEM BPV...
Old 03-04-2021, 02:53 PM   #198
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Summer look ...Sexy Sexy time 2017 OEM STi Wheels mounted.. 18x8.5 Ummmm I LIKE IT ALOT...now to get the goldies refinished
Old 03-04-2021, 02:56 PM   #199
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Its starting to get the look I want.. Like I say going to get the goldies refinished.. Does any body have the color or a DIRECT MATCH to Factory for Powder coating???
Old 03-04-2021, 07:03 PM   #200
Silver571
Member#: 88361
2013 Zentorno
Wow, that turned out great!
