Welcome to the North American Subaru Impreza Owners Club Friday April 16, 2021
Old 06-08-2007, 12:29 PM   #1
Thugthizzle
Member#: 114098
Default knocking noise?
Theres a knocking noise coming from my car. It sounds like it's coming from the timing belt area or front of the car. Any ideas? It does it at idle or going down the road.
Thugthizzle is offline   Reply With Quote
Old 06-08-2007, 12:31 PM   #2
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
um....spun rod bearing?
anthonyrb98 is offline   Reply With Quote
Old 06-08-2007, 01:01 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Check your oil level....
Master2192 is offline   Reply With Quote
Old 06-08-2007, 01:25 PM   #4
throwOutBaRing
Member#: 149012
2004 WRX
Black Pearl
Does the knock change with RPM?
Does the knock continue when the car warms up (this may not be a great thing to test if you do have a real problem, but many subaru's have a weird cold noises)?
throwOutBaRing is offline   Reply With Quote
Old 06-08-2007, 01:32 PM   #5
Thugthizzle
Member#: 114098
yeh, it does it if the car is warm or cold. It sounds more like a rattle than a knock. It sounds like something is hitting the plastic timing belt cover? Oil level is fine
Old 06-08-2007, 01:42 PM   #6
Thugthizzle
Member#: 114098
it's not a constant knocking noise, like every so often while at idle it will knock once and the knock doesn't change much when driving
Old 06-08-2007, 01:52 PM   #7
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
Your timing belt idlers/pullies are worn. go get your teming belt changed and have them replace the idlers as well. My 03 was rebuilt at 77K and my timing belt idlers/pullies were THRASHED.
Valhakar is offline   Reply With Quote
Old 06-08-2007, 01:55 PM   #8
Rippen Griffen
Member#: 91708
2019 Veloster N
06 OBP - Sold
I think my car is like yours...it knocks from time to time. Scared the carp outta me when I first heard it. But, I have driven the car over 1k miles and the sound is still intermittant. I'm thinking that I have a lose heat shield???
If the bearing did go out, would the car stall or could it still be driven? Would it drive ok for a short while and then slowly get worse and worse? I have seen many posts diagnosing the problem, but I haven't seen if people are driving on it and don't know it's a problem until - Kablewy!!!
Rippen Griffen is offline   Reply With Quote
Old 06-08-2007, 02:30 PM   #9
MasterKwan
Member#: 98961
2003 WRX
If the timing belt goes, the car won't be drivable and you'll likely have some major damage to the valvetrain. So, if you think the idlers are bad, I'd get them fixed pretty soon.
MasterKwan is offline   Reply With Quote
Old 06-08-2007, 02:37 PM   #10
Thugthizzle
Member#: 114098
yeh my car has 75k miles on it
Old 06-08-2007, 06:53 PM   #11
Thugthizzle
Member#: 114098
i figured it out lol, it was my intercooler piping hitting the fendwell... Thanks everyone for there help>..
Old 06-08-2007, 11:42 PM   #12
jmonty
Member#: 97716
2013 BRZ GBS LTD
Outback Ltd
may be the MAF sensor? they tend to drift and not throw a code. You may want to replace that?
jmonty is offline   Reply With Quote
Old 06-09-2007, 12:10 AM   #13
bthomas
Member#: 50004
02 wrb
what?
bthomas is offline   Reply With Quote
Old 06-09-2007, 01:17 PM   #14
big16gwrx
Member#: 129459
check the timing belt tensioner
big16gwrx is offline   Reply With Quote
knocking noise??? Wedge Normally Aspirated Powertrain 9 11-20-2011 12:56 AM
Clunking Noise and Knocking Noise from rear. AWD_Drift Brakes, Steering & Suspension 16 02-14-2011 02:56 AM
Weird Knock noise, dont think its engine knock mlotek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-14-2006 09:12 PM
Slight knocking noise, various noises on springs? twotacosfor99cents Brakes, Steering & Suspension 4 02-21-2003 01:26 PM
knocking noises from back of WRX . The fix ! ginowrx Brakes, Steering & Suspension 3 06-08-2001 12:30 AM
