![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 92114
NESIC
Vehicle:03 WRX (NAVY Camo) in"Special Ed." Run Group |
![]() Like the title, where is the best (most reasonable) place to buy a brake pad spreader/remover online.
I'm running a Wilwood big brake kit with Cobalt GT Sport pads and would like a tool that would make it faster/simpler to change them out. I've seen the pad spreader around but not sure where to purchase. Thanks guys!
#2 |
Member#: 98961
Vehicle:2003 WRX Black |
![]() Well, you can use a screwdriver between the pad and the rotor. I have a pair of vise grips with flat ends on the jaws (for holding welding materials). I use that on my calipers.
#3 |
Member#: 124146
Vehicle:'17 Outback 2.5i Premium Tungsten |
![]() A large C-clamp will do the job well for little money.
#4 |
Member#: 103162
NESIC
Vehicle:04 RS Sedan PSM |
![]() Sears sells pad spreaders/removers.
#5 |
Member#: 15359
![]() Most pad spreaders are designed for sliding calipers and won't work well on your Wilwood setup. I have the BSL6 front caliper. When I change pads I just open the bleeder and push the piston back in with my finger. I'm running a track car though, so I'll just leave the bleeder open for a little bit and let it gravity bleed any air bubbles that might have accumulated.
Duncan |
#6 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
![]() wiggle one pad out. Turn 90* with friction surface against rotor. Use as a lever to push pistons back.
Insert new pad. NOW remove the second pad, turn 90* and use as a lever. insert new pad. |
#7 |
Member#: 120152
![]() My friend has the rubber padded quick grips. They work quite nicely and don't marr up nice mono-block calipers.
#8 |
Member#: 92114
NESIC
![]() Cool, thanks for the input guys.
#9 |
Member#: 39086
NWIC
Vehicle:2004 STi White |
![]() Eastwood.com for your strange tools.
SS brake line copper washers - where to buy | mmiller2002 | Brakes, Steering & Suspension | 4 | 03-08-2010 02:07 PM |
Brake pads for gc8, where to find? | Mayrun | Brakes, Steering & Suspension | 0 | 08-03-2009 09:18 AM |
Changing brake pads, where to buy? | 98kPa | Bay Area Impreza Club Forum -- BAIC | 10 | 08-09-2002 05:22 PM |
Need decent brake pads, what and where to get? | RotarFreak | Brakes, Steering & Suspension | 8 | 05-03-2002 11:48 AM |
Where To buy Endless Brake pads??? | Tkacik | General Forum Archive | 4 | 05-20-2000 12:36 AM |
